Injen CAI for 350Z now CARB approved :)
Old Jan 20, 2005 | 02:59 PM
HyperSprite's Avatar
HyperSprite
Mad Scientist
Default Injen CAI for 350Z now CARB approved :)
I just got an email back form Injen regarding CARB status (last I heard it was pending). They got their approval last month.
Here is the doc that states it http://arb.ca.gov/msprog/aftermkt/de...eo/D-476-4.pdf
I am printing this and keeping it in the Z
If you want to look up other parts you can go here
http://www.arb.ca.gov/msprog/aftermk...es/amquery.php
I usually pick a category of interest and search the resulting page for "350Z".
Chris
Old Jan 20, 2005 | 04:01 PM
MGV156's Avatar
MGV156
Too bad I had to take mine out because it was making the engine run too lean. Well, that's according to Gary from Steven's Creek after he had Consult take some readings.
Old Jan 20, 2005 | 06:00 PM
whatever's Avatar
whatever
Veteran
wow, that took a while....
wonder when any of the FI will be carb.... in 3 years?
Old Jan 20, 2005 | 06:28 PM
HyperSprite
Mad Scientist
Originally posted by whatever
wonder when any of the FI will be carb?
I don't want to take this to far off topic but...
Yeah... Jim Wolf Tech says their TT system is going through the final certification for CARB and will be released upon passing, and supposedly this is any day now.
Rough specs on that is:
Twin water cooled Garrett ball bearing pumps
No mods to the bumper, radiator, motor stays in the car during install.
Cast manifolds.
two smaller intercoolers side by side instead of one giant one.
128 more HP at the wheels @ 6psi
Six Thousand Nine Hundred Ninety Nine Dollars
Chris
Old Jan 21, 2005 | 05:02 AM
HyperSprite
Mad Scientist
Just for grins, I searched every section of the CARB list, this is what I found.
Air Filter/Intake Modification
EO: D-392-21
EO Date: 12/18/2003
Manufacturer Name: Advanced Engine Management
Device: Air Induction Systems
Device Type: Air Filter/ Intake Modification
http://arb.ca.gov/msprog/aftermkt/de...o/D-392-21.pdf
21-547 2003 3.5L Nissan 350Z
EO: D-392-22
EO Date: 12/23/2003
Device: Air Bypass Valve
http://arb.ca.gov/msprog/aftermkt/de...o/D-392-22.pdf
20-402s 2003 Nissan 350Z 21-547 The air bypass valve can only be used with ARB-exempted Advanced Engine Management, Inc. Cold Air Systems. Installation of the air bypass valve requires cutting and removing a short section of the Cold Air System inlet pipe.
EO: D-392-24
EO Date: 9/20/2004
http://arb.ca.gov/msprog/aftermkt/de...o/D-392-24.pdf
21-547 2003-2004 3.5 liter Nissan 350Z
EO: D-392-25
EO Date: 9/20/2004
http://arb.ca.gov/msprog/aftermkt/de...o/D-392-25.pdf
20-402s 20-403s 2003 Nissan 350Z 21-547 The air bypass valve can only be used with ARB-exempted Advanced Engine Management, Inc. Cold Air Systems. Installation of the air bypass valve requires cutting and removing a short section of the Cold Air System inlet pipe.
EO: D-476-4
EO Date: 12/23/2004
Manufacturer Name: Injen Technology Co., LTD
Device: Cyborg Intake System
RD1985 2003-2004 NISSAN 350Z
EO: D-244-5
EO Date: 6/22/2004
Manufacturer Name: Jim Wolf Technology, Inc.
Device: POP-Charger Air Filter Kit
http://arb.ca.gov/msprog/aftermkt/de...eo/D-244-5.pdf
P3503-1XCN7 350Z 03-05 Air filter element; bracket; hardware
EO: D-269-27
EO Date: 10/20/2003
Manufacturer Name: K & N Engineering, Inc.
Device: Typhoon Intake System
http://arb.ca.gov/msprog/aftermkt/de...o/D-269-27.pdf
69-7070TB 2003 Nissan 350Z V6-3.5L
69-7070TP 2003 Nissan 350Z V6-3.5L
69-7070TR 2003 Nissan 350Z V6-3.5L
69-7070TS 2003 Nissan 350Z V6-3.5L
EO: D-436-10
EO Date: 2/17/2004
Manufacturer Name: Stillen Sportparts
Device: Stillen Supercharger Kit
Device Type: Supercharger System
http://arb.ca.gov/msprog/aftermkt/de...o/D-436-10.pdf
2003 Altima, FX35, Murano, Maxima, Pathfinder, QX4, 350Z, G35, I35 2004 Altima, Frontier, Pathfinder, Xterra, FX35, 350Z, G35, I35 The Stillen Supercharger Kit consists of a Magnuson Products, Inc. supercharger assembly that is rated at a maximum boost of 6.1 psi. at 6500 rpms using a 2.2" diameter pulley. The kit also includes an upper intake manifold, a supercharger bypass valve, an add-on fuel injector that uses a metal fuel rail, an intercooler, and a stand alone fuel management unit to operate the additional fuel injector. Installation of the supercharger kit requires the rerouting of the positive crankcase ventilation hose. All supplied hoses and lines are SAE30R9 which is rated at 15 gm/m2/24hrs. The kit retains the stock air cleaner housing. Excluded are the following 2004 model-year LEV II LEV test groups: 4NSXV03.5G7C, 4NSXT03.5G7A and 4NSXV03.5G7A.
Old Jan 21, 2005 | 03:59 PM
LOU's Avatar
LOU
If anyone is curious Vortech is trying to get CARB on an 2005 model. If the 2005 model is certified than so is the 2004 and 2003. Whereas if they certified the 2003 it wouldn't count for 2005.
Old Jan 24, 2005 | 03:20 PM
whatever's Avatar
whatever
Veteran
so does this mean the Nismo CAI is carb legal since it is a rebadge AEM...?
Old Jan 24, 2005 | 03:43 PM
HyperSprite
Mad Scientist
it might, is there any place on it with a part number that matches the aem numbers?
I am also wondering how those with current Injen CAI can get the sticker.
Chris
Old Jan 24, 2005 | 08:29 PM
WSchli1672's Avatar
WSchli1672
So Lou....keep me up on the vortech carb. Is it just around the corner on the vortech, including the 2003 and 2004 model. What does this mean? = " Whereas if they certified the 2003 it wouldn't count for 2005."
Old Jan 24, 2005 | 08:56 PM
HyperSprite
Mad Scientist
Keep in mind running a product through testing is quite expensive, so a company like Vortech only wants to do it once.
The 2003 and 2004 are ULEV, the 2004.5 and 2005 are ULEVII.
If it passes for the higher standard (ULEVII), CARB assumes it can't hurt the lower standard, so they pass it on the whole line.
Chris
Old Jan 25, 2005 | 05:55 PM
WSchli1672's Avatar
WSchli1672
Will the 2005 perform same as others equally, or will it improve? i.e. increase hp, quality, etc., or be same except newer?
Old Jan 31, 2005 | 09:48 AM
Chicken's Avatar
Chicken
Instructions on this page...
http://www.injen.com/carb.html
Old Jan 31, 2005 | 12:18 PM
HyperSprite
Mad Scientist
So I am basically screwed because I bought it used
Chris
liqalu04
Jan 2, 2022 12:58 PM
issyz
Jul 2, 2017 03:04 PM
wanderingstuden
Jan 28, 2016 07:03 PM
Justin100
Nov 29, 2015 03:58 PM
codek
Sep 28, 2015 03:03 AM
