lsd into base?
Old Jan 23, 2010 | 10:20 AM
ace32x's Avatar
ace32x
Default lsd into base?
is there a pumkin that just drops in the open end base model or will i need to go buy viscous axles to get this to work correctly? putting in a kaaz 2way
Old Jan 24, 2010 | 04:31 PM
killa.beez33's Avatar
killa.beez33
Nice choice on LSD. As for the axles, I am not sure. haha. Honestly the stock VLSD on the Z sucks IMO, it only works when it wants to.
Old Jan 24, 2010 | 10:17 PM
Z33VQ35's Avatar
Z33VQ35
I have a base and put in Nismo LSD pro. You can take it to Diff specialist and they will put it in for you. I put it in with my brother and had a specialist checked on it. You pretty much replace oem gears with your lsd. It's pretty simple. I am very happy to get rid of fury of "One Tire Fire!". All the popping noise are annoying tho. Good luck..
Old Jan 24, 2010 | 11:05 PM
abui01's Avatar
abui01
Get a Quaiffe LSD, it's the only aftermarket one that's gear driven (zero noise/chatter) and drops directly into the base pumpkin.
Old Jan 27, 2010 | 06:18 PM
HATED1's Avatar
HATED1
you need to buy the different axles to fit the kaaz lsd, no way around it, some say it might work without buying it, but their wrong. If you get the Nismo lsd pro like i have and the poster above, it is just drop in, only way to get nismo though is used, currently discontinued. Quaife is good depending what you want it for, if your thinking of drifting get the kaaz, tomei, or nismo. Cheaper bet would be nismo.
Old Jan 27, 2010 | 06:46 PM
ace32x's Avatar
ace32x
i got the kaaz and it was $80 less than the nismo only payed 1050 for it, and with this http://www.z1auto.com/prodmore.asp?m...ne&prodid=3438 (bottom of the page they make a kit for fitting it into the stock base pumkin) so alot cheaper than paying 2k for new axles in the rear! for future reference if any 1 else decides to do this
Old Jan 27, 2010 | 11:58 PM
350Zimo's Avatar
350Zimo
Ok. All LSD's are designed to fit in your stock pumpkin. In fact the stock pumpkin is no different than the one with the VLSD. The axels are the same. If you are going TT, you should upgrade the axels while the diff is out and the lsd being installed. You will save bunch of money. if you need anyone to do the job cheaper, let me know. Ray in woodinville will beat any shops' quote. Besides he's well known among the locals and he's meticulous!
Old Jan 28, 2010 | 12:00 AM
jjaujou's Avatar
jjaujou
And here I was all ready to read a thread about an army brat with a contraband transportation issue.
Old Jan 28, 2010 | 02:27 PM
ace32x's Avatar
ace32x
everything cant be the same if lsd's wont go into the base with out viscous axles or the conversion kit z1 offers. and drift office is doing it for $80 so im not worried about cost
Old Jan 28, 2010 | 03:06 PM
davboy's Avatar
davboy
thought I was the only one who thought that.
Old Jan 28, 2010 | 03:36 PM
johnlotusboy's Avatar
johnlotusboy
Axles (OEM speak "drive shafts") same between diff's.
Output "drive flanges" that insert in to the differentials are different between VLSD/LSD.
Driveline/drive shaft is called "propeller shaft"
Not to be confused words for these parts.
If not sure of the name of a part look in the blow-up drawings in the OEM shop manual or use parts sheet for oem parts suppliers on-line.
Bad confusion over part name = bad advice/misunderstandings/improper part purchases.
Old Man Ranting turned OFF
Old Jan 28, 2010 | 04:11 PM
ace32x's Avatar
ace32x
for the lsd to fit properly into the base pumkin you either need to replace the "axles with the viscous axles" or the conversion kit from z1, this is coming form drift office nissan dealer and multiple places i was reading from. and viscous axles from nissan are grand a pop so no ty : O
Old Jan 28, 2010 | 04:56 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
the NISMO is not discontinued
Old Jan 28, 2010 | 04:58 PM
Z1 Performance
Former Sponsor
they are talking about the same thing just using different (incorrect) terminology
axles are the same between all models
the output shaft - which is what goes in between the axle and the pumpkin, differ between LSD and non LSD cars. Those, as well as the associated bearings, seals, ring gear bolts on other various pieces are what should be done when installing an LSD
Old Jan 28, 2010 | 11:33 PM
350Zimo's Avatar
350Zimo
thanks
350Z_Al
Oct 29, 2020 07:44 PM
350z82
Oct 1, 2015 06:25 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
