zex kit questions
My Zex kit worked flawlessly last night. on just a 55 shot ran a 13.562 at 104.33 on 19s. What a difference...from no spray and 14.1s still waiting for plugs to go bigger shot...
According to the ZEX kit, any shot over 55hp (crank #'s), and you need to start retarding the timming. Does the Z's ECU sense boost, and automatically retard the timing a bit? The Zex kit says to retard timing by 2 degree's for a 75hp shot. Is this really necessary with the Z.
absolutely not. You control the a/f mixture by changing the proper fuel/nitrous jets. After every jet change I always recommend that you dyno to make sure your a/f is safe. No one here with nitrous does timing adjustments that I know of.
ZEX IS THE BEST ALONG WITH A BLOWER....
13.241@106.8mph
MODS:
Zex 55hp NOS
Borla True Dual Exhuast
Injen CAI
HKS Grounding
UR 3 Peice Pulley Set
18" ADR Wheels Wrapped with Proxies
Check out my ride:
http://www.cardomain.com/member_page...7&cat=10&val=1
13.241@106.8mph
MODS:
Zex 55hp NOS
Injen CAI
HKS Grounding
Check out my ride:
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
