Nitrous Oxide Too soon, jr.
Traction Question
Old Feb 23, 2009 | 03:28 PM
genegoesfast's Avatar
genegoesfast
Originally Posted by Alberto
Alignment specs? Temp when doing it?
alignment specs are actually stock due to me being a stock ride height. Temp is 60 degrees plus on average.
Old Feb 24, 2009 | 07:01 AM
Alberto's Avatar
Alberto
Cranky FI Owner
You have an 04' Z, and it's on stock alignment? My camber moves .1-.3 negative per year on average. If you havent had an alignment anytime in the past year I guarantee its -2 or worse!
I may not know "jack $hit about [your] set-up now" (nor do I even care about your or other people's set up), but I know enough to know you don't have nitrous.
You dont know what I have or dont have on my car right now. Do you really think I post about everything? Who are you to tell me and others online what I do not have? LOL
Old Feb 24, 2009 | 09:21 AM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
Of course you don't post about everything - who does?
Why are you so butthurt? If you have nitrous, well, congrats. If you don't, well, nobody will reprimand you.
You gave out numbers as if you had nitrous at that time (it read like so), so I was telling the OP that you had a single turbo and not nitrous (to avoid any confusion). There's nothing wrong with me telling him that.
I don't know who pissed in your cereal these past few days, but calm down. Nobody's out to get you - you got serious anger management issues. I'm still @ you getting so worked up, though.
Old Feb 24, 2009 | 07:41 PM
chefrey's Avatar
chefrey
needless to say alberto is right. negative camber is a bad idea when running nitrous. its a real bad idea to throw gobs of instant tourque at your tires when you are only using half the contact patch due to camber. i made this mistake myself running a 100 shot on a dropped 350. couldnt launch with it, couldnt spray in first after i got traction, couldnt have the nitrous activated at the start of second gear. i actually had to wait to about half way threw second to engage and not blow the tires up. even lost my grip in 3rd a number of times.
.8 inch drop on 19.9.5 +20 275/35 tires traction was allways a problem.
the best solution i found was to use somehung like the maximizer so u could slowly ramp the nitrous in to keep traction. if you go that way be sure to keep a close eye on your solenoids they will wear a lot faster when they are ramped.
Old Feb 25, 2009 | 03:18 PM
genegoesfast
No I mean stock specs...I've been aligned in the last 6 months. Sorry about the confusion.
issyz
Jul 2, 2017 03:04 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
Alexreyes
Sep 30, 2015 11:30 PM
