How To Repair 5th Bow Motor, with photos.
Old May 21, 2018 | 11:41 AM
  #201
350zconvert's Avatar
350zconvert
I have a 2004 350z. The top closes ok, but when opening the top after at has been closed for a few days...the lid goes up 1/4 of the way and stops. I bump the switch two more times and it goes all the way and works fine the rest of the day. Sounds like I need to replaces brushes in the two convertible top Motors. Are the brushes the same size and is there a video out there showing how to remove the motors? What is 5th bow? Is there a 1st, 2nd, 3rd and 4th bow??
Old May 22, 2018 | 10:27 AM
  #202
Ivan Youroff's Avatar
Ivan Youroff
According to service manual to access roof actuators one needs to uninstall roof assembly. It's like a first step in the guide. However the same is true for 5th bow motor, which people learned to remove without even touching the roof assembly itself.
I have similar symptoms to yours, and replacing brushes 5th bow motor didn't fix help much, so the only option left is roof actuators, but even after reading service manual and looking at it on the car I got no idea how to replace them without removing the roof completely. Let me know if you figure out the way.
Old May 22, 2018 | 01:06 PM
  #203
zakmartin's Avatar
zakmartin
Hey Ivan, what part of Seattle do you live in?
Old May 22, 2018 | 03:45 PM
  #204
Ivan Youroff
Green lake
Old May 22, 2018 | 04:00 PM
  #205
msk59's Avatar
msk59
5 Year Member
I am new to the forum and have a convertible 2006 350Z with 6 speed MT. The car is in mint condition with low miles and I am trying to keep it clean.So reading all I can to learn about the convertible top. Is there a procedure on how to grease those areas in order for the top to stay functional?
thank you.
Old May 22, 2018 | 04:03 PM
  #206
Ivan Youroff
thank you.
I believe the discussed situation cannot be prevented by greasing or anything like that, it's just the way brushed motors work — brushes wear out and the only way to save the motor is replacing them.
Old May 22, 2018 | 04:15 PM
  #207
msk59's Avatar
msk59
5 Year Member
thanks i understand that. My car is 2006 and has only 51K on it. the previous owner kept it in the garage and looks like trunk was never used. In reading one of these posts someone suggested to keep the linkages lubricated every few years or so to keep the top functioning properly. Motor issues I understand
I check the elastic straps and they are not that elastic so i will be replacing those soon. Will check with the dealer to see how much they charge to replace or other local upholstery shops here in Tulsa area.
Old May 24, 2018 | 06:23 AM
  #208
350zconvert
The motors can be removed by removing 2 bolts and 1 nut. Very simple. Will post pics when brushes come in this week and I re-install motors. Nissan will only sell you an "assembly" which has motor installed on part of the convertible top frame work, which would be a LOT more intense.
Old May 24, 2018 | 06:27 AM
  #209
350zconvert
Old May 24, 2018 | 11:59 AM
  #210
Ivan Youroff
Wow, that'd be highly appreciated! Could you also share brushes dimensions for these motors? And where did you order them?
Old May 27, 2018 | 04:19 PM
  #211
Ivan Youroff
A tiny update on 5th bow motor brushes dimensions:
8-10 is approximated length of the new brush, I installed 10mm and it barely fitted: the spring could barely reach the end. Of the brush.
Also to note that the material is not a regular graphite, rather some mix with copper or some other metal.
Old Jun 7, 2018 | 06:59 AM
  #212
simioh's Avatar
simioh
Hey, sorry for bringing up an old thread, it seems like it was very detailed with the picture explanations but the pictures don't show up. Is it just me, or were the pictures taken down or something?
Old Jun 8, 2018 | 02:10 PM
  #213
sluggoZ's Avatar
sluggoZ
I can help you..PM me your email address.
Old Aug 1, 2018 | 01:52 PM
  #214
mkubi007@gmail.'s Avatar
mkubi007@gmail.
Where did the pics go? Is there another site they are on? I would love to see them.
Old Aug 22, 2018 | 06:48 AM
  #215
Zhelpneeded's Avatar
Zhelpneeded
I'm not able to see the pics from this post. Are they still available? Thanks
Old Sep 16, 2018 | 04:01 PM
  #216
VictorBravo's Avatar
VictorBravo
I recently had my 5th bow motor rebuilt by a guy in Florida. He did a great job. I found him on eBay. I just posted a video on Youtube describing my reinstall of the motor. It is a pain in the *** but hopefully, the video will help make the pain easier. Just remember how much you are saving doing this yourself.
Old Sep 17, 2018 | 06:14 AM
  #217
Zhelpneeded
I also had my motor rebuilt by professionalserviceinc. I was fortunate enough to find his link on ebay.com. The turn around was phenomenal. I had to glue a Phillips head socket into a socket in order to the back screw out. I wouldn't hesitate recommending this repair. The cost of a new motor is ridiculous.
Old Oct 12, 2018 | 03:04 PM
  #218
Tall_Larry's Avatar
Tall_Larry
What happened to the photos?
Old Jan 7, 2019 | 04:33 PM
  #219
Dlwarre's Avatar
Dlwarre
sorry I don't see any pictures
Old Jan 7, 2019 | 04:37 PM
  #220
Dlwarre's Avatar
Dlwarre
I know this is an old thread, but do you know where I can get access to the directions for gaining access to the 5th motor and replacing it?
