Shop Builds Temp moving posts for some clean up of this section.
AAM Built: In-House Sleeved VQ, GReddy Twins, AAM Fuel and Exhaust: 550whp Pump Gas
Old Jan 17, 2008 | 08:47 AM
Clint@Altered's Avatar
Clint@Altered
Default AAM Built: In-House Sleeved VQ, GReddy Twins, AAM Fuel and Exhaust: 550whp Pump Gas
Well, we just finished up another AAM In-House, Built and Sleeved GReddy Twin Car. Too bad its snowing
During the break-in period, our long-time customer Javier decided that he wouldn't be happy unless he was well into the fives on pump. So after the break-in, we stripped off the 2 and some odd inch aftermarket exhaust he was running and bolted-up our AAM 3" GReddy Down-Pipes w/ open dumps and our 3" Dual Titanium Exhaust. It always a shock what a difference a 3" turbo back exhaust makes - even with a slipping clutch! He'll be back soon for Cams and a twin-plate for 600++
Here are some the rest of the specs on the car:
AAM In-House Built and CNC Machined Stage III Block
*Darton Sleeves
*JE .020 9:0:1 Custom 1000hp Pistons
*Eagle Rods
*L19s
*AAM CNC Block Cooling Modifications #1 & #2
Stock Heads
GReddy Twin Kit and Front Mount
HKS Head-Gasket
RevUp Oil Pump
AAM Oil Pan Spacer, TB Spacer, Plenum Spacer, and return Line Kit.
AAM Oil Cooler
AAM Billet Rail Return System and Pump
*750cc RC Injectors
AAM ECU Flash
Utec EMS
JWT Clutch & Flywheel
HKS EVC VI
ENDLESS BBK
VOLK SF-Winnings
Enjoy the Pics and videos below:
15psi 93 Octane
Old Jan 17, 2008 | 08:51 AM
Ahsmo's Avatar
Ahsmo
Imakecopies
Nice numbers.
Old Jan 17, 2008 | 08:57 AM
taurran's Avatar
taurran
Nice, but definitely a bit more in that setup for sure. Needs a standalone (like me)!
I'm interested if you all had any issues running those RC 750's with the UTEC. Anything strange?
Old Jan 17, 2008 | 10:11 AM
DaveFunction2ND's Avatar
DaveFunction2ND
What's with Peak TRQ at 5800?
Old Jan 17, 2008 | 10:24 AM
eagletanggreen's Avatar
eagletanggreen
Got Track!!!!!
Coooooool!
How much does a set up like this (ball park) cost?
Did you guys fix the problem with the 3" exhausts (fitment issues). I had nothing but problems with mine, had to sell it!
Old Jan 17, 2008 | 10:28 AM
doug's Avatar
doug
i'm sure that wing will help keep the car mounted on the dyno when you guys go for more power *sarcasm*
Old Jan 17, 2008 | 10:35 AM
r0mey's Avatar
r0mey
really nice numbers smooth curve too great job
Old Jan 17, 2008 | 10:36 AM
doug's Avatar
doug
yeah i must say the dyno chart is not as bumpy and rugged as that APS TT thread everyone keeps bumping every day
Old Jan 17, 2008 | 10:40 AM
JETPILOT's Avatar
JETPILOT
Yeah.... the peak torque is strangely high RPM, and it's quite low. Usually torque is right around the HP number.
JET
Old Jan 17, 2008 | 10:41 AM
Clint@Altered
Originally Posted by eagletanggreen
Coooooool!
Hey thanks for the comments. We've made several adjustments to the design of the 3" exhaust and it now fits like a glove.
Old Jan 17, 2008 | 10:42 AM
Clint@Altered
Shortly after 3800 rpm, the JWT clutch begins to slip a bit. We'll be putting in multi-disc clutch and re-dynoing shortly. I cant wait to see what the torque is then!!!!!!
taurran's Avatar
taurran
JET
Stock heads?
Or clutch... makes sense... ^^
Old Jan 17, 2008 | 10:46 AM
Clint@Altered
Thanks! A stand-alone would allow us to turn up the power even more. As far as the 750cc injectors go, they are a chore with the Utec. But since our ECU Flash's come with injector scaling and startup/idle enhancements, we can get the Utec to work quite well with them - to the point where if the Utec goes bad, you can remove it and run off of the factory ECU to 1-2psi max.
Old Jan 17, 2008 | 10:49 AM
doug's Avatar
doug
Clint are you guys going to do a more accurate pull in 5th gear anytime soon?
Old Jan 17, 2008 | 12:20 PM
punish_her's Avatar
punish_her
With the pump gas (octane?) and 9:1 pistons, whats the psi you guys are running at to get the 550whp?
Old Jan 17, 2008 | 12:25 PM
Clint@Altered
Eventually we'll make a fifth gear pull. The JWT Clutch that is in the car now is about done. So it'll have to wait until we get a twin-plate in the car.
Old Jan 17, 2008 | 02:29 PM
JETPILOT's Avatar
JETPILOT
For that much torque I would be looking at getting a triple carbon clutch.
JET
Old Jan 17, 2008 | 02:33 PM
rr_z33's Avatar
rr_z33
hmmm guess i ordered mines before you guys fixed it. mines had some issues with fitting. the left side hangs alot lower. =/
Old Jan 17, 2008 | 02:59 PM
DanielW's Avatar
DanielW
tension anyone?
Old Jan 17, 2008 | 03:04 PM
doug's Avatar
doug
first post says 15
