Nitrous Oxide Too soon, jr.
Nitrous with Fully Built NA Rev-up Motor
Old Jan 14, 2010 | 10:30 AM
kacz07's Avatar
kacz07
Default Nitrous with Fully Built NA Rev-up Motor
Hey! Looking to get into the nitrous game w/ my new setup. NA build not getting me to the number I want, so I'm going on the juice. The build itself seems strong enough to handle a larger shot, but I think with the increased compression (11.5 to 1), I should be more efficient. Thinking about a 75 or 100 shot.
I'm thinking about the Dynotune Nitrous kit for 03-06 350Zs. Looking into a proper engine data monitoring system (microedge, gauges, etc.).
I'm reading up, but just wanted to introduce my build to the nitrous crowd for discussion!
List of mods and build thread:
https://my350z.com/forum/na-builds/4...50z-revup.html
Components from intake to Exhaust:
JWT PopCharger (ConceptZPerformance)
Custom 3 inch MAF housing
Cosworth Manifold (Sharif@Forged)
Nismo Radiator Cap
Koyo R-core radiator
Samco hoses
GTM Oil Cooler
Ferrea +1mm Oversize Valve train
JWT C8R Camshafts
HR Head Gaskets
NGK Iridium tipped spark plugs (one step colder)
Wiseco 96mm 11.5:1 Pistons
-.020mm overbore
-ceramic coated
Eagle H-beam rods
ARP L19 Head Studs
ARP Main Stud kit
ACL Trust Washers
ACL Main Bearings
ACl Road Bearings
Engine Gasket Kit
Rear Main Seal Retainer
Engine Component Work:
-Block inspected and cleaned
-Block redecked
-Block Bored and Honed using a Torque Plate
-Rotating assembly balanced
-Crank magnafluxed
-Journals micro-polished
-Heads inspected and cleaned
-Heads redecked
-Ported exhaust and intake runners
-5 angle radius cut valve job
-Bowl work
-Valve stem seals installed
-Valve Stem Heights set
-Cold Clearance set for JWT cams
-Heads assembled
Megan Racing long tube headers
Borla True Dual Exhaust
UpRev Osiris Pro Tuner
Old Jan 16, 2010 | 08:30 PM
Hostetler's Avatar
Hostetler
150 shot would be very good for this set-up...it looks to be a strong build and can definitely handle a 150 shot. Direct port fogger with direct port meth/water injection
now go do it, post numbers and details
Old Jan 16, 2010 | 08:38 PM
S12 driver's Avatar
S12 driver
With such a high compression ratio, you might be limited on pump gas. You may not be able to spray 150 shots on pump gas.
Old Jan 16, 2010 | 08:46 PM
Hostetler's Avatar
Hostetler
thats what the meth injection is for
Old Jan 19, 2010 | 04:55 AM
kacz07's Avatar
kacz07
Leaning towards the Zex direct fit kit...
Old Jan 19, 2010 | 05:03 AM
SRT8-Jeep's Avatar
SRT8-Jeep
Id say a 150 + shot will do the trick...
however, if your gonna spray it Id say ditch the iridium plugs for a set of copper plugs
also, Id say dont get the zex kit, just get dynotunes and get a progressive controller...who cares if you have o rebuild solenoids after a while from it...thats easy
Old Jan 19, 2010 | 05:16 AM
jbaker1121's Avatar
jbaker1121
sounds good.....I want to do the same for my FX if i end up cheaping out and not wanting to spend mad bank on FI
Old Jan 19, 2010 | 10:23 AM
kacz07's Avatar
kacz07
Yeah my logic is that I have enough power NA and can activate the additional stress (albeit not so significant considering the build, shot, etc), rather than having to stay out of boost all the time if I want to keep the engine wear to a minimum. Not only that, but with less parts, seals, etc., maintenance should be less and that equals more enjoyment with my car.
Old Jan 20, 2010 | 12:07 PM
mgrotel's Avatar
mgrotel
why do you suggest copper over iridium plugs?
Old Jan 20, 2010 | 09:51 PM
kacz07's Avatar
kacz07
+1 I've never read in any FI build where copper is chosen over iridum tipped colder plugs...
Old Jan 20, 2010 | 09:57 PM
mgrotel's Avatar
mgrotel
actually, in reading some more, copper seems to be preferred in most FI applications.
Old Jan 20, 2010 | 10:04 PM
Hostetler's Avatar
Hostetler
there is a greater chance of burning/melting/breaking the tip of an iridium plug under high cylinder pressures (high boost,Big shot)
-Iridium-
-Copper-
And with copper you can adjust your spark plug gap...if you try to gap iridium plugs, you will most likely damage them
kacz07's Avatar
kacz07
Well, I guess I haven't been paying attention... I feel like I'm ok, considering I'm fully built NA and won't be going with a crazy huge shot.
Old Jan 21, 2010 | 07:31 PM
BakaN20's Avatar
BakaN20
The microedge is one of the best controllers you can get. Incredible for the price. Use stage 1 to activate meth and stage 2 for nitrous. It can do so much, if you want more info, let me know. Go for meth also, if you are interested, I can get a discount from a supplier.
35reilly
Sep 28, 2015 07:42 AM
