Nitrous Oxide Too soon, jr.
Just sprayed on the dyno. Pig rich as can be.
Old May 4, 2010 | 03:51 PM
izit26's Avatar
izit26
Default Just sprayed on the dyno. Pig rich as can be.
The guy at the dyno shop sent me winpep 7 along with my runs from 2 springs and today. I guess I should have expected the numbers based on my 115.5 trap speed black bumper.
I don't know if you guys prefer uncorrected or SAE numbers, but I'll post the higher one to feel good about myself. (uncorrected)
ALL motor:
269.62hp
242.11tq
Spray (950psi bottle pressure):
362.04hp
374.31tq
AFR hit 12.0 @ 4200rpm and dropped from there. It bottomed out @ 5800. I'm leaving a lot of power on the table.
All runs made on pump gas with 2 degrees of timing pulled across the board and LFR6a coppers installed. I've attached the 2 runs for dissection.
Old May 4, 2010 | 04:58 PM
snaponbrian's Avatar
snaponbrian
what are you doing to pull the timing ?
Old May 4, 2010 | 05:55 PM
What is the story on the torque? Sudden drop at 5,000 RPM?
Old May 4, 2010 | 05:57 PM
03threefiftyz's Avatar
03threefiftyz
Too much fuel......damn near washing the motor out with a/f like that.
Old May 4, 2010 | 05:59 PM
plumpzz's Avatar
plumpzz
Ratio of Nitrous to fuel decreases as RPM goes up (more fuel added per unit time) so there is less oxygen for the reaction. Thus, with most linear nitrous setups, you get a big torque loss as RPMs go up.
Old May 4, 2010 | 06:09 PM
izit26's Avatar
izit26
Factory retard. Just the opposite of having them add more. My understanding is that they can go 2* in either direction. It gives me a warm fuzzy feeling.
Old May 4, 2010 | 06:12 PM
izit26's Avatar
izit26
Hella fuel. I'm running .002 sized larger jets than recommended. I'm really thinking about adjusting that. I'm just about done with the "more with less" path. I just want one 11.9 pass on an open diff with no tune other than reading plugs and the occasional dyno.
Old May 4, 2010 | 06:14 PM
izit26's Avatar
izit26
That begs the question. Do I dial back the fuel and risk an even bigger lean spike at activation, or add a 35hp 2nd stage and get up around 400rwhp?
Old May 4, 2010 | 07:15 PM
BakaN20's Avatar
BakaN20
I am guessing that you are getting the uneven mixture due to nitrous pressure drop with consistent use throughout the run?
Old May 5, 2010 | 08:21 AM
absurdparadox's Avatar
absurdparadox
Yeah, thats always been my thought... people are saying that the Z will handle a 125hp shot fine, and usually, the danger with nitrous is at lower rpm's, due to massive torque increase.
Therefore, people should run a 175hp progressive shot :-D.
Old May 5, 2010 | 08:38 AM
zerostyle's Avatar
zerostyle
OP try 200 shot to lean it out.. Get a little over 400whp safely.
Old May 5, 2010 | 08:40 AM
03threefiftyz
200 shot and safely don't belong in the same reply. He just needs a real tune on the shot he has (along with properly sized fuel jets), and he will be on his way.
Old May 5, 2010 | 09:21 AM
plumpzz's Avatar
plumpzz
You would pull timing in the early phases of nitrous introduction and get more aggressive as the ratio of nitrous to fuel per time decreases. I dont have any expierience in tuning cars, but from what I understand in motor tuning and control theory in general, thats what I would try.
Old May 5, 2010 | 09:40 AM
ArcticT's Avatar
ArcticT
What size jets are you running? I think a progressive 175 shot sounds like a great idea! You should try that and let me know how it goes.
Old May 5, 2010 | 04:47 PM
izit26's Avatar
izit26
I run .061n .036f. This is my last season of experimentation. Next is suspension.
Old May 6, 2010 | 06:58 AM
ArcticT's Avatar
ArcticT
Wow, that is a big shot for -2* and pump gas. So I guess a 34 fuel jet would probably work a little better up high but that will be pretty scary right at the hit. I got the progressive controller/window switch from Dynotune not really planning on using the progressive part of it, but if my dyno sheet looks anything like this one I will most likely run it progressive.
Old May 26, 2010 | 06:25 PM
mgrotel's Avatar
mgrotel
get a used utec and pull fuel on the top end
Old May 26, 2010 | 06:39 PM
mgrotel's Avatar
mgrotel
what a/f are you wanting to be at on spray?
Old Jun 2, 2010 | 03:00 PM
mgrotel's Avatar
mgrotel
bump
Old Jun 2, 2010 | 07:02 PM
binder's Avatar
binder
by the sound of it you have no tuning software and aren't tuning the ecu then.
Here's the kicker, your tip in (lean spot) will always occur when you jam the gas unless you tune the ecu to fix that. So here's the smart thing, set your window switch on the nitrous to engage AFTER your initial tip in. So your tip in will happen at 3k rpms and nitrous hits at 3.5k therefore giving your engine 500 rpms to adjust for the big rush of air before you blast it with nitrous That will help the tip in lean condition.
because of that, i would also pull back the jetting big time.
if you are drag racing the question is why have your nitrous engage so low? when you shift you aren't going to be anywhere near 3k range so just move the window switch up and you can pull more fuel since you're leaner down lower rpms.
