Nitrous Oxide Too soon, jr.
help! 2006 Z looking to spray...
Old Mar 15, 2010 | 02:26 PM
CamiloA98's Avatar
CamiloA98
Default help! 2006 Z looking to spray...
Hello,
I have a 2006 Base stock. What do I need for a 100 shot of nitrous?
Old Mar 15, 2010 | 03:19 PM
DavesZ#3's Avatar
DavesZ#3
The first thing you need to do is to read the FAQ at the top of this forum (https://my350z.com/forum/nitrous-oxide-181/)...
https://my350z.com/forum/nitrous-oxi...irst-time.html
Old Mar 15, 2010 | 03:51 PM
jbaker1121's Avatar
jbaker1121
You need a 100 shot nitrous kit....
check out ZEX or NOS
Old Mar 15, 2010 | 05:26 PM
Mike@Blackline's Avatar
Mike@Blackline
lulz
you should be able to shoot 75 shots, 100 shots safely every once in a while, but thats going off what ive read around here, i havent the slightest idea bout NOS and its use
Old Mar 15, 2010 | 05:58 PM
CamiloA98's Avatar
CamiloA98
Just read the first timer FAQ posting. I ordered the NOS kit a few minutes ago. Will a 100 shot blow a stock VQ REVUP?? My car has 55,000 miles on it already and I just want to make sure that I don't kill my car...
Old Mar 15, 2010 | 06:02 PM
mgrotel's Avatar
mgrotel
colder plugs, pull timing, window switch
Old Mar 15, 2010 | 06:21 PM
Barnabas's Avatar
Barnabas
National Z Club President
get the kit with the 3 size nozzles start small break in the engine and then work your way up too the 100 shot.
Old Mar 15, 2010 | 06:58 PM
CamiloA98's Avatar
CamiloA98
Ok I obviously need to do more research and stop asking noobish questions... I bought the NOS kit on ebay with the 100 shot so I have no choice now.
Thanks guys.
Old Mar 15, 2010 | 07:00 PM
Barnabas's Avatar
Barnabas
what kit?? what company?? what brand?? what accessories??
Old Mar 15, 2010 | 09:20 PM
mgrotel's Avatar
mgrotel
to change the shot size, all you have to do is buy the appropriate fuel and nit jets
Old Mar 15, 2010 | 10:50 PM
CamiloA98's Avatar
CamiloA98
The wet NOS kit was $449 on ebay and included...
# 10LB NOS Hi Flow Blue Bottle (EMPTY)
# 10LB NOS Bottle Brackets Black
# NOS Bottle Nut Adapter 4an
# NOS Fogger
# NOS Nitrous Solenoid (Up to 150HP)
# NOS Fuel Solenoid
# NOS Nitrous Solenoid To Fogger Braided Line
# NOS Fuel Solenoid To Fogger Braided Line
# NOS Pedal Microswitch & Bracket
# NOS On/Off Switch
# NOS Stainless Braided Bottle Line
# High Pressure 5/16 Fuel Line & 3 Clamps
# Fuel Line Brass Connector (To Connect Fuel Line to Solenoid)
# NOS Wiring & Fuse Holder
# FREE VISION Motorworks 0-1500 PSI Nitrous Gauge and Adapter Kit
http://cgi.ebay.com/ebaymotors/03-04...item3ca2a539cf
but from my reading I see that I still need to buy...
  • bottle warmer
  • cold spark plugs
  • purge kit
One of the local shops said they would install it and tune it for $375.
If you guys know where to buy the parts that I need for cheap, please let me know...
Old Mar 15, 2010 | 10:53 PM
CamiloA98's Avatar
CamiloA98
Got it. Thanks.
Old Mar 16, 2010 | 08:13 AM
mgrotel's Avatar
mgrotel
instal and tune for 375? thats sounds pretty good to me, what did they say they would tune it with? utec? other?
purge kit isnt necessary, but nice to have
i would highly recommend getting a window switch as well to make sure you dont spray too low in the rpm range
Old Mar 16, 2010 | 09:43 AM
CamiloA98's Avatar
CamiloA98
The guy at the shop told me that they will tune the NOS kit in the shop but that with a 100 shot I dont need to tune my ecu... I guess their just going tune the fuel and air mix.
Purge kits are not necessary!!! That's perfect!! I read that they leaked nitrous. Now I might afford the window switch. Oh and the shop owner lowered the price for installation to 275.
Old Mar 16, 2010 | 10:31 AM
mgrotel's Avatar
mgrotel
just be careful, a 100 shot is right on that fine line of where you need to start pulling timing to be safe, i melted plugs with a 100 shot
Old Mar 16, 2010 | 10:38 AM
CamiloA98's Avatar
CamiloA98
Ok I just finished purchasing what I need,
  • NOS WOP/RPM Window Switch
  • the tank heater
  • cold spark plugs
Nothing to do now but wait for UPS. I opted out of buying a purge kit because I'm reaching the limit of my budget for this project. I may buy the purge kit later in the year. Cant wait to take it to the track!!
Old Mar 16, 2010 | 10:42 AM
CamiloA98's Avatar
CamiloA98
What type of spark plugs where you using?? How much HP to the wheels did you make?? Do you still have that setup?
Old Mar 16, 2010 | 11:03 AM
mgrotel's Avatar
mgrotel
i have one step colder ngk plugs, probably about 310-320 to the wheels, im an auto transmission, i still have the setup, however, i am fairly certain the melting was from high engine temps, causing preignition, not good. just installed a meth injection kit to keep temps down and have a utec on the car. now if i could only get someone on here to help me out with a map, i would be set, but no one wants to help
Old Mar 16, 2010 | 11:42 AM
Barnabas's Avatar
Barnabas
lets hope they know what they are talking about.
From what I know im pretty sure you need to
Ill let some of the experts chime in here
Old Mar 16, 2010 | 04:25 PM
BakaN20's Avatar
BakaN20
Blow down tube.
