Nitrous Oxide Too soon, jr.
Compression and No2
Old Sep 28, 2004 | 06:39 AM
redline350ZZ's Avatar
redline350ZZ
Default Compression and No2
I was wondering if the 11.5-1 compression Forged Pistons and No2 would be a bad Idea?????
My ideal thing would be have the high compression with cam work for maximum N/A preformance daily...... but still be able to run a 75-100 shot for track use???????
This route is cheaper than a turbo and hopefully will provide a better engine life.......
Old Sep 28, 2004 | 08:48 AM
350_Z's Avatar
350_Z
It's never a good idea to combine high compression with a form of forced Induction. You are going to have to pick one route or the other. If you want to stay N/A go with Cams/Pistons/Headwork. If you want Forced induction such as Nitrous just go with Bolt-ons/Nitrous, you could also add cams to this setup.
Old Oct 5, 2004 | 05:25 AM
350Z-VDC=Bandit's Avatar
350Z-VDC=Bandit
depends what sacrifices you can make as far as octane of the fuel u run and how long you want the motor to last.
I was lookin at the AEBS stroker kit that has to choices an 11.0 and 11.5 I am leaning to the 11.0 I can run the allmotor and then if I "take it to the track" all I have to do is run it to 1/4 tank and drop in some octane booster with mmt and im good to go for a 125-150 shot....A lot of the LS-1 guys running nitrous are at an 11.0 or higher so its not the compresion but the fuel that your burnin when you hit that **** that is going to make the biggest difference. PING IS BAD
Later,
Scott
Old Oct 5, 2004 | 03:23 PM
kaj75's Avatar
kaj75
Default Re: Compression and No2
We are thinging alike. I am also thinking about doing this I am looking at fully built motors and I am really considering going this route I figure if I can get to 330 to the wheels on motor which I believe is achievable then throw a 150 -200 shot on there it should be fine. With good rods and good enternals I just can't see why the motor couldnt handle that kind of hp. As long as you have the proper air to fuel ratio it should be fine.
bcoffee20
Nov 19, 2015 06:39 PM
bneumann
Oct 7, 2015 12:16 PM
B Esquire
Sep 24, 2015 07:52 AM
ThreeFiveZero Z
Sep 12, 2015 04:33 PM
