Searching for new clutch set up. Need some input fellas
#42
If you have the money and want to hold the power...ATS across all damn day.
Hit up RHDjapan for the best price ( 800 lower that CZP, 400 lower than others) You will pay import fees but its not much. You will be about 2100 otd. You will need a new TOB and sleeve from nissan which is another 100.
http://www.rhdjapan.com/ats-carbon-t...33-vq35de.html
That is what I swapped to and love it. Hated OS giken with light flywheel.
MeanZ runs carbonetics which is the same as ATS...but carbonetics no longer exists.
#44
Getting close to installing my Ats triple. Want to know if the stock sleeve that throughout bearing is pressed on to will work also a factory bearing. Thxs
#48
I installed the a Twin ATS, it's very nice. And it required a different Nissan sleeve. If you look on the website it shows what is required for your paticatular setup.
Easy install, just take your time and make sure you have the correct sleeve and bearing.
Install the parts in order just like it came from ATS.
Break in is about 800-1000 miles in stop and go traffic, no super hard driving.
Hope this helps
Hope this helps
Cux350z (06-30-2016)
eZg (07-02-2016)
#52
Hopefully someone see this and can chime in and explain what these washers are for and where they go. Been looking over the manual and says nothing about these.
#56
FYI, if anyone is curious the ring/washer that comes with the ATS clutch goes on before you press bearing on. So sleeve , ring, press bearing. This is what RHDJAPAN got back to me with!! Might have been understandable if directions were in English!! Anyway that's how it goes so guess I will be pulling Trans off to install. Lol
