help on motor
Old Mar 29, 2007 | 08:02 PM
SPRacing's Avatar
SPRacing
Default help on motor
the motor makes a loud clicking sound. if you watch the video, you'll see. I currrently have an turbonetics kit, CJ Motorsports Stage 2 with 550cc, and UTEC. Can anyone in the bay area can help me out with my build?
http://s132.photobucket.com/albums/q...Picture052.flv
thanks in advance
Old Mar 29, 2007 | 08:08 PM
Nic@CiNcity's Avatar
Nic@CiNcity
Does it rev match? Sounds like my Evo did when my block decided to take a dump on me.
Old Mar 29, 2007 | 09:23 PM
SPRacing's Avatar
SPRacing
what do you mean by rev match. My idle changes if i leave the car on for a while.
Old Mar 29, 2007 | 10:46 PM
Darshu's Avatar
Darshu
Rod knock Sounds pretty bad too. Did you lose oil pressure at some point recently?
Old Mar 30, 2007 | 10:30 AM
cbtech's Avatar
cbtech
It also sounds like a bad lifter. Rod knock, from what I remember, would be much louder and have more of a random knock. Not the repeditive tick that you hear.
Old Mar 30, 2007 | 11:00 AM
Darshu's Avatar
Darshu
That sounds pretty loud to me, though you could diagnose it pretty easily by listening to see if the sound appeared to be coming from the head in one bank or the block itself. Rod knock would be the sound of the conrod slapping around in a damaged bearing, so while it can very in severity, it will always follow engine RPM.
Old Mar 30, 2007 | 02:30 PM
SPRacing's Avatar
SPRacing
i dont think its rod knock. If i start the car right now, the noise wouldnt be there but if the car idles for little longer then the noise is there.
thanks for the help.
any bay area can help me out on a motor build?
Old Mar 30, 2007 | 02:32 PM
SPRacing's Avatar
SPRacing
i did poped a oil line not too long ago
Old Mar 30, 2007 | 02:36 PM
Darshu's Avatar
Darshu
When the engine is colder, the oil is thicker and pressure is higher, but as temps come up and oil viscosity and pressure at idle decrease, the noise appears? Does it increase in frequency with engine RPM? does it appear localized to one particular part of the engine?
Old Mar 30, 2007 | 11:43 PM
andypandy's Avatar
andypandy
got the same thing in my motor.
could be spun rod bearings.
taking the car to GTM first thing in the morning tomorrow to diagnose the problem.
good luck to you too.
Old Mar 31, 2007 | 01:13 PM
SPRacing's Avatar
SPRacing
the sound does come one particular place and the sound do get louder when i rev the car.
Old Mar 31, 2007 | 01:14 PM
SPRacing's Avatar
SPRacing
hey fill me in after you get your car back from the shop. what are you planning to do? build?
Old Mar 31, 2007 | 02:00 PM
andypandy's Avatar
andypandy
my block is built.
i was missing 1 quart of oil so i suspect that it's NOT spun rod bearing... but hell, it was making all these funky *** noises that seems to be the most obvious reason i could speculate as.
i am thinking heavy valve damage, but again only speculation. the shop should be calling within a few hours... i'll let you know by then.
btw, where was your noise coming from? mine was coming from the driver side above the throttle body.
Old Apr 2, 2007 | 01:36 PM
SPRacing's Avatar
SPRacing
my block is built.
i think we're on the same boat. i believe its valve damage also. where did you take your car too. I need a shop in the area that can built my block or install it.
Old Apr 2, 2007 | 08:16 PM
andypandy's Avatar
andypandy
GT Motorsports in southern california.
i still haven't got a call back from them... they are really busy as they have clients all the time, so i am sitting this out. sucks as i must grocery shop with my bicycle and backpack. haha! but it's good exercise for the oh-so-soon summer.
anyway, once i get official word, i'll let you know. where are in california are you located?
Old Apr 3, 2007 | 07:39 PM
SPRacing's Avatar
SPRacing
i just notice your in LA. im in San francisco. but just fill me in anyways on what your going to do. Im on spring break and might be heading down south to LA. thanks
Old Apr 19, 2007 | 09:53 PM
andypandy's Avatar
andypandy
well got the news today: it was a spun rod bearing.
i checked out the bearing which has 2 raised notches and cylinder 6's bearings were gone... just a flat brass piece with the ceramic coating annihilated. my crank and rod are scruffed up too, so i will have to change both out. i have two options: 3.8L stroker crank or go with the stock crank... right now it's only a matter of funds to complete whatever needs to be done.
anyway, yeah... i learned a hard lesson. matter how 'premium' the oil is, it's imperative to change the oil every 2000 miles... just to be safe.
have you taken your car in yet? i suggest you don't drive anymore, or you might cause serious damage to the internals and even the block.
Old Apr 20, 2007 | 06:15 AM
THE TECH's Avatar
THE TECH
Who built your motor? Is anyone taking care of some of the costs?
Fixxxercask
Nov 9, 2015 11:10 AM
