Old Mar 17, 2016 | 09:13 PM
  #11021
n0smoke's Avatar
n0smoke
Managed to throw on my spacers- really pleased with the results in the looks department. I can't help but feel a little anxious knowing they're down there though. I know I'm going to be a little overzealous checking up on them the next few weeks
just to clarify for anyone interested:
Bilstein B8
Swift Spec-R Sport springs 1.2"(F), 1.0"(R)
18X8.5" @ +33mm (4)
245/40/18(F), 265/40/18(R)
20mm front spacer (B2AutoDesigns)
25mm rear spacer (same)
Pics:
Spacers appeared to be of good quality- and I'm always appreciative of a sugary taffy.
*excuse the blurry dusk pics. The cracked glass that covers the camera lens on my Note 3 allows humidity in- should really invest in a camera one of these days.
Old Mar 18, 2016 | 09:18 AM
  #11022
mg23's Avatar
mg23
wow looks clean as hell
Old Mar 18, 2016 | 02:19 PM
  #11023
Spike100's Avatar
Spike100
n0smoke Great selection on shocks and springs! The drop looks perfect, and the spacers flush-up the setup. Very Nice!
Old Mar 18, 2016 | 04:27 PM
  #11024
Bilstein B8
18X8.5" @ +33mm (4)
Pics:
That looks GREAT n0smoke!! Perfect fitment. And car is clean as always!! Good reference for spacer sizing too!
Old Mar 18, 2016 | 04:58 PM
  #11025
How do those 265 tires fit on the 8.5 wheels? I was thinking about running 235/40 fronts 255/40 rears... I have the touring model blues so I need to worry about the traction control.
Old Mar 18, 2016 | 06:29 PM
  #11026
1.2 factor..... (8.5 * 25.4) * 1.2 = 259mm.... round up to 265 is fine. Not optimal but close enough for jazz.
Old Mar 18, 2016 | 06:48 PM
  #11027
n0smoke's Avatar
n0smoke
Thanks for all the kind words. As much as I like the way it looks, the way it DRIVES is really what's sweet. Everything you've read about the Swift/Bilstein setup is true- more relaxed over bumps and road undulations, more controlled when pushing it. Best of both worlds!
The 265's work fine for me- there is a really slight bulge, but not big enough to look sloppy or worry about. They stay exactly at the air pressure I set them at with the occasional fluctuation of a pound or two in accordance with temp- as do the fronts.
Old Mar 18, 2016 | 09:34 PM
  #11028
Smile
Finished my hood for now. Still in the air if I want to do the section behind the vent
Old Mar 19, 2016 | 08:00 AM
  #11029
jg021v's Avatar
jg021v
Default Me, too and tunnel brace
Originally Posted by rustyschopshop
Finally got my rear subframe connector brace from ultra racing. Ever so slightly heavier then the OE brace. Gives more clearance for accessing the exhaust flanges which is a major plus that i was not expecting. Definitely looks alot better then the damaged brace that I bought the car with.
I just got my UltraRacing Sub and Tunnel Braces.
Old Mar 19, 2016 | 11:59 AM
  #11030
chari's Avatar
chari
New lip spoiler installed today
Old Mar 19, 2016 | 04:13 PM
  #11031
:suici de::su icide:
:suici de:
And then I couldn't get done before dark...
Tally....
12+hours
$80 in drill bits (many broken)
Ruined some clothing
Dremal easy lock cut off disks
Drill cut off disk
Angle grinder cut off disk
Sawzall
Sanity
Health
wifey had to make a bonus trip to dumpster for more drill bits
Couldn't get new exhaust aligned before dark...
Told wifey im calling the junk yard to take car away... It didn't go over well... Hopefully finish tomorrow...
Old Mar 19, 2016 | 06:52 PM
  #11032
rustyschopshop's Avatar
rustyschopshop
Glad to hear you finally got it out. To try and make you feel better.... Just imagine how much money you saved if you had to pay someone to take the old one out. Now you can smile and think of the brand new shiney one that is going in
Old Mar 19, 2016 | 06:55 PM
  #11033
rustyschopshop
I have though about getting a heavier duty tunnel brace but is at the bottom of my to-do list. There is actually another brand that I was wanting to go with once I bite the bullet. Can't think of the name at the moment but saw it on RHDjapan website. Not sure if I like the ultra racing mounting on the tunel brace. Either way it is far stronger then the factory. Gratz on the install.
Old Mar 19, 2016 | 08:18 PM
  #11034
CJM's Avatar
CJM
Finally got the new wheels on the car after refinishing them. Rather pleased with the result and such a rare set of wheels. Now to finish this vinyl wrap...
Old Mar 19, 2016 | 08:57 PM
  #11035
HRMoneyPit's Avatar
HRMoneyPit
Told you not to give up
Old Mar 19, 2016 | 09:14 PM
  #11036
NissanZcrazy's Avatar
NissanZcrazy
Thing is,if he had of taken it to a shop they would have had torches to heat up/cut all the rusted nuts/bolts.Which would have made everything alot easier!!.Generally speaking a shop will charge 1hr labour for what you did
BUT then you don't get the satisfaction of working on your own car.
FYI they sell mini acetylene torch kits which makes exhaust work a piece of cake
Old Mar 19, 2016 | 09:20 PM
  #11037
NissanZcrazy
Looks great!,I'm going to have to look into one of those.Really cleans the underbody up
Old Mar 20, 2016 | 12:24 AM
  #11038
SonnyWu's Avatar
SonnyWu
Looking good n0Smoke! Is that the original paint?
Old Mar 20, 2016 | 06:51 AM
  #11039
QuintonC's Avatar
QuintonC
I like it, I'm unsure about that rear portion behind the vent as well. Looks kind of like the ZL1 hood with the way it's wrapped.
Old Mar 20, 2016 | 08:19 AM
  #11040
HRMoneyPit's Avatar
HRMoneyPit
Did my coilovers and Akebono but failed and bleeding the brakes cause they don't work unless I pump twice every time I need brakes. Smh
Waste of 80 worth of Motul
