Shop Builds Temp moving posts for some clean up of this section.
SP 350Z low boost dyno numbers
Old Aug 22, 2008 | 03:44 PM
Chris@SP's Avatar
Chris@SP
Sound Performance
Default SP 350Z low boost dyno numbers
I wanted to start a new thread on our current shop car progress, so if a mod could delete the other thread, I would appreciate
Here are the specs on our 350z
SP 3.5L (Darton Sleeves)
Headgames Race Heads
Brian Crower Stage 2 cams
CJ Motorsports Intake Manifold
SP Twin Turbo Kit 67bb
SP Fuel System (CJM Fuel Rails)
ProEFI 128pin ECU
RPS Carbon Carbon Clutch
onto the dyno numbers and vid
Pump gas (93octane)
11psi = 605rwhp
15psi = 675rwhp
110 Octane
17.4psi = 723rwhp
21psi = 790rwhp
We're very pleased with the numbers and it has a beautiful hp curve, nice and smooth.
We'll throw some C16 into it next week and turn up the boost!!
View Video on FQuick
Chris
Old Aug 22, 2008 | 03:58 PM
chopperman's Avatar
chopperman
600+ Hp on only 11 psi, wow. That car is sick
Old Aug 22, 2008 | 04:30 PM
thawk408's Avatar
thawk408
Can we have to dyno chart to see the spool and powerband? Also, whats up with all the smoke on decel?
Old Aug 22, 2008 | 05:14 PM
SoundPerformance's Avatar
SoundPerformance
Sound Performance
I will post the dyno sheet on Monday but I can say that the HP finally crests at 8400 RPM. The turbos come on strong at 4500.
As far as the smoke goes, I believe it is a combination of a bad scavenge pump along with not enough crankcase ventilation. I am still running the stock PCV valve so that may have to go!!
Old Aug 22, 2008 | 05:19 PM
Crom's Avatar
Crom
Wow..these numbers seem like stroked equivlants
Old Aug 22, 2008 | 05:23 PM
SoundPerformance
Sound Performance
Nah, the stroked guys are still ahead.....
We just have really good heads, a great intake manifold, some really big turbos and a kick *** computer to our benefit!!
I am very pleased though how the HP never falls off all the way up to 8400!!
Old Aug 22, 2008 | 05:24 PM
thawk408's Avatar
thawk408
What are you revving it out to? Whats helping it make power that high? The intake manifold and heads? Because I know those 264 BC probably are not helping very much at that high of rpm.
Old Aug 22, 2008 | 05:29 PM
phunk's Avatar
phunk
CJ Motorsports
very cool. cant wait to see some graphs. also cant wait to see how everything (especially the intake) does at the higher boost. give me a reason to pull the trigger on the casting!!!
Old Aug 22, 2008 | 05:30 PM
phunk's Avatar
phunk
CJ Motorsports
larry if you look at the PCV nipple on the back of the driver side valvecover, its restricted on the inside quite small (towards the inside). i drilled mine out to match the ID of the nipple to help vent pressure once the manifold is boosted and the PCV valve closes
Old Aug 22, 2008 | 05:41 PM
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
Very nice. Got a pic of that intake manifold?
Old Aug 22, 2008 | 05:43 PM
thawk408's Avatar
thawk408
Middle of the page.
https://my350z.com/forum/forced-indu...-update-4.html
Also, chris I would appreciate it if you left the old threads and dont have them deleted. They have some very nice information in them.
Old Aug 22, 2008 | 06:30 PM
Chris@SP's Avatar
Chris@SP
Sound Performance
Middle of the page.
Very good point! I hope the mods don't mind 2 threads
Charlies intake is doing great, and seeing the power just shoot up is a beautiful thing. Dave at headgames did an amazing job too!
I took it for a very quick blast on the street for a couple gears. HOLY CRAP!!! Feels awesome, oh and those mickey's HOOK
Old Aug 22, 2008 | 06:52 PM
thawk408's Avatar
thawk408
Now lets see how long the factory 6spd last....
Also, what turbine A/R are you running on the 67s?
Old Aug 23, 2008 | 06:39 AM
Zridder19's Avatar
Zridder19
You guys at SP are amazing!
Old Aug 23, 2008 | 12:17 PM
Chris@SP's Avatar
Chris@SP
Sound Performance
on a cold motor we made 813rwhp @21psi today
I'll get charts today.
Chris
Old Aug 23, 2008 | 12:31 PM
Chris@SP's Avatar
Chris@SP
Sound Performance
Old Aug 23, 2008 | 01:04 PM
Chris@SP's Avatar
Chris@SP
Sound Performance
HP & TQ on the last pull
Old Aug 23, 2008 | 03:37 PM
thawk408's Avatar
thawk408
What hotside A/R is being used?
Old Aug 23, 2008 | 05:35 PM
phunk's Avatar
phunk
CJ Motorsports
now i see on the green run the power goes all the way to the end at 8400. on the other runs it drops off quickly just before that. is that quick drop just where you let off the throttle?
any plans to rev it higher? only curious because id like to see how the manifold handles 9000rpm... but results are ****in rad anyway!
Old Aug 23, 2008 | 06:01 PM
SoundPerformance
Sound Performance
Yeah I probably let off a bit earlier on that pull!!
I can try going a bit higher.... just for you!!
