Nitrous Oxide Too soon, jr.
CarChip E/X
Old Jan 29, 2004 | 04:26 PM
cyberz350's Avatar
cyberz350
Default CarChip E/X
http://www.davisnet.com/drive/produc....asp?pnum=8220
Just curious if you guys had any thoughts or experience with this product. Might be useful in logging o2 readings with nitrous on a run.
Old Jan 29, 2004 | 05:25 PM
cyberz350's Avatar
cyberz350
Here's a better look at it
http://www.troublecodes.net/articles/carchip/
http://www.thecarchip.com/ccex.asp
Old Jan 29, 2004 | 05:39 PM
cyberz350's Avatar
cyberz350
Kay, this is probably the most useless post ever, I was researching the sample rate of this product. It's fastest sample rate is once every 5 seconds. And seeing as the quarter mile is only about 13-14 seconds for us semi stock Zs, this product would only record about 3 times during the run. Not very useful.
I currently use the pocketlogger
www.pocketlogger.com
and it records 6 samples per second per parameter. A lot more useful than than once every 5 seconds. I just thought I had found something better. Oh well.
Old Jan 29, 2004 | 07:59 PM
roark's Avatar
roark
CarChip is really designed as a long term logger. I use mine to log stats over time so I can see what's going on with things like timing, A/F, etc. It's not a good tool for mapping short bursts (e.g. 1/4 mile runs)
So, while the pocket logger is great for getting lots of data over a short period of time, the CarChip takes fewer samples, but can record months (with the E/X model) of daily driving.
The original idea is to keep track of how the car is being driven, (for example, your teenagers.) I use mine to log milage I use for work.
Old Jan 29, 2004 | 09:24 PM
cyberz350's Avatar
cyberz350
Yea, thats what I figured. It sounded real good at first, but like you said, not good for 1/4 logs. I can see how it could be useful though if you let other people drive your car.
Old Feb 27, 2004 | 09:14 PM
alex30327's Avatar
alex30327
All these thing are worthless without a wideband O2 sensor. The stock sensors are only good for stochiometry (spelling?) readings.
You need a sensor that can give accurate reading at WOT.
backagain
Feb 14, 2005 02:47 AM
peptidbond
Feb 6, 2004 01:55 PM
peptidbond
Dec 30, 2003 08:21 PM
