Nitrous Oxide Too soon, jr.
How much you spraying?
Old May 15, 2008 | 06:26 AM
KS35's Avatar
KS35
Default How much you spraying?
Just wanted to see what shot everyone is running. Saw a thread in G 35 Driver for FI, so i was just wondering how much you pushed it, your HP, 1/4 mile times, and other bolt ons. Is you motor still running strong, is it built, or did it go boom? How often did you use it and how long have you had it? Hopefully we'll see some good numbers.
Thanks for you input!!!
Douglas
Old May 15, 2008 | 06:51 AM
hershell's Avatar
hershell
Here are the top N2O times.
It seems that most are running a 100 or a 125 shot. Their are a few running a 150 shot.
Originally Posted by aceman
Nitrous Oxide Systems
1. one350zfan ----------03 Base 6spd 150 shot 11.832@113.32mph 1.653 60ft Verified DRs
2. AudibleMayhem -------03 Tour 6spd 150 shot 11.833@115.53mph 1.639 60ft Verified Slicks
3. 350z0827 ------------03 Tour 6spd 125 shot 11.896@117.12mph 1.639 60ft slicks
4. Integrity -----------03 Tour 6spd 100 shot 12.052@113.67mph 1.739 60ft Verified Slicks
5. Mysunset 350z -------03 Tour Auto 100 shot 12.621@108.46mph 1.742 60ft Verified Slicks
6. Faster than U -------05 Base 6spd 100 shot 12.662@110.84mph
7. VicPham -------------03 Tour 6spd 100 shot 12.804@111.55mph 2.090 60ft Verified Street
8. Blububble -----------04 Base 6spd 100 shot 13.120@108.58mph 1.994 60ft Verified Street
9.
10.
Old May 15, 2008 | 09:44 PM
MySunset350Z's Avatar
MySunset350Z
im the only auto huh? lol.
if you dont plan on building your bottom end, stick to 100-125 shot with some colder plugs and you'll be fine.
Old May 18, 2008 | 09:20 AM
KS35's Avatar
KS35
So Sunset what all do you have done to your car? Tune? How long have you been spraying? Does it weaken the motor at all?
Thanks
Douglas
Old May 18, 2008 | 10:32 PM
MySunset350Z
Thanks
Douglas
bought my car in march of 2003, and slapped nitrous on in in august of 2003.
pulley, test pipes, intake, tranny cooler, nx nitrous with all the goodies. heater, opener, dual purge, billet mount and all the gauges (a/f, fuel pressure and nitrous pressure). shot as high as 125 for a short period of time, but dropped down to 100 and kept it there since. 2 step colder plugs, and some mickey thompson et streets to keep it on the ground. the last mod was my torque converter upgrade, but havent tested it on the strip yet. everything else i've done is cosmetic.
thats it. no ecu work, no controllers, no engine work at all aside from the plugs.
motor has 72k miles on it and still no issues (knock on wood). car runs fine. i just need to wash it more often.
i have a video in my sig of my car. video was with a 100 shot and before the tc was done. if i post another slip its going to be a sub 12second run or i wont even bother.
Old May 19, 2008 | 07:12 AM
KS35's Avatar
KS35
So you just pretty much just threw it on there? wow thought it was a little more complicated than that...
Old May 21, 2008 | 05:23 AM
MySunset350Z
its not very complicated. you just have to be carefull just like with any other type of FI you put on your car.
there are certain guidlines you have to go by when using nitrous to make sure you have years and years of hassle free use without messing something up.
Old May 21, 2008 | 06:38 AM
KS35's Avatar
KS35
What kind of guidelines? Their a form on it? Do you have a window switch or just push button? Also nice vid... What do you put on there to lock up your front tires to do a burnout or did you just hold the brake? Thanks for all your info really helpful!!!
Old May 21, 2008 | 11:42 PM
MySunset350Z
like dont spray at too low of an rpm. dont spray with low bottle pressure. dont spray unless your at wot. dont bounce off the rev limiter wen ur spraying.
do a search for "CMODS", theres a fuse you need to pull be able to do a standing burnout.
i have a wide open throttle switch mounted right behind my gas peddle. i also have another switch hidden in the shifter that engages and disengages the system inbtween shifts, but its not a must have.
Old May 22, 2008 | 11:23 AM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
Pics and more information, please.
Old May 22, 2008 | 08:39 PM
KS35's Avatar
KS35
Fuse huh? well i'll check that out, thanks for all of your info Sunset...
Old May 22, 2008 | 09:28 PM
Old School's Avatar
Old School
Shift_Boost
mmmm...nitrous....me likey nitrous.
Old May 23, 2008 | 02:29 AM
MySunset350Z
its a wot switch i tweaked and mounted in just the right spot in the shifter (auto), to where its engaged when im in manual mode and disengaged when i shift up or shift down in manual mode. its wired before the wot switch behind the gas pedal so it needs to be activated before the wot switch gets power. not as complicated as it sounds. but i dont like the idea of spraying while the car is shifting and the throttle body isnt open all the way. asking for trouble in the long run imo.
ill take some pics and post them tomorrow.
Old May 23, 2008 | 03:23 AM
coachk's Avatar
coachk
Sounds interesting....what rpm range are you spraying in? I'm also a little confused about how your spraying at wot but having it not spray during manual shifts. I guess my question is , when your racing why would you not be at wot when shifting?
Old May 23, 2008 | 07:29 AM
3hree5ive0ero
Retired Admin
Very interesting. Not bad of an idea.
CoachK, I think he's saying that he's WOT when racing, but during his manual shifts, his WOT switch power is momentarily cut off as he has fabricated another WOT switch for his auto shift ****.
Old May 27, 2008 | 02:11 AM
mjk's Avatar
mjk
isnt the wot switch mounted on the TB? and so only engages when the tb is at wot?
thanks
Old May 27, 2008 | 02:34 AM
3hree5ive0ero
Retired Admin
thanks
A WOT switch is installed behind the gas pedal. It is a manual on/off switch.
TPS (throttle position sensor) is what you mean. That senses the difference in voltage between the set voltage (user defined/set) and the actual reading on the TB wire. When the difference becomes 0 (or goes above the set voltage), that's when it triggers the solenoids electronically.
Old May 27, 2008 | 03:06 AM
mjk's Avatar
mjk
I guess its different on a z, drive-by-wire.
thanks for explaining
bcoffee20
Nov 19, 2015 06:39 PM
Vigman
Nov 17, 2015 04:34 AM
kyin
Oct 15, 2015 05:54 AM
roadmax
Sep 12, 2015 05:55 PM
