Nitrous Oxide Too soon, jr.
Can we retard timing manually ?
Old Mar 21, 2009 | 02:08 AM
GooDy151's Avatar
GooDy151
Default Can we retard timing manually ?
Is there anyway to adjust timing instead of getting piggy back or reflash?
HR tho.
thanks
Old Mar 21, 2009 | 05:01 AM
350z-Jim's Avatar
350z-Jim
The only manual way of adjusting timing on older cars was turning the distributor. Obviously this doesn't apply to our cars. You would need a re-flash or an ignition system that is programmable or has a retard function built into it (MSD etc).
Why do you want to retard timing anyway? Nitrous or are you going turbo? If it's nitrous you can spray 100-125 on stock timing no problem, just use colder plugs.
Old Mar 21, 2009 | 06:06 AM
ZU L8R's Avatar
ZU L8R
Viper Sellout
The consult @ the dealership can adjust timing. + or - 2 degrees I believe. I don't know how much they would charge you
Old Mar 21, 2009 | 06:55 AM
twitch579's Avatar
twitch579
Or anyone with the Cipher program can pull some for you.
Old Mar 21, 2009 | 07:25 AM
QuadCam's Avatar
QuadCam
you can run a 100-125 shot without any timing adjusting......it has been done by many on these boards......including myself.
Old Mar 21, 2009 | 08:22 AM
twitch579's Avatar
twitch579
Im sure he will need to adjust his fuel jets to get the right AF. On my 06 Sedan on the stock Dynotune jets for a 50 shot I was at 17's.
Find a way to monitor your AF before u start thinking about pulling timing. I wouldnt even spray on a stock car seeing what ive seen with these out of the box setups that are supposedly tuned for our particular cars.
Old Mar 21, 2009 | 10:33 AM
GooDy151's Avatar
GooDy151
Thanks every one
Obadabot
Jun 18, 2023 11:31 PM
