Shop Builds Temp moving posts for some clean up of this section.
Sound Performance G35 TT Phase II: (Upgrades)
Old Jul 27, 2010 | 09:09 AM
  #61
thom000001's Avatar
thom000001
There are 2 track that will basically let you run anything at any ET/mph lol. Reid@SP went this weekend and ran 10.67@137 in his supra with just long pants, a tshirt, and seatbelt, they didn't blink an eye.
My G is 3655lbs...ugh
Tom
Originally Posted by str8dum1
That would be great. Intense couldnt do it with more HP (But they had soo much extra weight over a stock bodied G35) nor could Blackbird (but thats probably due to lack of seat time in his case). . Wish we could get the G's down to 3200 like the Z guys are with full interior.
Will your local track let you continue to run without a cage into the 10s? Pretty sure we get booted after 1 pass.
Old Jul 27, 2010 | 10:19 PM
  #62
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
^ Which two tracks would those be?
Old Jul 28, 2010 | 06:20 AM
  #63
thom000001's Avatar
thom000001
Byron Dragway, and US 41 allow....pretty much anything...
Great Lakes Dragway has really cracked down in the last few years, and RT66 doesn't let anything slip by.
tom
Old Jul 28, 2010 | 08:55 AM
  #64
Alberto's Avatar
Alberto
Cranky FI Owner
FWIW my Z with the TT kit, TD 3" exhaust, slicks out back, full interior is 3280lbs without me in it.
Whats your G without you again?
Old Jul 28, 2010 | 09:57 AM
  #65
binder's Avatar
binder
is that kentland/morocco strip you are talking about?
The rundown seems like forever on that track. I watched a few nationals races there and also did a couple stuntshows there on the bike.
Old Jul 28, 2010 | 09:58 AM
  #66
thom000001's Avatar
thom000001
3655 w/me and no fuel....so based on that time I'd say
3455 w/o me and no fuel.
Next time I'm near scales I'll weigh it.
Tom
Old Jul 28, 2010 | 11:08 AM
  #67
str8dum1's Avatar
str8dum1
i think Hal's was about 3200 as well. The Gs are 2-250 lbs heavier, so that right there costs us about 0.2s.
Old Jul 28, 2010 | 11:32 AM
  #68
binder's Avatar
binder
we could loose 50lbs on the driveline by having someone make us a nice carbon driveshaft like the z's.
Old Jul 28, 2010 | 12:35 PM
  #69
str8dum1's Avatar
str8dum1
Nah I wouldnt go to carbon DS. plus it wouldnt be 50 lbs. Ours is less than 50lbs to begin with.
they got rid of the carbon DS
http://www.injectedblog.com/nissan-350z/
Old Jul 28, 2010 | 06:36 PM
  #70
binder's Avatar
binder
ah, aluminum would be nice.
Ours weighs quite a bit between the 2 halves. Maybe not 50lbs but it's heavy enough that it gets tiring trying to hold it with 1 hand while putting bolts in.
Old Jul 28, 2010 | 08:09 PM
  #71
IIQuickSilverII's Avatar
IIQuickSilverII
i guess u 2 can always compensate the effects from weight by running bit more boost
Old Jul 29, 2010 | 06:42 AM
  #72
thom000001's Avatar
thom000001
gotta love turbos
Old Jul 29, 2010 | 11:41 AM
  #73
binder's Avatar
binder
as long as traction holds at the higher hp
Old Aug 2, 2010 | 10:37 PM
  #74
Blackbird CPV35's Avatar
Blackbird CPV35
Def seat time, the damn track keeps kicking me out after 1 pass, so I only have had a handful of passes this year.
I have no plans to put a cage in either so it looks like im f-ed
Old Aug 3, 2010 | 06:17 AM
  #75
str8dum1's Avatar
str8dum1
^what were you other passes like? any higher traps? you 2-stepping off the line? at what rpm?
Old Aug 3, 2010 | 05:38 PM
  #76
Blackbird CPV35
11.1 11.2's they are all in that range. I am still feeling out the car and learning how to 2 step it. Launching this car is hard as fawk
Old Aug 4, 2010 | 10:21 AM
  #77
binder's Avatar
binder
amen, is it our clutches that does it to us? i've had this car for 4 years and still can't launch it half as good as a camaro.
Old Aug 4, 2010 | 10:55 AM
  #78
thom000001's Avatar
thom000001
I think its a combo of the clutch, engine/tq delivery, traction, etc (well of course it is right).....but Also I think its the drive by wire!
I know SP was having a hard time getting 100% throttle on the first 9 sec passes due to the factory ECU cutting throttle after a burnout.....so with my little advice of "hey restart the car after the burnout".....BAM 100% throttle on next pass (and a 9.8 I believe). (I learned this one from bwicked).
It seems that the facotry ECU (regardless of what aftermarket computer you are controlling rest with), will intervene at the most in oportune times. The VDC will cut throttle from 100% after it is called for use, and it takes like 4 or 5 full throttles to get 100% back.
So maybe try that, after your burnout, turn the car off and on again. Or look at a whole new speed sensor setup (ugh). Or to start, log your throttle position (both pedal and TB for the entire pass).
Tom
Old Aug 4, 2010 | 11:45 AM
  #79
Blackbird CPV35
Ive actually had times where the speedometer stops working after the burnout until I restart the car.
Old Aug 4, 2010 | 12:09 PM
  #80
thom000001's Avatar
thom000001
See, I might be on to something here!!!!!!!! Me and my noodle hard at work......
Tom
