Shop Builds Temp moving posts for some clean up of this section.
Intense Widebody G35/PowerLab GT35R/ProEFI ECU Makes 653WHP!
Old Nov 9, 2007 | 06:58 AM
  #41
D350Z10's Avatar
D350Z10
Originally Posted by Audible Mayhem
damn 29 psi, thats a lot of boost. your kit is basically doing the same thing that we are having issues with Taurrans car. its bottlenecking somewhere over a certain boost level. if you post your graph on your 500 whp , i bet it pulls all the way up to redline. then as you add boost it will start dropping sooner and sooner in the rpms.
you made 500 on 10 psi and 650 on 29 psi. thats not even 8 hp per psi. we can make the same hp levels on the same boost but we are trying to get it do that without the bottlenecking that we are both going through.
maybe it is the stock manifolds.....
+1, thats way to much boost for that power... that doesn't sound reliable.. a thousand miles or so and headlift will become an issue
Old Nov 9, 2007 | 07:20 AM
  #42
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
Originally Posted by booger
Where is the turbo at....down low like APS's kit ? Or up front like TN's kit ?
any pic's ?
Here's a prototype on a Z from one of the other threads --> https://my350z.com/forum/forced-induction/271686-new-single-turbo-kit-installed.html
Old Nov 9, 2007 | 08:08 AM
  #43
tig488's Avatar
tig488
that 35R is working overtime, lower compression, 29psi, and already at 800 crank hp, damn that baby is pumpin. hurry and put the 37R on there. are yall measuring air intake temps?
Old Nov 9, 2007 | 09:03 AM
  #44
IIQuickSilverII's Avatar
IIQuickSilverII
Originally Posted by IntenseFab
Thanks tig,
Yeah its just PowerLabs Stage 1 single turbo kit 3'' downpipe, 3'' exhaust, and ProEFI ECU. I'll have some video up tomorrow as well!
CAnt wait will my car is done!
it will be even more INTENSE !!!
/no gt37r for me\
Old Nov 9, 2007 | 09:13 AM
  #45
INTENSEPOWER's Avatar
INTENSEPOWER
Vendor - Former Vendor
Hello,
As stated earlier in the thread by IntenseFab, it didn't hold at 29psi -- it spiked. It held 21psi to redline. The turbo was all in. The initial post needs to be edited to state that the motor has ARP headstuds.
Darren.
Old Nov 9, 2007 | 09:22 AM
  #46
ILLBZNU's Avatar
ILLBZNU
Default What size head studs?
What size/type of head studs?
Old Nov 9, 2007 | 09:35 AM
  #47
INTENSEPOWER
Hello,
They're standard ARP.
D.
Old Nov 9, 2007 | 09:50 AM
  #48
D350Z10's Avatar
D350Z10
Originally Posted by INTENSEPOWER
Hello,
Darren.
21psi on standard head studs is still pushing your luck, I know from experience. Best of luck though!
Old Nov 9, 2007 | 09:56 AM
  #49
IIQuickSilverII
ur makings this a bigger deal than it really is .....its all preliminary and for R&D purpuses also......
there is a reason why I am getting L19s on mine.
Old Nov 9, 2007 | 10:00 AM
  #50
Quamen's Avatar
Quamen
It says ARP headstuds.
Old Nov 9, 2007 | 10:07 AM
  #51
taurran's Avatar
taurran
I'm interested in seeing if it makes much more power with a larger turbo. I also wish I could see what the piping looks like from under the car.
I personally wouldn't feel right running around at 21psi making 600-650 or so... IMO it means there's a bottleneck somewhere and if it's exhaust side it's trapping heat in there.
Old Nov 9, 2007 | 10:18 AM
  #52
rkd350z's Avatar
rkd350z
omg great!!!
Old Nov 9, 2007 | 10:24 AM
  #53
IIQuickSilverII
hot of the press!!!!
on GT37R
2 + 1 overlayed
Old Nov 9, 2007 | 10:25 AM
  #54
taurran's Avatar
taurran
Very nice... is that the same car? How much boost?
Old Nov 9, 2007 | 10:27 AM
  #55
IIQuickSilverII
yes ...not sure on the boost...
...its on a gt37r btw...
Old Nov 9, 2007 | 10:28 AM
  #56
rkd350z's Avatar
rkd350z
our car will be like Supra
very similar dyno curve with supra except it drops at the end..
want to see this kit with Cosworth plenum.
  #57
INTENSEPOWER
Hello,
Thanks for your luck! Let me address your concerns:
1. Boost pressure has nothing to do with the head lift, cylinder pressure does. I.E. -- you could run 21psi and only make 400whp and never have a problem.
2. The stock ARP's are only marginally stronger than the OEM bolts.
3. We've run well over 1000whp on Supra's with stock bolts.
4. Our engine builder (the same one that builds our 1500whp Supra's) has advised us that for this power level we didn't need to run L19 studs.
5. The tune is most critical. If you detonate you have cylinder pressures that equate anywhere from 3x-5x or more pressure, or more than the cylinder pressure that's actually being produced. If you stay away from detonation with a proper tune, the stock head bolts are sufficient for this power level.
6. We put standard ARP bolts in because we were already into the motor. Our intentions were to push the limits of the stock sleeves, so we didn't want to hit a stock bolt limit before a stock sleeve limit and have to go into the engine twice to achieve our goals.
7. This will be a production kit, off the shelf, sold to the public. We are testing right now. It's not meant to give everyone 650+ whp, but it's capable of it.
If you're not familiar with the name Jason Seibels, Google him. He was the chief designer of the AEM EMS and the tuner of Stephan Papadkis's cars, John Sheperd, and many other of the fastest imports in the world. His resume and track record (pun intended) speak for themselves and we have full confidence in his company, Pro EFI, and of course his tuning abilities.
Thanks again for your luck!
Darren (thanks Jorge for posting the new dyno results -- now over 700whp w/ a GT37r -- and no head lift )
  #58
IIQuickSilverII
wait till mine is done
new thread will be created for GT37r Results
I guess ill help darren adn create the thread for him since he is off to lunch lol
/end of thread - on to the new one
Old Nov 9, 2007 | 10:36 AM
  #59
IntenseSales's Avatar
IntenseSales
Default ahaha
Had the privilege of being stuffed in the trunk to hold the wheels to the dyno on these last passes. Soooooo SICK! Fat guy in a little Truuuuunnnkkkk!
Old Nov 9, 2007 | 10:50 AM
  #60
TENGAI's Avatar
TENGAI
Why would you say there's a bottleneck??? 600-650whp at 21psi is about damn PERFECT for a 35R. If they only made 450ish at 21psi, then I'd say yes, definitely a bottleneck. But that's not the case here at all.
The fact that the 37R made over 700whp is testament to the fact that the piping on the kit FLOWS. No way to debate that...
