Nitrous Oxide Too soon, jr.
Help!! 75 shot,+ na mods 14.2 E.T. !!!
Old Aug 24, 2008 | 03:34 PM
mangoman4u's Avatar
mangoman4u
Default Help!! 75 shot,+ na mods 14.2 E.T. !!!
Two years ago my stock 03 6mt was running 13.996-14.3 @99-101 mph consistently. Since then , I moved away from any track , and , have within 6 months installed : untuned UTEC (Running intake & header base tune) , STRUP headers, Megan Racing test pipes and cat-back exhaust , AAM plenum spacer , ZEX 75 shot with traction control window switch. And moved back to the same area and same track.
Two separate trips at the track have netted me consistant 14.3 runs @ 95-98 mph. Based on my mods , my research tell's me the set up should be good for low 12's @ around 105 mph.
Anyone have any ideas?
Old Aug 24, 2008 | 03:51 PM
mangoman4u's Avatar
mangoman4u
Default Also
Also I forgot to mention that my car gives me a verified 25- 28.5 MPG Highway milage and around 22-23 combined mpg as it allways has .
Old Aug 24, 2008 | 03:56 PM
Willie's Avatar
Willie
Limp mode?
Old Aug 24, 2008 | 04:15 PM
GrayG35's Avatar
GrayG35
the nitrous is not working. the window is probly not opening
Old Aug 24, 2008 | 04:16 PM
GrayG35's Avatar
GrayG35
also i think it should be good for mid to high 12's with good tires
Old Aug 24, 2008 | 04:33 PM
pimpsahab's Avatar
pimpsahab
Maybe with five mexicans giving you a pushstart causing a 1.2-1.3 60 foot
Old Aug 24, 2008 | 04:39 PM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
You're definitely not spraying nitrous and the weather's yielding slower ET and trap.
I'd check the wiring, the solenoids, and the electronics before attempting to use the nitrous again.
Old Aug 24, 2008 | 07:53 PM
genegoesfast's Avatar
genegoesfast
how would you not know that the nitrous wasn't firing? It should be a major kick in the a$$. Are you spinning tires?
Old Aug 25, 2008 | 08:03 PM
Laino's Avatar
Laino
Pull your nozzle out and fire it.
Maybe your just out of practice.. Go back I doubt low 12's tho
Old Aug 25, 2008 | 08:06 PM
3hree5ive0ero
Retired Admin
Out of practice doesn't give you the lower trap speed with a 75 shot of juice and slower ET, no matter how much traction you lost in 1st and 2nd.
Good luck getting low 12s (and at only 105 mph) with just a 75 shot, not to mention on street tires. I don't even need to bring up the current weather conditions, right?
OP, check/fix the plumbing and the wiring.
Old Aug 26, 2008 | 03:02 PM
I am JDM's Avatar
I am JDM
low 12's at 105 tells me ur research is WRONG!! take it from 3hree5ive0ero and i we know from experience and spray. a 105 trap is more of a low 13. and on street tires low 12s is not likely. and do u feel the nitrous turn on???
Old Aug 26, 2008 | 07:22 PM
3hree5ive0ero
Retired Admin
Actually, a trap of 105 on better than perfect run with better than perfect variables can result in a 12 sec run.
My sig shows a good example of what a 105 trap would get you as far as E.T., if you execute things almost flawlessly along with great conditions (click on my 1/4 mile time to see the slip).
Old Aug 26, 2008 | 07:59 PM
I am JDM's Avatar
I am JDM
on slicks doubt street tires tho
Old Aug 26, 2008 | 09:46 PM
3hree5ive0ero
Retired Admin
Well, for my time, it was on slicks.
I've seen a 13.000 @ 100.xx run though in person. It was a very, very hot and humid day (no surprise there, since it is TX after all) where I was only pulling 13.4 or 13.6 on slicks. This guy in a supercharged 350Z ran that 13.000 @ 100.xx run and I couldn't believe it. I didn't know how to explain it.
Well, anyway, it is possible to run 12s with mid 100mph traps. I see those from time to time at the drag strip and I used to go very often.
OP, progress update?
Old Aug 27, 2008 | 06:29 AM
singh's Avatar
singh
_______________
Wow. I hate to be an @ss, but you purchased all those mods and you achieved a degraded performance. That sucks. There must be a problem.
Old Sep 4, 2008 | 07:31 PM
Zendem's Avatar
Zendem
Why they gotta be Mexicans?
Anyway definatly something wrong with the nitrous set up, i'm running 14.3's on a bad day at the track.
Old Sep 5, 2008 | 05:03 AM
silver350tn's Avatar
silver350tn
hey turn your bottle on.no reason why you should be running that slow at all
Old Sep 7, 2008 | 11:58 PM
mangoman4u's Avatar
mangoman4u
Default update
I think I'm running rich
1.o2 sensor on right bank was unplugged (ran over a tractor trailer TIRE in the middle of the road i95,... could not dodge; cars on either side of me)
2. I my cone filter was a little loose and dirty ; cleaned and replaced.
3. I think my plugs (1step colder) are expiring (they have around 5000 miles on them ) ECU is throwing p300(random misfire) and p302 (misfire cylinder #2) I have a set of IRIDIUM 1 COLDER , ANYONE HAVE AN EXAMPLE OF WHY I SHOLD NOT USE THEM PLEASE LET ME KNOW.
4. Probable nitrous leak; higher than normal pressure 1050 , and when I took the bottle out it felt light , speed shop said it had 1 pound , line over tightened I think.
5. Car was at high altitude for 1 year getting 14 mpg. Retarded timing & adjusted fuel map by stock ECU ?
On another note , while under my car yesterday I noticed that when Nissan replaced my transmission on factory warranty, they either did not torque down or install driverside differential mount. The bolt was completly loose. Boy that would have sucked if the car was running right; leaner optimal condition + loose differential + nitrous would probably equal broken something ,like a drive shaft .Once I reinstalled the bolt I noticed crisper shifts.
New ET 13.996 on 75shot .Still not good , but better.
I will let Every one know once I am up to par what the rest of the problems were.
Old Sep 14, 2008 | 01:51 PM
MDHRZ's Avatar
MDHRZ
Hey man nice meeting you last week. Anymore updates on the car?
Old Sep 15, 2008 | 12:16 PM
Fluid1's Avatar
Fluid1
That's insane, I ran bone stock and got 13.868. Something's way wrong.
sales@czp
Sep 23, 2019 03:30 PM
HoBrahYouStink
Jun 24, 2016 10:58 PM
Tochigi_236
Sep 27, 2015 03:40 PM
