Nitrous Oxide Too soon, jr.
Nitrous questions
Old Apr 27, 2010 | 01:44 PM
bluz370's Avatar
bluz370
Default Nitrous questions
Hey guys I am looking into nitrous currently. I have read up about what most people use on here and it seems like the wet shot is the preferred method. Is there a reason for this? Do the kits require you to use the schrader valve to get fuel? someone told me this is how they get the fuel for the line.
What is the main reason that people dont run a dry kit? Is it because you are not mixing the fuel with the shot?
If you only ran a small (75) shot, and tuned for a/f and plugs, would it make a difference if it was wet or dry? I understand the concept of nitrous just had these few questions. If there is a reason not to use a dry kit other than that I would love to hear it! thanks
Old Apr 27, 2010 | 03:29 PM
MREDDLE's Avatar
MREDDLE
First Wet kits are generally safer, if the correct fuel jets are used. I have seen cars use a 100shot dry. But, they run rich (lots of fuel) for this reason. I like to run fuel and nitrous as the gain is higher and its only an additional solinoid tapped into the fuel line before the FPR. Most nitous manufacturers have install insturctions on their websites. I hope this helps.
Old Apr 27, 2010 | 06:11 PM
Italianjoe1's Avatar
Italianjoe1
Wet kit makes tuning so much easier, and allows you to 'tune' the nitrous AFR separately from the base tune.
Old Apr 27, 2010 | 08:45 PM
drivessidewayz's Avatar
drivessidewayz
Imo if you're going wet pick up a fuel rail/line adaptor to simplify the install. I dunno if anyone else carries it, but Dynotune is the cheapest of anyone I've found and actually sells a 350 single and dual intake wet kit with this adaptor.
Keep in mind you posted this in the 350z Nitrous section.
Old Apr 28, 2010 | 08:36 PM
ironx's Avatar
ironx
here is an example this is my setup that a friend helped me with this is a dyno tune system
fuel tap
Old Apr 29, 2010 | 09:08 AM
bluz370's Avatar
bluz370
So you dont use the schrader valve you use the fuel rail/line adapter? When I ran nitrous in my old f body people used dry shots and just tapped the fuel from the schrader valve making one of the pistons really lean out bc it was stealing the injectors fuel. Im assuming this isnt the case on the dynotune set up? Thanks for the relplies! I will be doing this on a 370, so I want to make sure I do it as safe as possible.
Old Apr 29, 2010 | 08:55 PM
Italianjoe1
There isn't a test port on the rail on the Z's. My old Cobalt and my dad's 4.8L vortec both have one and I used that as the fuel pickup with on problems.
Old Apr 29, 2010 | 09:13 PM
jbaker1121's Avatar
jbaker1121
I want nitrous on my FX
Old Apr 30, 2010 | 10:08 PM
drivessidewayz
Originally Posted by jbaker1121
i want nitrous on my fx
do eeeeeeet
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
