Shop Builds Temp moving posts for some clean up of this section.
G35 NA stroker with ITBs
Old Oct 1, 2008 | 08:02 PM
  #61
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
Originally Posted by Ahsmo
I translated the text below:
The ITB kit installed on this G35 was only intended for use on race cars. As a result, the problems Hal ran into installing them on a street car are not applicable to the application the ITB kit was intended for i.e. a race car.
After all the hype and what not, Jenvey, the ITB manufacture, has decided to build a kit specifically for use on a street 350z or G35. The kit will be on display at PRI this year.
Hal used the regular race kit on this build, not the fore mentioned street kit. If you would like a race kit, call Hal or Neal. Hal and Neal need to call me so I can give them the correct price for the race kit. The kit comes with and without an air box.
Hal did a great job with the install. He is not the first to do the install. However, he is the first to show it off on a public forum.
Hope this helps everyone
Thank you!
Old Oct 1, 2008 | 08:04 PM
  #62
r0csfinest's Avatar
r0csfinest
thanks for the translation haha
Old Oct 1, 2008 | 08:09 PM
  #63
Ahsmo's Avatar
Ahsmo
Imakecopies
no problem. No disrespect intended towards Mack Z. I am sure he is busy and what not.
Old Oct 1, 2008 | 10:52 PM
  #64
Nathan's Avatar
Nathan
Great job Hal
Are you able to tell the advance position of the inlet cam @ the 6.5 k + area.
Just a very small point, with a 86.4 stroke & 100 mm bore the capacity of this motor will be 4.069 L
Old Oct 2, 2008 | 02:58 AM
  #65
Ivory's Avatar
Ivory
I don't know if you guys took away the right information from this thread, or from the simple video I made.
The install is simply awesome, the fit and finish is top notch with dedication for it to happen. The tune is amazing for a race motor and a first application of this kit, Hal pulled it off without major issues. The idle is smooth as anything, which was my primary concern for a high rev motor with aggressive cams. Need I mention the kind of strings Greg needed to pull for my motor to be done in time.
So if there are any people out there with a doubt, I suggest you come up here to Rochester and I'll show you personally what I mean.
Old Oct 2, 2008 | 03:59 AM
  #66
escobar929's Avatar
escobar929
amazing work!
Old Oct 2, 2008 | 07:23 AM
  #67
buzzardmountain's Avatar
buzzardmountain
Epic post....
Old Oct 2, 2008 | 08:37 AM
  #68
Ivory's Avatar
Ivory
Sound clip videos
Old Oct 2, 2008 | 07:36 PM
  #69
mchapman's Avatar
mchapman
Originally Posted by Nathan
Great job Hal
They are running the Haltech so they can set cam timing values themselves.
Old Oct 3, 2008 | 10:42 PM
  #70
Nathan's Avatar
Nathan
I realise that Murray, but I would like to know what value they set the inlet cam at the higher revs. Rememering the stock ECU has the cam set at full retard at a little over 6K .
Old Oct 3, 2008 | 11:06 PM
  #71
lgear080's Avatar
lgear080
A moment of silence for teh SIKNEZ! amazing. amazing.
So... safe for street use? I read thru the posts, but
missed the point. I am stunned. Great sound clips.
Old Oct 4, 2008 | 07:18 AM
  #72
thawk408's Avatar
thawk408
SLOW DOWN THIS IS A NEIGHBORHOOD!!!! Haha jk. (its from the celica commercial)
Old Oct 4, 2008 | 08:16 AM
  #73
Ivory's Avatar
Ivory
The stock ECU is pretty much by passed except for Idle I believe.
stock ECU also have the throttle closing around top speed, that was also by passed.
Hal would know what else is still controlled by the ECU.
  #74
Ivory's Avatar
Ivory
Yeah I just did quick bursts. You can hear me braking hard after the second pass. haha.
Old Oct 4, 2008 | 08:18 AM
  #75
Ivory's Avatar
Ivory
The ITBs are not meant for street. An airbox is needed for DD. For the time being I have lots other work to do, so I don't have many chances of driving it anyhow.
Old Oct 6, 2008 | 06:01 AM
  #76
Dynosty's Avatar
Dynosty
Vendor - Former Vendor
At 6500, 2deg
At 7000, 0deg
Old Oct 6, 2008 | 11:20 AM
  #77
GTM's Avatar
GTM
Nice Job Injected, it definetely looks good! In for final tune after the owner gets his other work done, I know how that goes.
Old Oct 6, 2008 | 04:13 PM
  #78
Nathan's Avatar
Nathan
Originally Posted by Hal@IP
At 6500, 2deg
At 7000, 0deg
Thanks, It's a little less than I thought it would be.
Old Oct 6, 2008 | 09:44 PM
  #79
NiZMo1o1's Avatar
NiZMo1o1
Mac Aka MadMax is always working on something at the shop , most of you dont know but hes also British/Jamican, Therefore I that translation was on point Ahsmo.
Old Oct 7, 2008 | 07:15 AM
  #80
John@z1's Avatar
John@z1
Z1 Motorsports
Very nice work IP.
