FS: Invidia Gemini Catback, Test Pipes, Rays Wheels
Old Apr 23, 2012 | 08:51 PM
TongMan's Avatar
TongMan
Default Invidia Gemini Catback, Test Pipes, Rays Wheels
All SOLD!!
Old Apr 25, 2012 | 11:42 AM
dphoenix's Avatar
dphoenix
do you know the weight for rear 19x10?
Old Apr 25, 2012 | 11:46 AM
Junkster's Avatar
Junkster
Curious to know if the TP's work on 07-08 350?
Old Apr 25, 2012 | 12:02 PM
SE5spd's Avatar
SE5spd
they do not.
Old Apr 25, 2012 | 01:10 PM
TongMan's Avatar
TongMan
I believe they are 28lbs each. Someone can correct me if I'm wrong.
Yea, I don't know.
Old Apr 26, 2012 | 12:07 PM
TongMan's Avatar
TongMan
Still available guys.
Old Apr 26, 2012 | 01:01 PM
Cali-Darkness's Avatar
Cali-Darkness
Originally Posted by SE5spd
they do not.
Are you sure? Our cats are the same last I checked. They should mount right up. I have seen it done with HFC from a 07-08 on a 370Z.
Old Apr 26, 2012 | 01:04 PM
SE5spd's Avatar
SE5spd
I know the headers on 3.5 and 3.7 are different and isn't that the determining factor?
Isn't that the reason DE and HR cats are different?
Could be wrong
Old Apr 26, 2012 | 01:11 PM
singh's Avatar
singh
_______________
350z HR ('07-'09) and 370z share the same cats and therefore the test pipes should fit both cars
Old Apr 26, 2012 | 01:21 PM
Cali-Darkness
^+1
Could be wrong
No, the HR & DE have different bolt pattern where the exhaust manifold & cat meet.
Junkster would be able to use the TP's on his HR 350Z. Might need the Check Engine Light fix, there is a thread in the HR section on how to make the o2 adapter for the J bend.
Old Apr 26, 2012 | 01:31 PM
SE5spd's Avatar
SE5spd
Well then I guess I was wrong. Does anyone know if 370 and HR Z exhaust are interchangeable?
Old Apr 26, 2012 | 02:14 PM
TongMan's Avatar
TongMan
No check engine light with my test pipes. It comes with the extended J bungs already welded on.
Old Apr 27, 2012 | 07:02 AM
Junkster's Avatar
Junkster
I am actually working out a deal right now with someone that wants my HFC's so let me get back to you on that. Im trying to work out a trade cause in reality i need to get a set of stock cats AND test pipes lol
Originally Posted by Cali-Darkness
^+1
After some research i found this is indeed true, His already have the J bends but i already had to do the spark plug defouler with steel wool trick on my Stillen HFC's im assuming it cant be any more different on the Invidia TP's
Old Apr 30, 2012 | 02:08 PM
TongMan's Avatar
TongMan
Still available for pickup guys. Anyone local interested? It has been confirmed by several HR 350z owners that the test pipes will fit no problem.
Old May 1, 2012 | 06:38 AM
Junkster's Avatar
Junkster
^ i am interested in the TP's just trying to figure out a deal with someone else on selling my Stillen HFC's so i can get the money for the TP's haha...ill keep you posted, been busy with finals coming up and stuff blahh
Old May 1, 2012 | 06:41 AM
SE5spd's Avatar
SE5spd
Finals FTL
Mine are soon
Old May 1, 2012 | 11:28 AM
albertsZ's Avatar
albertsZ
Will the invidia exhaust fit on an 06 de 350z?
Old May 1, 2012 | 12:49 PM
TongMan's Avatar
TongMan
^^^ I don't know. Anyone else can chime in?
Old May 1, 2012 | 01:30 PM
Cali-Darkness
Not if it is off a 370Z
Old May 7, 2012 | 08:00 PM
fhumphrey04's Avatar
fhumphrey04
Where in Cali are you? I'm going to be in sac in a few weeks.
