Shop Builds Temp moving posts for some clean up of this section.
taurran : "Testing new waters" with the Turbonetics ST
Old Jan 24, 2008 | 08:13 AM
  #1381
taurran's Avatar
taurran
Originally Posted by taurran
Yep. Here's the video. This is from when the queiter exhaust was on it. I'm glad I got this because with the loud exhaust now it would be a lot harder to hear.
<object width="425" height="355"><param name="movie" value="http://www.youtube.com/v/AdMez8q8LxU&rel=1"></param><param name="wmode" value="transparent"></param><embed src="http://www.youtube.com/v/AdMez8q8LxU&rel=1" type="application/x-shockwave-flash" wmode="transparent" width="425" height="355"></embed></object>
So... is anyone stumped by the sound in this video?
Old Jan 24, 2008 | 08:31 AM
  #1382
EnjukuBG's Avatar
EnjukuBG
Enjuku Racing
Taurran Already Has Twins lol
i never read that before.
Old Jan 24, 2008 | 10:01 AM
  #1383
IIQuickSilverII's Avatar
IIQuickSilverII
Old Jan 24, 2008 | 10:36 AM
  #1384
Zilvia's Avatar
Zilvia
i couldn't really hear any thing.
Have you tried revving it with the hood open. w/ the the throttle.
maybe u can find out where the tap is coming from.
if it sounds like a tapping sound, BBs against a wall, like you said earlier. Then you might have a loose or bent valve. B/c that when my KA dropped a valve. It made this really loud tapping sound once it got past 2k, and at constant throttle you could't hear it as much, but giving it gas you could hear it completely.
just another possibilty, which i really hope isnt the case.
Old Jan 24, 2008 | 10:45 AM
  #1385
taurran's Avatar
taurran
You're thinking of two different sounds. You can hear the metallic tapping in that, which is based on RPMS. It makes it if revd but its really quiet. It makes it louder while the motor is under load and in gear, so hard to hear under the hood. We traced it to the motor somewhere in the vicinity of the heads when Jayson and I were listening around on the motor.
The "BB's against the firewall" was the pinging noise I heard at high boost.
It doesn't really sound like valve tapping... but I guess I could be wrong if it's different than I'm used to. I own a KA24 too which has noisy valves.
And no, that's my old Fuji exhaust. The new 3" dual tipped exhaust should be finished tomorrow night.
Old Jan 24, 2008 | 12:10 PM
  #1386
2004Black350z's Avatar
2004Black350z
Exhaust Whore
Im also stumped by sound. Couldnt hear the noise that clear. Also please post piks of exhaust and def a sound clip craig
Old Jan 24, 2008 | 04:53 PM
  #1388
diwun67's Avatar
diwun67
Kinda sounds like it has a diesel sound to it...but I can't tell what it is
Old Jan 24, 2008 | 05:17 PM
  #1390
taurran's Avatar
taurran
Yeah, that's what I called it.. sounds like a diesel truck kinda.
On another note, I just went by the exhaust fab shop to check out the progress, and WOW... it looks amazing. It only had one tip on but I can already tell its going to end up being absolutely sick...
The exhaust will be ready to roll tomorrow. I'll get some pics and hopefully some sound.
Old Jan 24, 2008 | 06:38 PM
  #1391
Zexy's Avatar
Zexy
Diesel truck sound is piston slap.. I never heard of diesel truck sound having to do with anythinga bad motor Hope you get it sorted out craig. Built motors are usually noisier depending on the piston to wall clearance.
Old Jan 24, 2008 | 11:12 PM
  #1392
Zilvia's Avatar
Zilvia
yea i think i was mixing up all the things you are saying. either way i hoe you guys get it solved.
Old Jan 24, 2008 | 11:43 PM
  #1393
solidsnake's Avatar
solidsnake
This is totally off topic but I like the new spoiler. Didn't you have the INGS before? Car looks good and the 18s are awesome, IMO would look better in gloss black but it's your car, not mine
Old Jan 25, 2008 | 04:57 AM
  #1394
taurran's Avatar
taurran
Ugh... Piston slap would be something that would be worse when the car is cold, correct? I'll have to check.
My car does still smoke a bit. I know that Ryan was telling me it was smoking while under boost before. I'm fairly certain its not the turbo as this is the 3rd turbo that's been in the car, and each has been built with brand new seals. There's also the case of the PCV that's hanging open since it has no intake pipe before the turbo (need to fix this soon). I'm going to keep an ear out if the noise changes after the car heats up.
I think that it's interesting that Jeremy said that Larry's car made the same noise, and interestingly enough his car was smoking and seemed to have blowby issues. I'm wondering if my car has the same issue but I'm hearing its a non-issue? Larry, what came of this?
Old Jan 25, 2008 | 05:36 AM
  #1396
taurran's Avatar
taurran
Originally Posted by 98MODMTR
After putting my ear to the engine I was sold on the cam tensioner being the culprit, but having that piece replaced and the noise continuing, I am way out of my league and can't say what it may or may not be.
Right. For all I know it could be anything. I think it's something an experienced engine builder would have to diagnose in person. Woohoo...
Old Jan 25, 2008 | 05:52 AM
  #1397
Audible Mayhem's Avatar
Audible Mayhem
My350z
please dont twist things around
i said that larrys car sounds like this. there is NO smoke and NO blowby issues with his car.
Old Jan 25, 2008 | 05:56 AM
  #1398
Audible Mayhem
My350z
please remember that you are the one who bought used RC750s and a used Utec for this build i have told you since day one that i think something is wrong with the injectors.
it all comes down to this, you need to step up and upgrade some things on your car. you cant have the fastest car without the right equipment.
Old Jan 25, 2008 | 06:38 AM
  #1399
taurran's Avatar
taurran
Right. The intention was never to twist. I was referring to whatever was going on before with his car which I only have half the info on. Larry's car should be running right now after all the work put into it.
I'm going to have to try a few things on my car. There could be half a dozen small things that contribute to smoke that I can fix easily. First things first is to get it back from the exhaust shop so I can dick around with it some.
Old Jan 25, 2008 | 07:08 AM
  #1400
drap660's Avatar
drap660
No disrespect to anyone, but Taurran why dont you just go with Jeremy's suggestions. Afterall he did build your car and knows better than anyone what the problem could be. I build atv's on the side and know what its like working with used parts that might have issues. Why not go with Jeremy's idea and put it in his hands. I know the build took forever and maybe things didnt go exactly the way you wanted but I think it would be in your best interest to let him finish it off. If you supply him with a new EMS and a set of new injectors then he would have to figure this out, because everything else came from him. Once again no disrespect to anyone...
