Nitrous Oxide Too soon, jr.
100 shot OK without retarding?
Old Sep 28, 2007 | 07:48 AM
skwid's Avatar
skwid
Originally Posted by RedondoG
When I ran those numbers I had the jets all wrong and the A/F was at 10:1 (.004" larger fuel jets). At the same time I had a bad O2 sensor that wasn't working at all above 5K rpm.
I have since increased the a/f to 11.5:1 and had the O2 sensor replaced, but no dyno yet.
Ok cool. I was just checking. It sounds like you should be better off now.
@Oldschool, you still injecting or are you FI?
Old Nov 6, 2007 | 07:46 PM
VQTURBODREAMS1's Avatar
VQTURBODREAMS1
what is the difference between pulling timing and tunning the car??
Old Nov 7, 2007 | 07:24 AM
RedondoG's Avatar
RedondoG
Pulling timing is a global thing (pull 2 degrees across the entire range) whereas tuning might involve pulling timing in a specific RPM band and at the same time changing fuel targets, cam timing, etc...
Old Nov 7, 2007 | 09:58 AM
VQTURBODREAMS1
so how do you pull timing??
Old Nov 7, 2007 | 10:00 AM
blasian's Avatar
blasian
You pull timing with some type of engine management.
Old Nov 7, 2007 | 10:18 AM
RedondoG's Avatar
RedondoG
I use the Osiris system by Uprev.
sales@czp
Sep 23, 2019 03:30 PM
Fixxxercask
Cooling System
Nov 5, 2015 03:21 AM
Mattg350z
Oct 2, 2015 06:51 AM
SharX59
Sep 27, 2015 09:23 AM
