Shop Builds Temp moving posts for some clean up of this section.
My "Z33Art" Custom Supercharger Build *PICS*
Old Sep 6, 2008 | 04:35 PM
  #181
Cux350z's Avatar
Cux350z
hatersgonnahate
Originally Posted by Quamen
Here is a picture of the intial prototype adjustable pressure relief valve for supercharged applications!
OOOOOOo nice. Guess its most beneficial to locate near the SC as possible or would mounting near the IC or TB be better for maintaining pipe pressure?
Cant wait to see the power adder and final numbers!
Congrats on the engagement!
Old Sep 6, 2008 | 07:01 PM
  #182
Quamen's Avatar
Quamen
Ultimately pre-intercooler would be the best because it prevents you from cooling air that you aren't using. Otherwise location doesn't really matter.
The pressure that this is adjusted to will not be the same as manifold pressure and would obviously vary from kit to kit depending on the effeciency of the system and the pressure loss between the headunit and the manifold.
Old Sep 6, 2008 | 07:08 PM
  #183
Quamen's Avatar
Quamen
Originally Posted by radiologue
Love your porsche!
I have a 968 turbo track car myself. I don't think I have the ***** or the skills for Pike's Peak, but I share your enthusiasm for speed. My car makes the same power as your 928 but doesn't sound near as nasty!!! I love it.
Nice!!!
6.4L 32V motor is replacing the 5.1L 16V this winter and is at the machine shop right now. A hybrid blower that I made is also going on the car so we can really put the power down. Essentially I took an impeller and volute from one supercharger (aka the billet impeller we make and the corresponding volute) and made it fit in a gear driven blower with a much higher internal step up but that had a small impeller.
Attached Thumbnails My "Z33Art" Custom Supercharger Build *PICS*-hpim2150-medium-.jpg   My "Z33Art" Custom Supercharger Build *PICS*-hpim2148-medium-.jpg   My "Z33Art" Custom Supercharger Build *PICS*-hpim2147-medium-.jpg
Old Sep 6, 2008 | 07:11 PM
  #184
Quamen's Avatar
Quamen
The above required some work. The radius of the stock impeller was a full 1/2 inch less than the impeller I put in. I had to machine the center diameter that the impeller sits in so it was larger. However, the minor locating diameter of the new volute was larger than the stock volute so I had to add material.
I did this by machining a groove in the case and making a ring that I pressed into the case that would accurately located the volute. The ring is visible in the pictures.
Old Sep 6, 2008 | 08:18 PM
  #185
radiologue's Avatar
radiologue
Very nice work!
How much power are you shooting for. What does that car weigh?
I'll share a few more pics of mine.
Attached Thumbnails My "Z33Art" Custom Supercharger Build *PICS*-951racecar6.jpg   My "Z33Art" Custom Supercharger Build *PICS*-951racecar27.jpg   My "Z33Art" Custom Supercharger Build *PICS*-951racecar7.jpg   My "Z33Art" Custom Supercharger Build *PICS*-951racecar2.jpg
Old Sep 7, 2008 | 09:17 AM
  #186
Quamen's Avatar
Quamen
Very nice work!
Sweet!!!
My brother in law has a 951 which is quite similar. Very impressive car and I love the work!!! How much does it weigh?
Old Sep 7, 2008 | 01:30 PM
  #187
radiologue's Avatar
radiologue
weighs about 2200 lbs
3.1L stroker
makes 425whp at low boost and around 500whp at high boost
Quite frankly I'm just trying to get use to the car. My 350z has a lot more power but because the porsche is so light---man its faaaaast!
Old Sep 10, 2008 | 03:33 PM
  #188
Quamen's Avatar
Quamen
New pics of the hood before the mesh and the baffling go in on saturday!
Attached Thumbnails My "Z33Art" Custom Supercharger Build *PICS*-hood-1-medium-.jpg   My "Z33Art" Custom Supercharger Build *PICS*-hood-2-medium-.jpg
Old Sep 14, 2008 | 06:00 PM
  #189
Quamen's Avatar
Quamen
Some photos of the front end. Got the oil scavenge pump installed and working. I also got all the panels for the upper baffle that route air out the hood made. Just have to contour the two side pieces to the bottom of the hood. The back one is the only one visible in the picture.
Attached Thumbnails My "Z33Art" Custom Supercharger Build *PICS*-091408_1838-00-.jpg   My "Z33Art" Custom Supercharger Build *PICS*-091408_1847-01-.jpg
Old Sep 14, 2008 | 06:17 PM
  #190
Cux350z's Avatar
Cux350z
hatersgonnahate
damn, was hoping for power adder dyno.
those vents arent going to weaken the hood near the latch?
oh btw:
when you have a moment, please leave itrader for the fenders
Old Sep 14, 2008 | 06:57 PM
  #191
Quamen's Avatar
Quamen
oh btw:
Dyno will be this weekend (FINALLY!!!) if all goes this week and I can get the base map tuned for the power adder.
No latch on the hood. Just hood pins so it really didn't weaken it as much as you think. The hood is still quite rigid suprisingly.
Old Sep 14, 2008 | 07:30 PM
  #192
JonnyC's Avatar
JonnyC
Sweet, hopefully I'll be back in time Sunday to check this thing out!
Old Sep 19, 2008 | 01:33 PM
  #193
Cux350z's Avatar
Cux350z
hatersgonnahate
bump! hoping the dyno is still scheduled for this weekend. Anxious to see the results.....
Old Sep 19, 2008 | 11:16 PM
  #194
Quamen's Avatar
Quamen
Here you go!
https://my350z.com/forum/forced-indu...er-414whp.html
Old Sep 22, 2008 | 06:28 PM
  #195
Quamen's Avatar
Quamen
Well as of August 19th I was able to finally dyno the car!
I hit 394 intially on the dyno with conservative street tuning of both the fuel and timing maps. I then proceeded to install my new toy.... the 928M V-Plus Impeller!! This things is absolutely amazing!!!
I logged my boost for both the stock impeller and the new impeller and saw just over a 15% gain in boost from 2000rpm to redline with the same pullies!
When the day was all said and done I pulled 414whp/355ft-lbs with the new impeller in on a conservative tune just like the stock one for comparison reasons.
However, after getting aggressive with the timing I hit 440whp but started to sputter up top from knock counts. I was running some fairly aggressive timing so it could just be that I need higher octane fuel.
Overall I am happy to finally be done with it and have 99% of the work done finally!!!
Later this fall I should be coming back with the 928M Boost Limiter Valve on along with a smaller pulley and some C16 in the car! Looking to hit 450whp at 10psi agian but with a fat mid-range.
<object width="425" height="350"> <param name="movie" value="http://www.youtube.com/v/Qt8YDPGLmmQ"> </param> <embed src="http://www.youtube.com/v/Qt8YDPGLmmQ" type="application/x-shockwave-flash" width="425" height="350"> </embed> </object>
My only regret was that I couldn't run more boost becuase this impeller seemed to be just getting started based on my boost graphs.
Old Sep 22, 2008 | 10:49 PM
  #196
mchapman's Avatar
mchapman
Nice work!!
Old Oct 25, 2008 | 11:27 AM
  #197
mysterymann's Avatar
mysterymann
nice work there
Old Dec 28, 2008 | 05:40 PM
  #198
Quamen's Avatar
Quamen
Not an update since the project is done.
However, I wanted to let the vendors know that I am in the market right now for rods and pistons. I am looking preferably for Eagle rods and Arias pistons. If any vendors have special deals going please feel free to contact me.
I also wanted to post some updated pictures of the 928 Race Car. Here are some pictures of the new adjustable chin splitter, adjustable carbon fiber wing, and the fully removable front clip:
Here are some pictures of our latest modification which is a completely fabricated intake manifold with a switch from mechanical fuel injection to electronic fuel injection! The manifold is actually 100% done now with a beautifully cnc engraved top welded on to it but right now these is the only pictures I have:
Again, vendors or even forum members with new rods/pistons that they are looking to sell please feel free to pm me.
Old Dec 28, 2008 | 08:49 PM
  #199
eltness350's Avatar
eltness350
The Untouchable
looks amazing as usual!! ill let u ride in mine if i can ride in yours this spring!!
Old Dec 29, 2008 | 03:00 AM
  #200
Quamen's Avatar
Quamen
Absolutely! Where in Milwaukee do you live? I'm in Franklin.
