then ill stand corrected when it doesn't break 300 : P
good luck. You can go the same dyno where 350zlowlife dynoed and put down 370whp.
Go to the drift office. Bob calibrates his dyno precisely. He's good.
with the set up im running on it atm should be running at about 330-350
not sure the increase from the cobb ecu but everything else would put you at around 300 at the wheels. walter put down 280whp (281 iirc?) from his 07 stock and i doubt your 08 has any more power.
edit: just checked cobb's site and the max you get from their ecu is 8.5% hp increase, which would be around 23-30 depending on if that number is pre- or post- intake/exhaust though.
Reason: cobb tuning site
i saw inflated numbers from that dyno. Guys do some research on a stock HR #'s and you will see. 260-270whp is the norm for the HR. anything over that is high. and Stop reading what people claim
they hadn't mapped a 08 base yet and the computers in the car have small variances apparently and the ecu wouldn't work with the touring stage 2 map. After i downloaded the information onto it and mailed it back to them i had to wait another 2 weeks for them to make the maps for it and mail it back. Since i had to wait so long they did a 3rd map for free that's "stage 2+" that is better performance than the average stage 2 map for the set up I'm currently running. according to them anyways
not saying i don't believe you 350zimo but it "should" be running at 330 ish" if what cobb said was correct
did you look at the threads i posted?
The highest horse power HR 350z is putting down 318whp 264 wtq. A a full bolt on G37 put down 344whp. All these cars are with sort of a custom tune, whereas you get the generic one, even if the tuner claims they made it specially for you.
if it costs $$ I'm broke waiting for a free dyno day some where, just bought some paint and did my grille and doorhandles. also bought some lowering springs and sway bars so I'm like tapped lol
