Nitrous Oxide Too soon, jr.
SPX? Does pulling the valve stem out of it work?
Old Apr 20, 2004 | 03:48 PM
Z YA LTR's Avatar
Z YA LTR
Question SPX? Does pulling the valve stem out of it work?
Or do I need to buy the new fitting?
Could anyone that has the adapter tell me how long the spacers are that you used.
Also, whats a webpage that sells them(spx fuel adapters)? Thanks!
--Josh
Old Apr 21, 2004 | 05:32 AM
tig488's Avatar
tig488
yeah you have to pull the stem out for it to work, the stem is there for the service department to hook their fuel pressure tester to.
Old Apr 21, 2004 | 09:16 AM
Z YA LTR's Avatar
Z YA LTR
Well I meant does it work just fine like that. I mean does the pressure stay cosistent? Or should I go ahead and just buy the fitting to allow proper fuel flow.
--Josh
Old Apr 21, 2004 | 11:34 AM
tig488's Avatar
tig488
oh, my zex came with the fitting, so i just changed it out, as far as the spacers go, i didnt use them, i just bought some bolts that were a little long and was gonna use them without spacers and just tightened them down to where i thought they were tight, i read where somebody else thought the spacers caused it to leak because you couldnt tighten it down enough.
Old Apr 21, 2004 | 12:32 PM
ZU L8R's Avatar
ZU L8R
Viper Sellout
What's the best way to get the middle stem out? I'm sitting here looking @ mine and it looks like it screws in.
Old Apr 21, 2004 | 01:05 PM
cyberz350's Avatar
cyberz350
I read that someone used two pins to take it out.
Old Apr 21, 2004 | 01:48 PM
Z YA LTR's Avatar
Z YA LTR
Where can I buy the spx adapter?
--Josh
Old Apr 21, 2004 | 05:41 PM
tig488's Avatar
tig488
well, there is a tool specially made for it, it has 2 prongs on it and slides over the little pin, i had one from my old bmx days, it just slides over it and unscrew, it isnt tight, so if you have some small needlenose pliers try them
Old Apr 21, 2004 | 05:46 PM
ZU L8R's Avatar
ZU L8R
Viper Sellout
cool, I'll give that a try
Old Apr 21, 2004 | 05:50 PM
Z YA LTR's Avatar
Z YA LTR
Im sorry, I didnt mean the valve stem remover I meant the actual SPX fuel adapter. I cant seem to find a site that sells them. I can remove the stem with a small flat head screw driver.
--Josh
MAsSIVrOOM
Oct 20, 2023 10:50 AM
Fixxxercask
Nov 9, 2015 11:10 AM
