Nitrous Oxide Too soon, jr.
best window switch??
Old Jul 27, 2008 | 08:29 PM
2boosted4u's Avatar
2boosted4u
Default best window switch??
who has the best window switch?? or what should i use instead?? besides a utec i already have a tps from my zex kit so im good there...thanks in advanced
Old Jul 27, 2008 | 09:09 PM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
MSD and Dynotune window switches seem to be very popular.
Old Jul 28, 2008 | 07:25 AM
2boosted4u's Avatar
2boosted4u
will those work with the zex box?? when i saw the instructions it looks like it needs a whole relay setup and stuff...how hard are they to install??
Old Jul 28, 2008 | 01:43 PM
3hree5ive0ero
Retired Admin
The MSD and the Dynotune ones can replace the ZEX box altogether. But, if I remember correctly, the ZEX box also houses the solenoids. I had a friend who installed the MSD unit and his ZEX brain together, so it should work. Same with the Dynotune (as its the same as MSD with a different brand name on it).
It shouldn't be too hard if you know anything about wiring.
Old Jul 28, 2008 | 05:51 PM
2boosted4u's Avatar
2boosted4u
right on bro should i bother with the 2 channel or just 1??
Old Jul 28, 2008 | 06:22 PM
3hree5ive0ero
Retired Admin
If that's what I'm thinking.. then you only need 1.
I'm guessing you only have 1 set of solenoids (1 fuel, 1 nitrous), which means that you can only utilize 1 channel anyway. If you have a second set of solenoids, then you can use the 2nd channel to use that second set of solenoids for a bigger shot.
You can spray a 50 shot from 3-6k, then spray another 50 shot from 4-6k. Remember that with nitrous it's not just simple math. That is 50 shot + 50 shot isn't 100. You have to calculate the diameter of the jet sizes and blah blah to actually get the real number, so I don't suggest you do this. Simple math, I'd assume, but more trouble than it's worth.
Old Jul 28, 2008 | 06:26 PM
2boosted4u's Avatar
2boosted4u
hahaha good **** yea ill just need 1 channel with my 100 shot
Old Jul 29, 2008 | 05:09 PM
BiGGD198's Avatar
BiGGD198
noob question but im at work, running off shitty wireless internet and i know i should search first but i finally got the "post" page to work so id figure i ask since i have the opportunity....
what is a window switch?
Old Jul 29, 2008 | 05:18 PM
2boosted4u's Avatar
2boosted4u
everyones goin to say search...i just say go to dynotunenitrous.com and look it up...it allows you to set what rpm you spray in and what gears you want to lock out...meaning what gears you DONT want to spray in
Old Jul 29, 2008 | 06:36 PM
Ruthless18x's Avatar
Ruthless18x
Personally I like the Zex RPM window switch, it is supposed to work well with the Zex "brain". We'll see though, just ordered it today.
Old Jul 29, 2008 | 09:14 PM
2boosted4u's Avatar
2boosted4u
interested in how that works out keep me postedd
Old Jul 29, 2008 | 09:26 PM
3hree5ive0ero
Retired Admin
There's no such thing as which one works better. As long as they're set up correctly, they should all work the same. They all have the same general idea/principle behind it anyway. So, to argue this one works better is just plain stupid and uneducated.
The difference you may see is just a software thing, not a hardware thing. So personal preference could play a part there, but again, why spend the extra dough on things that does essentially the same thing as the cheaper one? To look pretty?
Do some research on these things and you'll learn a lot more than just asking for quick answers here. Plus, once you learn things on your own, you can help other noobs.
Old Jul 29, 2008 | 09:35 PM
2boosted4u's Avatar
2boosted4u
soooooooo should i search??
Old Jul 29, 2008 | 09:38 PM
3hree5ive0ero
Retired Admin
I don't know. What do you know/think?
Personally, I think the Dynotune has the best price for its features and will do the job perfectly well.
The MSD has the name value, so it's a bit more pricey, but does the same thing as the Dynotune one essentially.
I'm not sure about the ZEX one, but I'm guessing that the name will bring up the price a little for what it does while doing the same thing the others can do.
Then there's the NX one, which is just crazy. It has all the bells and whistles, but all that comes with the heavy price. It sure looks pretty, though.
P.S. - There's at least 1 guy for each of the above companies on our boards. So, regardless of what you choose, you should be able to get help, if necessary, with troubleshooting while installing the said item. Well, except for the NX one, but that's only because it's too damn expensive.
Old Jul 29, 2008 | 09:55 PM
2boosted4u's Avatar
2boosted4u
right on
Old Jul 30, 2008 | 09:39 AM
BakaN20's Avatar
BakaN20
zex is the sameas Dynotune. The box looks exactly the same and the instructions program the same way as the Dynotune. The instructions are a little better than Dynotune but essentially the same.
Old Jul 31, 2008 | 07:06 PM
2boosted4u's Avatar
2boosted4u
right on guys im just goin to order the zex to keep it all one company ya know
Siqcology
Sep 18, 2019 01:45 PM
Boots patrol
Exterior
Nov 7, 2015 12:26 PM
AP350z223
Sep 8, 2015 04:38 PM
