Nitrous Oxide Too soon, jr.
Nitrous
Old Feb 21, 2004 | 02:05 PM
Recon350's Avatar
Recon350
Default Nitrous
At the moment my car is completally stock, I was wondering what upgrades i must to have before getting a nitrous system installed?
Old Feb 21, 2004 | 02:40 PM
cyberz350's Avatar
cyberz350
Totally dependent on how far you plan on taking your ride. Up to 150 I believe all you need is colder plugs.
Old Feb 21, 2004 | 02:52 PM
Recon350's Avatar
Recon350
was planning on getting the Vex wet system either 75 of 100 shot
Old Feb 21, 2004 | 02:54 PM
Recon350's Avatar
Recon350
I was just curious because i know someone who put a 100 shot of nos in his G and blew his ecu chip so he had to upgrade to the technosquare chip. Is that necessary?
Old Feb 21, 2004 | 02:59 PM
Recon350's Avatar
Recon350
Zex not vex.....lolol
Old Feb 21, 2004 | 03:07 PM
infidsg35's Avatar
infidsg35
Dont see how thats possible to "blow the ECU".. 100 shot is fine but get colder plugs and dyno, dyno, dyno!!! A/F ratio is MOST inportant with Nitrous...
Old Feb 21, 2004 | 03:58 PM
Recon350's Avatar
Recon350
Where in Nj can i dyno my car??
Old Feb 21, 2004 | 04:19 PM
12SecZ's Avatar
12SecZ
TS flashes your stock ECU they do not replace it. If a 'chip were blown' a reflash wouldn't save it. Your friend is full of cockita
fluidz's Avatar
fluidz
here is a slip with 55 jets from a zex kit, a/f ratios are almost identical to stock motor a/f ratios...........no plugs just nos at 55
Old Feb 21, 2004 | 06:52 PM
Recon350's Avatar
Recon350
What are the A/F ratios on a stock 350z?
Old Feb 21, 2004 | 08:49 PM
fluidz's Avatar
fluidz
well they all vary, i was told by one person that my a/f ratios are the lowest he has seen on a stock motor at 6,200 rpm, ive seen some vary from mine as low as 11.8 at 6,200 rpm to 13.2 at 6,200 rpm on other cars............if you go with nos, you must dyno if your gonna go higher than 55 jets in my opinion to be safe, just my 2 cents
Old Feb 22, 2004 | 10:47 AM
12SecZ's Avatar
12SecZ
I've seen N/A stock go all the way up to 14.
Old Feb 22, 2004 | 06:04 PM
TD30's Avatar
TD30
Does anyone know what effect high altitude has on the A/F ratio?
Old Feb 22, 2004 | 07:57 PM
fluidz's Avatar
fluidz
Runs richer i think due to less oxygen, but the ecu probably adjust to compensate..........that is my final answer!......lol
eskimo
Nitrous Oxide
282
Jan 30, 2011 03:22 PM
amg_diananet
Nitrous Oxide
Sep 19, 2003 08:30 PM
cyberz350
Nitrous Oxide
Jun 20, 2003 06:05 PM
EmpiricalGMan
May 26, 2003 06:39 PM
