Nitrous Oxide Too soon, jr.
Q16 straight into gas tank on a single fogger ?
Old Oct 11, 2012 | 08:29 AM
Taz394's Avatar
Taz394
Default Q16 straight into gas tank on a single fogger ?
Anyone here ever did Q16 straight into the tank and sprayed a shot ?
considering doing a 150 shot with timing retarded and just pour Q16 into the gas tank
i am aware the 02's will be toast but anything else ? or should i be just fine ?
Old Oct 11, 2012 | 11:22 AM
thatv35guy's Avatar
thatv35guy
I thought you had to tune your car for Q16… C16 should be fine though IIRC.
Old Nov 2, 2012 | 12:27 PM
Old School's Avatar
Old School
Shift_Boost
You can run 150 shot on 93 with 2-4 degrees taken out. If you run Q16, you could potentially run more nitrous and more timing. I'd run C16 though...easier on the car
Old Nov 4, 2012 | 09:19 PM
juicinjake's Avatar
juicinjake
this topic interested me so i did some research on this. large gains between c16 and q16 (which is oxygenated) are going to come from larger drag race motors that take in a lot of fuel. i saw something like a 40hp gain from q16 over c16 on an 1100hp combination. on low output motors like ours the gains would be small... but thats ok. the point of running either one with nitrous would be to allow more nitrous and more timing, which would make large, noticable differences and be worth the effort no matter which fuel you chose... retune or not... hell uprev has 4 maps... na pump, nitrous pump, na race, nitrous race... seems to be tailored to that imo.
liqalu04
Jan 2, 2022 12:58 PM
Depravity
Oct 1, 2015 04:49 PM
