Shop Builds Temp moving posts for some clean up of this section.
The Build BEGINS! Gamermodz/GReddy/S&R Z goes under the knife!
Old Nov 18, 2010 | 10:17 PM
  #101
midz350's Avatar
midz350
That is crazy man..GL
Old Nov 19, 2010 | 04:07 AM
  #102
Cux350z's Avatar
Cux350z
hatersgonnahate
whats the TQ numbers?
Old Nov 19, 2010 | 04:32 AM
  #103
neverenough's Avatar
neverenough
Originally Posted by GAMERMODZoCOM
803rwhp, 15lbs of boost, fuel pump maxes out :-(
Getting new fuel pump tomorrow, Saturday or Sunday continue forward!!!!
Very nice! What is your max whp for your pump gas tune? I assume the 803whp was made on race gas. Can't wait to see the end result.
Old Nov 19, 2010 | 04:36 AM
  #104
0jiggy0's Avatar
0jiggy0
Nice, nice.
Old Nov 19, 2010 | 06:19 AM
  #105
str8dum1's Avatar
str8dum1
what kinda dyno? are you going to use a weldon pump now?
bump it up to 25psi and go for 1000whp.
Old Nov 19, 2010 | 07:54 AM
  #106
Durdan's Avatar
Durdan
it's a land&sea dynomite
Old Nov 19, 2010 | 08:09 AM
  #107
GAMERMODZoCOM's Avatar
GAMERMODZoCOM
Yes, that number was on C16.
We were tuning pump and were up to 595 at under 10lbs of boost and we ran out of gas. Rather than go get more pump gas, we just put the c16 in and continued.
Once we get a bigger pump we can continue with both tunes.
Time to go find a pump locally!
Old Nov 19, 2010 | 05:38 PM
  #108
GBoger's Avatar
GBoger
tq #'s?
Old Nov 19, 2010 | 06:45 PM
  #109
GAMERMODZoCOM
Originally Posted by GBoger
tq #'s?
643
Aeromotive Eliminator fuel pump will arrive tomorrow so we should wrap up this tune and the big number by the end of the weekend.
Old Nov 19, 2010 | 07:04 PM
  #110
03threefiftyz's Avatar
03threefiftyz
Although I know we have had our back and forths.....I am glad to see you wrapping up your build. Like I've said though.....making the hp is the "easy" part.....putting it to the ground effectively will be the tough part. Take some vids of your car on the dyno for the masses...
Old Nov 19, 2010 | 07:46 PM
  #111
GAMERMODZoCOM
As I said before, the big number is only for glory. That power is useless on for what I am doing.
The aeromotive eliminator fuel pump is arriving in the morning and then we just need to install it. So either tomorrow or sunday we should have it up. I would have had video of the 800 but it was 3am and I was too tired.
Old Nov 20, 2010 | 08:33 PM
  #112
blueper4mancez's Avatar
blueper4mancez
awesome build bro . this make me want to get back into the game . congrats on such a sick car .
Old Nov 21, 2010 | 04:55 AM
  #113
Crom's Avatar
Crom
600 at 10psi.... thats awesome....
Old Nov 21, 2010 | 05:00 AM
  #114
GreenGoblin's Avatar
GreenGoblin
In for the glory number
Old Nov 22, 2010 | 05:35 AM
  #115
S&R Performance's Avatar
S&R Performance
Vendor - Former Vendor
Taylor and the guys in the back really put this car together well. It's solid and making some excellent power. New pump will be in and then we go for the gold!
Old Nov 22, 2010 | 06:22 AM
  #116
str8dum1's Avatar
str8dum1
which pump controller are you using? thats a road course powerband? good luck with that. thats as laggy as my drag setup.
643
Old Nov 22, 2010 | 08:04 AM
  #117
GAMERMODZoCOM
We are now using the aeromotive iliminator.
Keep in mind, we only tuned on fuel. We have not started playing with the cams or anything. The cams are what will get the turbo's spooling up much faster.
Are you ready to loose your #1 spot on the top 50?
In all seriousness, it's going to be quite interesting to see what a completely built HR ends up doing. You DE guys had thousands of more options and years more of R&D on the parts available. Had I known then, what I know now, I would have purchased a rolling chassis and done the build with a DE/Rev up motor. Then again, doing it to a NISMO is kinda cool too.
Old Nov 22, 2010 | 08:12 AM
  #118
GAMERMODZoCOM
Also, once again, this big number is NOT what we will use at the track. We will only use about 650hp at the track and it will be tuned completely different.
Old Nov 22, 2010 | 09:57 AM
  #119
str8dum1's Avatar
str8dum1
hopefully the cam timing really does help your spool.
20% more displacement should have tons more trq/power under 5000 than the 3.5L. Esp with heads that are flowing 37% more than stock.
Originally Posted by S&R Performance
Old Nov 22, 2010 | 10:32 AM
  #120
GAMERMODZoCOM
hopefully the cam timing really does help your spool. not much area under the curve under 5000 rpms. you're gonna have to rev the **** outta that for road racing.
20% more displacement should have tons more trq/power under 5000 than the 3.5L. Esp with heads that are flowing 20% more than stock. I mean thats the entire reason going with that big sleeved stroker.
The only reason we even put larger compressor wheels in them was because of the displacement differenece. We knew that we would be able to spool them quickly off the stock cams (when adjusted correctly) but Tomei finally released a set so we are on their cams now.
What size turbo's are you running? 42R's? Ours are little 20G's with 60 - 1 compressor wheels which will be easy to spool once the cams are adjusted.
