Nitrous Oxide Too soon, jr.
Upped my shot. Dyno post inside
Old Sep 30, 2013 | 05:29 PM
2bad240's Avatar
2bad240
Originally Posted by Italianjoe1
I'm sure you're aware, but a 200whp gain on juice will amount to almost a 250 shot
Sick, sick power. I hope it holds together, that's a lot to whack through a stock bottom end.
How many passes are you getting from a bottle? Running a single 10lb or more?
The jetting is supposed to be 215 crank hp. 185 whp. Which is pretty much exactly what I gained. I'm staying with the same jetting for now but looking to gain high rpm power and more top end on the track with the changes to the setup I will be making.
I can make 4 consistent passes right now then it starts dropping off a bit. But I put 12 pounds in my 10 pound bottles and after purging the main line and making 4 runs and then purging off the excess off the main line and removing the bottle it usually weighs in around 19 pounds. So approximately 4 pounds left in the bottle. I figure I'm using somewhere around 1.5 pounds per pass.
And my main line is way to long it's somewhere around 16ft. Which is one of the things I will be replacing with the upcoming changes.
Old Oct 1, 2013 | 12:22 PM
Old Rice's Avatar
Old Rice
^^^^Ahhh..if I could spend your money on the changes I would buy:
*S1\S2 or bigger cam, something with less Intk\Exh overlap (so I read out there is good for spray) will compliment those LTHs you run. If you do bigger cams, do mine as well cuz I am out of my skill-set there lol.
*NANO to get the most out of the bottles, keep ur heater to overthrottle the n2o psi as you do.
*shorter main feed using -6an hose
*PG-CNTLR+window switch to move the wtq into the mid to higher rpm ranges or 2-stage it
*Larger .375 N2O solenoid
*15 or 20Lb bottle for more passes
sorry I was just dreaming there....what delivery upgrades you considering?
Old Oct 1, 2013 | 04:41 PM
2bad240's Avatar
2bad240
Was testing to see what my pressure drop off was like. I was dropping 300psi on a 1/4 pass. rolling start 10-130. It only dropped 50psi after upgrading from a 20foot 4an mainline to a 9foot 6an line and running dual bottles.
Oh and my collectors came in hope to install tomorrow
Old Oct 1, 2013 | 06:41 PM
ssblugsr's Avatar
ssblugsr
^ very nice, loving that collector
Old Oct 2, 2013 | 03:10 PM
2bad240's Avatar
2bad240
Welded on my v bands this afternoon
Old Oct 3, 2013 | 06:40 AM
djamps's Avatar
djamps
Dumb question, but with your dry setup how does the ECU know you're spraying and when to dump more fuel when the spray is post-MAF? I guess you've got to tune a particular map 'assuming' spray?
Old Oct 3, 2013 | 08:25 AM
NFGZ's Avatar
NFGZ
Man here you are spraying 180 dry shot, and I'm paranoid to spray 50-75 wet shot...
Old Oct 3, 2013 | 11:20 AM
2bad240's Avatar
2bad240
Yea I have a tune that adds the fuel at a certain point that's about 90% throttle. It's actually pretty awesome I can drive the car with no issues as long as I stay under 90%. Them when I want to spray I just flip a switch and when I hit the wot switch it comes alive
Old Oct 3, 2013 | 11:46 AM
Nismo1182's Avatar
Nismo1182
-6 all the way to the solenoid?
Old Oct 3, 2013 | 12:15 PM
iideadeyeii's Avatar
iideadeyeii
SAF-C??
Old Oct 3, 2013 | 12:29 PM
2bad240's Avatar
2bad240
Yea -6 to the solenoid. And I'm running uprev
Old Oct 3, 2013 | 04:48 PM
2bad240's Avatar
2bad240
Got the headers welded all up
Old Oct 4, 2013 | 03:10 AM
kellam's Avatar
kellam
stupid question. what would the reason be to replace the 2 bolt flanges?
looks very cool though
Old Oct 4, 2013 | 03:51 AM
2bad240's Avatar
2bad240
They never really sealed completely. And I figured if I was gonna replace the collector I might as well go with something cool
Old Oct 4, 2013 | 08:25 AM
ssblugsr's Avatar
ssblugsr
Hey any thought about putting exhaust wrap on now while its off.
Old Oct 4, 2013 | 07:06 PM
Italianjoe1's Avatar
Italianjoe1
What drag tires are you using now?
Old Oct 4, 2013 | 07:39 PM
2bad240's Avatar
2bad240
M&h dot racemaster 26x10.5
Old Oct 5, 2013 | 04:13 AM
  #38
OldManZ350's Avatar
OldManZ350
Are you running with open headers? IF not, what's your exhaust like?
Thanks,
TimRod
Originally Posted by 2bad240
Not the best vid but you can see it getting sideways off the line
http://youtu.be/ds4k5hp4btw
Old Oct 5, 2013 | 04:16 AM
  #39
2bad240's Avatar
2bad240
eBay longtubes with merge collectors welded on with v bands going to a AAM 3" y pipe. Going to a 3" single I custom made from a invidia made for a Evo X
Old Oct 5, 2013 | 04:33 AM
  #40
2bad240's Avatar
2bad240
Here is the vid from the pass I had to lift
http://youtu.be/gssppTX5D0c
