Shop Builds Temp moving posts for some clean up of this section.
GT Motorsports: 4.2L Stroker, VPro, APS TT, GTM BUILT 5AT, 600RWHP! *PIX*
Old Aug 10, 2007 | 11:41 PM
Sam@GTM's Avatar
Sam@GTM
GT Motorsports
Exclamation GT Motorsports: 4.2L Stroker, VPro, APS TT, GTM BUILT 5AT, 600RWHP! *PIX*
Another beautiful car we had the chance to work on, Came in with a APS TT, SP built engine, and SP cams. and the customer wanted some serious power so here are the upgrades we preformed on the following vehicle:
"Beauty & a BEAST"
2006 Nissan 350Z Roadster
GTM 4.2L Stroker Kit
GTM Newly Designed 14MM ARP 2000 Head Studs
GTM Stage 3 Heads
GTM Stage 1 Turbo Cams
GTM Fully Built Stage 3 Automatic Transmission
GTM Spec Coating on Pistons and Bearings
GTM Spec 14" Dual Fan Upgrade
GTM Radiator Shroud (Polished Version)
GTM Spec ECU Flash
HKS FCon VPro Standalone Engine Management System
HKS Knock-Amp A/F Wideband
HKS EVC6 Boost Controller
HKS Navigator
HKS Oil Temp Sensor
HKS Fuel Pressure Sensor
HKS EGT Sensor
HKS Oil Pressure Sensor
Defi Gauges with D-Link
GReddy EVO TT Exhaust (Modified to remove 50mm bottle neck)
GReddy Strut Tower Bar
GReddy Oil Cooler
GReddy Transmission Cooler
Polished Manifold and timing cover
Volk GT-S Wheels with Toyo T1-R
Stoptech 4 wheel cross-drilled Big Brake kit 6/4Piston kit
APS Twin Turbo Kit
APS Extreme Fuel System
APS 3.5
Down Pipes
Samco Hoses
PWR Race Radiator
This car came to us orginally for diagnostic work, Andrew was disappointed with the power the car was making. He was told the car made 550rwhp (so he ordered custom plates to match that ) After doing a baseline dyno the car did not even make 350rwhp. So Andrew said "If my liscense plate says 545rwhp I need to have ATLEAST that". With that said we set forward feed his hunger for more power!
The car is in the break in process, our first tuning sesssion we were able to accomplish 520rwhp at 11psi. We made the wrong spring choice on these actuators so we had a hard time building more than 11psi of boost. Car will be back in a few weeks to change the springs and go for 600rwhp.
Enjoy the Pictures! We will be back after the car returns for new springs and tuning.
Dyno Chart of the car when it orginally came in:
Conservative 91 Octane Tune 11 PSI
Pictures:
Sam
GT Motorsports
Old Aug 10, 2007 | 11:47 PM
rookie's Avatar
rookie
WOW, sick 5AT numbers.
Old Aug 10, 2007 | 11:49 PM
chriskabobbers's Avatar
chriskabobbers
wow impressive. that's the first time i've ever seen anyone with the 420zTT emblem besides alex.
Old Aug 10, 2007 | 11:53 PM
Sam@GTM's Avatar
Sam@GTM
GT Motorsports
You will be seeing a lot of cars with this emblem soon
Sam
GT Motorsports
Old Aug 10, 2007 | 11:58 PM
IssaFX's Avatar
IssaFX
Drool... nice emblems and all
If I may ask about how much installed for both?
Old Aug 11, 2007 | 12:23 AM
leeboyNY's Avatar
leeboyNY
Kimchi Eater
Sam,
Which spring did you use before and which one did you switch to?
I assume you used the forge actuators.
Digging the GTM emblem!!
Thanks!
Jay
Old Aug 11, 2007 | 12:27 AM
Sam@GTM's Avatar
Sam@GTM
GT Motorsports
We installed the BLUE springs first, we did not want to run a high base boost of 15psi. Looks like we are going to have to install the RED ones. Typically if you want to accomplish a 14-15 psi base actuator boost setting then red springs will be the way to go, just make sure the preload is set correctly.
With a boost controller you will have the ability to go up to 20 psi.
Yes we did use Forge actuators.
Take care Jason,
Sam
GT Motorsports
Old Aug 11, 2007 | 12:31 AM
paranormal's Avatar
paranormal
Evil Boy 4 LIFE
wow.. those heads have me drooling over here.. wish i had more money..haha
also the oil cooler and transmission cooler look sweet!
nice car for sure!!!!!!!!!
Old Aug 11, 2007 | 01:23 AM
Audible Mayhem's Avatar
Audible Mayhem
My350z
very nice sam!! must be very fun to drive !!
i would never get a tag with a number on it like that though, cause you always want more!!!
Old Aug 11, 2007 | 02:59 AM
S12 driver's Avatar
S12 driver
Wow, are those 420Z badge custom made? That is badass.
Old Aug 11, 2007 | 03:38 AM
Netko350Z's Avatar
Netko350Z
Serious $$$ there...
Old Aug 11, 2007 | 03:50 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Baller!!! Sweet ride!!!
Old Aug 11, 2007 | 04:25 AM
taurran's Avatar
taurran
Wow... nice work.
Insane money in that setup, there. I'm looking forward to seeing what it's really capable of. I'm hoping those APS turbos can deliver as they'll be the limiting factor it seems (assuming that the tranny holds up).
You guys are doing a lot of custom high end build products and this car seems to showcase them all. Got any more specs on those head studs? What's the compression on the 4.2l stroker and those pistons? More info on radiator shroud?
Old Aug 11, 2007 | 05:48 AM
turismo's Avatar
turismo
simply insane!
Old Aug 11, 2007 | 06:17 AM
cubu's Avatar
cubu
nice build, but not feeling how the front looks though... those blue radiators look cheap and don't reflect well on the car, kinda r......
Old Aug 11, 2007 | 07:50 AM
IslandZavage's Avatar
IslandZavage
Damn thats a sick build...Cant wait for my time to build the motor..
Old Aug 11, 2007 | 08:22 AM
abyss's Avatar
abyss
good thing you stopped yourself. Things that benifit your car aren't rice. ...and why do they look cheap? They look pretty good.
Old Aug 11, 2007 | 08:27 AM
rcdash's Avatar
rcdash
Absolutely beautiful car. One of the smoothest, highest hp 5AT dynos I've seen, and at only 11 psi is remarkable... Congrats to owner and GTM!
(I think the paired Greddy coolers look good - matches the engine bay scheme)
Old Aug 11, 2007 | 08:32 AM
abyss's Avatar
abyss
Could you PM me the price on these things?
GTM Stage 3 Heads
Old Aug 11, 2007 | 08:38 AM
XM 1's Avatar
insane everything nicely done.......btw i´m living in germany, would it be possible to get a build engine from you???
