Shop Builds Temp moving posts for some clean up of this section.
Stroker + twin 67mm turbos = 718whp pumpgas daily driver
Old Feb 5, 2008 | 09:34 AM
  #41
DanielW's Avatar
DanielW
veddy nice, Daniel want stroker
Old Feb 5, 2008 | 11:07 AM
  #42
Jonny Boy's Avatar
Jonny Boy
Nice build. The car looks and sounds awsome.
Old Feb 5, 2008 | 01:48 PM
  #43
failsafe306's Avatar
failsafe306
Very good job guys!
Is she burning some oil though?
Old Feb 5, 2008 | 07:29 PM
  #44
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
Nice polished Cosworth plenum.
BTW... Sorry if I missed this in another thread, but what are your impressions of the Cosworth plenum on this setup? I noticed from the dynographs that you guys aren't revving it up to 7000RPM (or more). Since it's a built stroker with your head package and the Cosworth plenum, why aren't you guys revving this motor higher?
Old Feb 5, 2008 | 09:12 PM
  #45
kevinapex's Avatar
kevinapex
Nice work Hal! Massive power, doesn't even sound like the motor is working!!Gota love a over 700 daily driver!
Enjoy it brother!!
Kevin
Old Feb 6, 2008 | 02:12 PM
  #46
Ivory's Avatar
Ivory
sweet Mike! Way to represent! the lights look fantastic on your car :P
Old Feb 6, 2008 | 06:28 PM
  #47
Dynosty's Avatar
Dynosty
Vendor - Former Vendor
The Cosworth plenum made significant gains (30-40whp) across the board. With the large powerband on this car, revving high is not required. We have tested it over 7000rpm before but it required another ecu due to the '05 G35 closing the throttle body at 7000rpm. The dynodynamics chart posted above is run to 6900rpm.
Old Feb 6, 2008 | 06:47 PM
  #48
eagletanggreen's Avatar
eagletanggreen
Got Track!!!!!
Originally Posted by Hal@IP
The ATS triple started slipping above 750whp. A graph of wheel speed vs rpm made it very clear on the dyno. Their only recommendation was "needs more breakin", but this car has been daily driven for 4 months now with this stroker + clutch...
+1
My car was slipping on the dyno at 20psi Same clutch!
Old Feb 6, 2008 | 07:44 PM
  #49
Kwame's Avatar
Kwame
FYI stroked motors typically have lower powerbands than non-stroked motors. Stroked motors have the ability to rev just as high as non-stroked motors but its just not needed as Hal mentioned earlier.
Old Feb 6, 2008 | 08:21 PM
  #50
meatbag's Avatar
meatbag
Can you get around this cutoff by any other way then replacing the ECU with something else? I have an Fcon so does this present a problem?
Old Feb 6, 2008 | 08:24 PM
  #51
Dynosty's Avatar
Dynosty
What year is your car - only the newer ones do it, and yes same thing with FCON because it does not control drive-by-wire. The easy solution is an ecu reflash to raise rev limiter, but again on this car it is not necessary due to the nice powerband.
Old Feb 6, 2008 | 08:50 PM
  #52
meatbag's Avatar
meatbag
My car is a 2005.
Old Feb 6, 2008 | 09:26 PM
  #53
eagletanggreen
Got Track!!!!!
My car is a 2005.
Had the same problem, had Sam at GTM reflash it so I can rev past 7500, also take the speed limiter and bump the idle. Best thing I ever did IMO.
Old Feb 6, 2008 | 10:10 PM
  #54
maximumsportZ's Avatar
maximumsportZ
Props guys, thats a hell of a machine.
Old Feb 6, 2008 | 10:15 PM
  #55
r0mey's Avatar
r0mey
I had the same problem with my car you can pm me if you want ill give you the answer I dont want to OT hal's thread. SOLID build hal
Old Feb 6, 2008 | 10:41 PM
  #56
JETPILOT's Avatar
JETPILOT
I don't knwo which ATS triple carbon clutch he has, but the soft compound triple clutch discs won't hold at those power levels. You will need the standard or R compound, the 1350 pp, and it sounds like you will need the CCM (carbon coated metal) flywheel and pressure plates which increases torque capacity significantly.
JET
Old Feb 7, 2008 | 07:51 AM
  #57
thawk408's Avatar
thawk408
Originally Posted by eagletanggreen
+1
WTF! I just bought this clutch! I swear if it slips I am going to break someones neck. I have the standard with the 1350 PP.
Old Feb 7, 2008 | 08:40 AM
  #58
IIQuickSilverII's Avatar
IIQuickSilverII
its not like there is much choice thawk.... ill test what mine can handle
Old Feb 7, 2008 | 08:48 AM
  #59
roncfpz's Avatar
roncfpz
Wow, that's crazy amounts of power. Great work.
Old Feb 7, 2008 | 08:51 AM
  #60
thawk408's Avatar
thawk408
If it would perform at what it is quoated to do, then it wont be a problem.
