More bushing install help
Old Jan 11, 2011 | 02:12 PM
White.Knight's Avatar
White.Knight
Default More bushing install help
Hey guys,
SPL front lower control arm bushings + compression rod bushing:
Anyone have these install, what were you charged? Anyone successfully install it themselves?
After searching exarmyguy said he was doing a DIY, how did this go?
tw8715 mentioned a shop up north. Are you able to remove the arms too or do ppl just bring you the arms and bushings to be pressed?
thanks for any responses.
Old Jan 11, 2011 | 08:51 PM
Tiltz's Avatar
Tiltz
I am in the market for the SPL compression rod bushings. I am pretty sure its not too difficult. You can get a press from harbor freight for less than $100.
https://my350z.com/forum/brakes-and-...g-install.html
Old Jan 11, 2011 | 08:58 PM
JasonZ-YA's Avatar
JasonZ-YA
Also search my name for the translink bushing installs.....there are diys for all front lower bushings....
J
Old Jan 11, 2011 | 08:59 PM
JasonZ-YA's Avatar
JasonZ-YA
Spl bushings don't require the steel dom tubing I call out...but the press concept is identical....
J
Old Jan 11, 2011 | 11:52 PM
tw8715's Avatar
tw8715
im pretty sure any machine shop around here can push the bushings in.
take off the arms and bring it to them to save some $ on labor charges!
if you do this let me know! i wanna feel the before and after lol
i couldnt pull the trigger and get these
Old Jan 12, 2011 | 05:14 AM
exarmyguy's Avatar
exarmyguy
I just did the compression arm bushing. It was really easy. If you know somebody that has a press I would really DIY. If not, then I would atleast take the parts off youself, then take it to a shop to have the bushings pressed out/new ones in. That will cut labor costs down. They'll probably charge about an hours worth of labor, even though it only takes about 10 min or so on the press. If the shop does everything... I would say 2-3 hours labor minimum.
Old Jan 12, 2011 | 07:12 AM
RetchedOne's Avatar
RetchedOne
Younker Nissan was able to press out/in my buddies front wheel bearing pretty quickly... i cant see these taking longer than their minimum charge of one hour...?
Old Jan 12, 2011 | 11:14 AM
JasonZ-YA's Avatar
JasonZ-YA
Guessing how much a shop can or will charge is a moot point.......
If its a shop familiar with the Z and all things go well, ie (no rust, etc like what happened here) then an hour sounds like the ACTUAL time, but if a shop knows that rust and seizing can happen and factor in the possibility of that issue they can probably quote more hours since they "know" the job...
about the only thing you can do is stand around and time the job and argue actual time??
if a shop thats not Z related is asked to do it, one look at the nice SPL bushings and a 350z modded or not, they are probably gonna quote high.......
in the end, about the best you can do is drive around and obtain quotes....
If someone locally ask me to install them for them, I tell them they must come over and lend a hand when i need it and it usually takes me under an hour as i have all the right tools for the job! I charge $100 bucks........but if i have to deal with a seized Compression rod to the stud, then 100 bucks is moot and honestly not worth it as it becomes a real pain in the azz!!! I just have to roll with it and knock it out........Ive installed about 6 sets now......most being people that wouldn't have normally purchased them with out my influence......
your welcome spl......
-J
Old Jan 12, 2011 | 11:57 AM
murders's Avatar
murders
ya im in the same boat, z1 can do it for you, im getting new arms and getting inner and outer bushing done and sent to me !
Old Jan 12, 2011 | 03:08 PM
RetchedOne's Avatar
RetchedOne
-J
You need to move to seattle...
Old Jan 12, 2011 | 05:42 PM
JasonZ-YA's Avatar
JasonZ-YA
^ I was there in Everett, working for Boeing 3 years ago....met Drivesolo and a few at f1 go karts or something like that...
never know, i may be back.....
-J
Old Jan 12, 2011 | 05:53 PM
RetchedOne's Avatar
RetchedOne
-J
Well be sure to post here if you ever do come up this way
Old Jan 13, 2011 | 01:49 PM
White.Knight
thanks for the suggestions everyone, i will shop around and find the best route. keep you guys posted.
I will also post how the steering and handling feels after.
Jason, SPL should be paying you!
Old Jan 17, 2011 | 09:42 AM
drivesolo's Avatar
drivesolo
-J
Hey Jason, I'm trying to recall that event. Was that when the local 350Z guys raced against the S2K guys at Sykart in Tukwila?
Old Jan 17, 2011 | 10:55 AM
seymore4's Avatar
seymore4
Professional
Got a group buy going on for the SPL products for local guys, all the bushings are included! I'm getting the full set
Old Jan 18, 2011 | 03:53 AM
JasonZ-YA's Avatar
JasonZ-YA
dont think so, it was an indoor kart place...only a few guys showed up...
I was there with a co-worker that was on company business with me.....was back in Sept 2007 if i remember right..
-J
Old Feb 15, 2011 | 11:19 AM
JasonZ-YA's Avatar
JasonZ-YA
I may be there march and april...
-J
Old Feb 18, 2011 | 10:55 AM
RetchedOne's Avatar
RetchedOne
-J
March is coming up...
Old Feb 21, 2011 | 08:43 PM
JasonZ-YA's Avatar
JasonZ-YA
Old Feb 21, 2011 | 10:21 PM
350Zimo's Avatar
350Zimo
Just PM me. I have a friend w/ a press. I can send you to him. He will do it for cheap
