is it suspension or brakes?
Old Mar 4, 2010 | 10:31 AM
sbl350z's Avatar
sbl350z
Default is it suspension or brakes?
I been hearing a little ticking noise coming from the rear, i'm not sure if it's the suspension or brakes making that noise. ;( any idea?
Old Mar 4, 2010 | 10:40 AM
Entaille's Avatar
Entaille
not enough info to go off of pal. it could be the axle clicking issue that many folks have had as well.
Old Mar 4, 2010 | 10:45 AM
sbl350z's Avatar
sbl350z
i can only hear the clicking when going slow. If it is the axles, is it gonna be expensive?
Old Mar 4, 2010 | 11:00 AM
Entaille's Avatar
Entaille
it might help you isolate the source if you go in a tunnel or under a bridge near a wall and go whatever speed makes it the most obvious to hear.
if it is the rear axle clicking, it may or may not be covered under TSB 04065A (dated November 2005)
Old Mar 4, 2010 | 11:03 AM
sbl350z's Avatar
sbl350z
damn ;( can't find tunnels or bridges around here haha.
i think i'm going to take it to les schwab n have them check it out. thanks anyways.
Old Mar 4, 2010 | 11:08 AM
Entaille's Avatar
Entaille
you could research rear axle clicking here on the forum and decide if it sounds similar. you could then call your local dealership if it sounds like that may be the same problem and mention the TSB to see if it would be repaired for free.
Old Mar 4, 2010 | 12:05 PM
Tatakai's Avatar
Tatakai
"little ticking" noise could also be a screw or just a rock stuck in the tire.
Old Mar 4, 2010 | 12:42 PM
killa.beez33's Avatar
killa.beez33
that actually could be a very good possibilty. But like others said it might be your axles or maybe your diff??
Old Mar 4, 2010 | 02:02 PM
Bumpinjeep's Avatar
Bumpinjeep
aftermarket coilovers? Give us a parts list.
Old Mar 4, 2010 | 04:50 PM
sdbarker's Avatar
sdbarker
If Ernie worked on your car, it'd be suspension. If not, who knows?
<3
Old Mar 4, 2010 | 07:23 PM
flyinglumpia's Avatar
flyinglumpia
I was going to say, I did not work on this guys car.
Old Mar 4, 2010 | 10:04 PM
HaulinZ's Avatar
HaulinZ
is your car automatic?
Old Mar 5, 2010 | 07:57 AM
johnlotusboy's Avatar
johnlotusboy
Les Schwab probably waste of time and money. Find a local 350Z guy to help you find the problem or try a "good" dealership, they will be familiar with our car platform and it's common issues. Schwab MIGHT find the problem but will always find the bill.
Old Mar 5, 2010 | 02:20 PM
sbl350z's Avatar
sbl350z
les schwab did a inspection and couldnt find anything wrong ;( and no they didn't charge me. it was all free.
and there's no 350z guy here... maybe in tricities but that's an hour away.
Old Mar 5, 2010 | 05:21 PM
Entaille's Avatar
Entaille
they couldn't find anything wrong because they don't know what they are looking for. they deal with generic repairs and installs, wear items, brakes, tires..
Old Mar 6, 2010 | 10:49 AM
sbl350z's Avatar
sbl350z
yeah probably true. i just wanted to make sure it wasn't brakes and suspension going bad i guess. i didn't hear the sound yesterday.
Old Mar 10, 2010 | 10:41 AM
sbl350z's Avatar
sbl350z
the clicking-sound-of-doom is back ;(
i should really take it into a nissan dealership..
Old Mar 10, 2010 | 11:53 AM
Entaille's Avatar
Entaille
either of these 2 threads may prove to be useful if the issue is what I think it is (just guessing of course.)
https://my350z.com/forum/wheels-and-...-replaced.html
https://my350z.com/forum/engine-driv...rear-axle.html
Old Mar 13, 2010 | 07:39 PM
sbl350z's Avatar
sbl350z
rear passenger side caliper is wearing out ;( i should save up for sports brakes n calipers
