Nitrous Oxide Too soon, jr.
question to the n20 gods
Old Jul 17, 2008 | 02:27 PM
genegoesfast's Avatar
genegoesfast
Originally Posted by garym
Hmmm,
I'm not at home to look, but maybe the info is in the UTEC guide.
I dug through the manual and it's definately just a ground.
Old Jul 17, 2008 | 03:33 PM
one350zfan's Avatar
one350zfan
I would think the TPS wire could still be connected to its same location because even if the zex box senses the TPS signal it still wont activate until it sees ground.
Old Jul 17, 2008 | 08:48 PM
genegoesfast
This absolutely makes sense and I do appreciate all the help. My only additional concern is that I would like to use the UTEC to define what WOT is; whether it be 90% or 100%. I want to make sure that it fires whether or not I managed to hit 100%. I'm not sure if that makes sense. Thanks in advance!
Old Jul 18, 2008 | 08:26 AM
one350zfan's Avatar
one350zfan
Ah, that puts a little wrinkle in the situation...
I would think that setting it at 90% wouldn't make much difference. When I get off of it I want the NO2 to stop immediately!
Old Jul 18, 2008 | 02:26 PM
2boosted4u's Avatar
2boosted4u
do you have to use a utec to accomplish the 90%?? or can you trick the zex box in to thinking that your at 100% when ur at 90 and anywhere past that it still fires
Old Jul 18, 2008 | 04:13 PM
genegoesfast
Yes you have to have the zex box "learn" what WOT is. Which means in a drive by wire car like the 350z you have to take the intake pipe off and pry the throttle body valve open while pushing the button on the ZEX. <this process i feel sucks and has to be somewhat inaccurate. I'd like to tweak and define what WOT "feels" like.
Old Jul 19, 2008 | 05:25 AM
genegoesfast
bump
Old Jul 25, 2008 | 04:36 PM
2boosted4u's Avatar
2boosted4u
hmmm i think i might try that for a lil more power for drifting instead of haven to pin it everytime....im getting dynoed tomorro morn so well see what happens!
Old Jul 25, 2008 | 05:35 PM
chefrey's Avatar
chefrey
im the person that was working with turbo xs and they stopped working with me so i just went to the old software and everything worked fine. genegoesfast bougth my utec off of me so you shouldnt have any problems it was working fine on my car.
the utec spare solenoid is definately the ground and if you have the new version on your utec try buying a map sensor. i have a pretty good idea that it will get the new update to work. i got as far as using a pig tail map sensor plug which pegged the boost at 60 psi and the spare solenoid would kick properly but the car would stall everytime i started it because the utec would pull fuel, fuel cut is at 40 psi and i was always reading 60. they wouldnt send me a map sensor on them so i just went to the old sowtware for free and it worked.
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
