Shop Builds Temp moving posts for some clean up of this section.
G35 NA stroker with ITBs
Old Nov 12, 2008 | 10:51 AM
  #121
thawk408's Avatar
thawk408
Originally Posted by Ivory
But then our base on the DD is around 219 for a stock Z. There is room on the percentage when comparing to the average.
Im sure I will strap it on a dyno and compare it with Z1 sometime to get a better relative scale.
Its general knowledge that it is around 10-12%
Old Nov 12, 2008 | 11:13 AM
  #122
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
there really is no comparison that can be drawn from one to another...it is all relative to the exact dynos being compared (not the types of dyno's, but the exact dynos). Some DD to DJ will be 11-12%, some will be higher, some will be lower. It's all relative to how those 2 dyno's are setup in the first place
Old Nov 12, 2008 | 11:38 AM
  #123
4SHIZZIL's Avatar
4SHIZZIL
agreed 100%
I put down 405 on a dyno pack and a 360 DDynamics TTZ crushed me... although he also had 100ft lbs of torque more also....lol
lol
Old Nov 12, 2008 | 11:54 AM
  #124
GTM's Avatar
GTM
Vendor - Former Vendor
+ a million
Old Nov 12, 2008 | 01:19 PM
  #125
Ivory's Avatar
Ivory
+1 then... +1 again.
That's why it'd make more sense to have a dyno day or something.
Old Nov 12, 2008 | 01:20 PM
  #126
Ivory's Avatar
Ivory
Originally Posted by buzzardmountain
What's the time frame of the air box???
Jenvey is making one right now...as to ours it might just take longer.
Old Nov 12, 2008 | 01:28 PM
  #127
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
I'm looking forward to seeing Jenvey's airbox design. Then maybe we can see these ITB's used in an FI application.
Old Nov 12, 2008 | 01:29 PM
  #128
redline06's Avatar
redline06
wow ITBs are so sexy!!!
Old Nov 14, 2008 | 07:49 AM
  #129
zxman69's Avatar
zxman69
The New airbox design will be on display at the PRI show in Orlando. The kits will be available a couple of weeks after the show. Although the ITB's can be used for FI the airbox was not made with this in mind and are not made to withstand boost. You would have to make a custom box for you application. I believe any competent shop can fab up an aluminum airbox for boost, and there are several that show their ability on here everyday.
Neil
Old Dec 1, 2008 | 04:29 PM
  #130
scmtkings4's Avatar
scmtkings4
would you be able to reach 350whp (DJ) without the help of ITB?
Im looking to do an N/A stroker in the future but im not so sure i want to go with ITB
Old Dec 1, 2008 | 04:35 PM
  #131
Kwame's Avatar
Kwame
It maybe possible but I'm not aware of anyone who has done so yet.
Old Dec 1, 2008 | 06:37 PM
  #132
Ivory's Avatar
Ivory
The answer is how much money do you have saved up and how far are you willing to go?
What you need other than the stroker without the ITBs would be very aggressive cams (cosworth maybe) and larger valves. We didn't do the valves which would've netted us a good amount of hp. Ultimately if you push the compression up to race spec you could attain 350whp without ITBs.
Old Dec 2, 2008 | 05:20 AM
  #133
350Zenophile's Avatar
350Zenophile
Cosworth just built a 360whp/290wtq DE for the syntec topshop challenge. Give them a ring and ask them how much it'll cost to duplicate.
Old Dec 2, 2008 | 06:39 AM
  #134
turismo's Avatar
turismo
Im pretty sure you can make this power n/a with a 4.3 high compression stroker, a decent intake manifold, cams and head work.
Old Dec 2, 2008 | 08:09 AM
  #135
rednezz's Avatar
rednezz
Originally Posted by thawk408
That is a farily high replication percentage. 10-12% is more inline when converting DD to DJ.
That also depends if the DD is an uncorrected number or corrected or not. If the DD is corrected to simulate a DJ numbers you will be way off if you add 10 to 12% more to the already corrected number.
Old Dec 2, 2008 | 09:03 AM
  #136
thawk408's Avatar
thawk408
True DD are not corrected. And yes I am aware of this as simple math is not difficult.
Old Dec 2, 2008 | 12:39 PM
  #137
rednezz's Avatar
rednezz
I just mentioned that because some people on this board have claimed a DD dyno corrected to represent a DJ as a uncorrected DD dyno.
Old Dec 3, 2008 | 09:21 AM
  #138
scmtkings4's Avatar
scmtkings4
hmm this is just for street use/93 octane, so race spec is out of the question.
do you have any vids yet? I'd like to see how this car sounds
Old Dec 3, 2008 | 09:46 AM
  #139
Ivory's Avatar
Ivory
https://my350z.com/forum/6374955-post68.html
Old Dec 3, 2008 | 10:10 PM
  #140
scmtkings4's Avatar
scmtkings4
sounds sick man.
idle lope?
