Nitrous Oxide Too soon, jr.
NOS on stock vq35de ?
Old Jul 12, 2013 | 02:11 PM
garym's Avatar
garym
I've been running 150HP shot in my '06 since 2008. Still runs strong.
I have the 5AT also. The trick is to shift earlier. Nitrous thins out in the higher RPM's because the A/F flow increases, but the nitrous flow stays the same throughout the rpm range, so you loose power in the higher RPM's.
By the looks of your graphs, you want to shift by 5000rpm. I shift mine about 5300-5500. I have my window switch set to shut off at 5800 just to be sure I don't over-rev it. You're 1/4 mile times will improve once you figure out that shift points based of your max HP range.
Old Dec 28, 2017 | 02:21 PM
Rocketz33's Avatar
Rocketz33
Originally Posted by 2004Black350z
Wet shots will blow motor. Dry is the way to go. I beat all the locals with 150 dry shot of Nos. Pulled on vettes
Which Dry shot kit are u running. im wanting to run a 50 dry shot on my z if you could let me know i would really appreciate it.
Old Dec 28, 2017 | 05:38 PM
BakaN20's Avatar
BakaN20
He was being sarcastic.
Edelbrock is the only one who made a dry kit I believe.
https://www.summitracing.com/parts/e...iew/model/350z
https://my350z.com/forum/nitrous-oxi...trous-kit.html
http://www.superstreetonline.com/how...brock-nitrous/
http://www.superstreetonline.com/how...s-nissan-350z/
Just go with a wet shot and call it a day.
Old Dec 29, 2017 | 12:37 PM
CK_32's Avatar
CK_32
If you have to ask, take it to a shop to explain or do it for you.
If you don't care if you blow or risk your motor. Just do it and see what happens.
