Nitrous Oxide Too soon, jr.
nitrous question
Old May 19, 2011 | 09:02 PM
smaqaho's Avatar
smaqaho
Default nitrous question
i just recently installed a zex kit on my 08 and am curious about a/f ratios.
at around 900-950 lbs of bottle pressure my a/f is around 10.5-11. should i swap fuel pills or nitrous pills? i could go with a little less fuel in the intake to lean it out some and maybe get around 11.5-12 or swap nitrous pills for the same effect and more power. zex recommends pulling 4* of timing on 100 shots or more though. the car runs good now with no detonation but im just curious as to what others are running.
Old May 19, 2011 | 10:09 PM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
For safety, I'd recommend changing your fuel pills to adjust your AFR. However, if you're spraying under 100 shot, then I guess you could try going slightly bigger on your nitrous jets. When you're fine tuning it (and not drastically changing the jet size) using the jets to achieve minor changes in the AFR, it really doesn't matter since you're only moving up or down by small increments, like using a step or two smaller fuel jet, in your example.
BTW, as a rule of thumb, you want to retard 2º of timing for every 50 shot.
Old May 19, 2011 | 10:25 PM
smaqaho's Avatar
smaqaho
well will i gain power by switching the fuel pills? zex (as well as what i read on forums) claim the power is gained more from fuel than nitrous. ideally i would like to have an efficient 75 shot setup and then increasing to a 150 shot after i get a dyno tune
Old May 20, 2011 | 06:55 AM
rtiid22's Avatar
rtiid22
According to ZEX you're going to need an aftermarket fuel pump when going above 100 shot.. FYI
Old May 20, 2011 | 09:01 AM
3hree5ive0ero
Retired Admin
You gain power from fine tuning your AFR, either via fuel or the nitrous. Again, I recommend that you mess around with the fuel jets in the smallest increments possible, even though doing the same with nitrous will yield similar results.
Also, you don't need an aftermarket fuel pump for 150 shot. Many of the nitrous guys have sprayed 150 as-is + a tune.
Old May 20, 2011 | 03:03 PM
smaqaho's Avatar
smaqaho
i think thats what ill do. right now im running a .016 fuel jet (if im not mistaken) and i think i have a smaller size in the bag. that would make a nice little saturday afternoon project.
im scared of going over 75 on a stock tune. once i get a dyno tune for the nitrous i will up the shot to either a 125 or 150, whichever the HR motor can hold safely on a good tune
Old May 21, 2011 | 10:48 AM
3hree5ive0ero
Retired Admin
Just making sure, you have 2 foggers (both with same jet sizes) on your HR, correct?
Old May 21, 2011 | 11:07 AM
John1006's Avatar
John1006
Quick question, i have a a lean safety switch on my microedge for nitrous. What should i set it at to shut off the nitrous?
Old May 21, 2011 | 11:53 AM
3hree5ive0ero
Retired Admin
You want to stay in the 11s ideally, but sometimes you will see some lean spikes. I don't know if Microedge accounts for those, but I'd personally set it around 12.
Old May 21, 2011 | 12:26 PM
smaqaho's Avatar
smaqaho
yes. i have one nozzle with a fuel line and nitrous line in each intake. and obviously both intakes have the same fuel and same nitrous pills in each line
this is the kit i have
http://www.zex.com/zx/nitrous-system...trous-kit.html
plus zex's window switch
http://www.zex.com/zx/nitrous-add-on...ml?___store=zx
Old Jul 17, 2011 | 03:31 PM
CTZ860's Avatar
CTZ860
Pardon my noob question but what are these pills?
I just read through the whole introductory thread and I did not see any info. relating to these "pills".
Thanks^^
Old Jul 17, 2011 | 06:16 PM
3hree5ive0ero
Retired Admin
Pills = jets
Old Jul 19, 2011 | 09:38 AM
CTZ860's Avatar
CTZ860
Kkk andthe jets are guna be ur 50 shot, 75 shot, 100 shot, etc. Etc... Correct?
Old Jul 19, 2011 | 09:39 AM
3hree5ive0ero
Retired Admin
The sizes of the nitrous and fuel when matched correctly to your particular application is what determines the size of your "shot."
Old Jul 19, 2011 | 11:07 AM
John1006's Avatar
John1006
3hree5ive0ero is always so helpful lol
Old Jul 26, 2011 | 03:10 PM
mgrotel's Avatar
mgrotel
to add to the already good info you got from others here, the lean spikes can happen, and usually the system will allow you to set a predetermined time limit to allow for those spikes. for example, if you set the limit to 0.5 seconds and the a/f ratio to 12:1, then once it sees an a/f ratio above 12:1 for more than half of a second, it will cut power. this is how you can allow for the lean spikes.
Old Jul 26, 2011 | 05:56 PM
John1006's Avatar
John1006
Ok thanks. I was looking into that now. Thanks for all the help guys.
Old Jul 26, 2011 | 06:27 PM
Italianjoe1's Avatar
Italianjoe1
My car gets a pretty bad lean spike on the initial activation of the system, but once it's running the a/f's are dead on, same as all-motor with around 900psi bottle pressure. I'm holding upper 11's and the car pulls really strong.
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
