QTEC: electronic controlled exhaust bypass valve
Old Sep 2, 2005 | 01:16 PM
first350's Avatar
first350
Default QTEC: electronic controlled exhaust bypass valve
Does anyone have experince with:this:http://www.quicktimeperformance.com/QTEC/
I'd plan to put it between the Y pipe and Catalytic converter...I'm assuming the OEM ECU would be able to richen up the A/F enough to compensate-right? (The only other mod I'll have is an intake)
I'm thinking of ordering one for an install, but heard that a lot of these type of units will loose their seal over time...I really don't want to be hearing a constant exhaust leak.
thanks!
Old Sep 2, 2005 | 02:12 PM
Havok_RLS2's Avatar
Havok_RLS2
Ummm... No. If you really think about it I'm sure you can figure out why this is such a bad idea for so many reasons. Regardles of what you might hear about everyone wanting or "Needing" a "Free flowing" exhaust. Fuel injected car do need some amount of back presure to work properly. Besides, since you live Cali, I know for a fact it's illegal as Hell. Oh! And it'll also sound like ****. It's still a V6.
Old Sep 2, 2005 | 02:21 PM
taurran's Avatar
taurran
Anyway, yes, there are a few people on these forums that have installed this mod.
I wouldn't suggest doing it on an NA z as the above poster was correct that some backpressure is good on a NA fuel injected car. But, it's definitely something that would be interesting on a high output turbocharged motor where full 3in piping is just not adequate.
edit: The WRX drivebys with the 80's butt rock is a great touch.
Old Sep 2, 2005 | 02:37 PM
Havok_RLS2's Avatar
Havok_RLS2
Thanks for correcting me taurran. I just assume that his Z wasn't FI. So with that been said..
FI = Good idea
NA= Bad Idea.
Old Sep 2, 2005 | 05:22 PM
first350's Avatar
first350
what about after the cat?...my sports cars have all been FI, so I'm in new terroitory with the Z.
thanks for the help!
Old Sep 2, 2005 | 07:03 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
Fujitsubo makes one that to put in the mid pipe...
it works fine on NA and FI
of course, when it is up, you are loosing flow / hp...
Old Sep 2, 2005 | 10:18 PM
first350's Avatar
first350
hummm...here's why I was thinking of getting the Qtec:
1) Increase in HP & TQ
2) I can have the car be quite when needed. (I don't like to distrub my neighbors)
Any thoughts on how to do this? Is there much power to be gained by freeing up the exhuast on a NA?
thanks!!
Old Sep 3, 2005 | 02:51 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
not much power to be had at all....exhausts on these cars are more of a styling mod and less of a performance mod till you do the ancillaries like cams, etc etc.
Biggest resitriction in the exhaust is the cats and Y pipe.....dumping the exhaust post Y pipe and pre mid pipe is going to net you a TON of noise...and nothing else
MM'08_350Z
Apr 22, 2021 09:42 PM
sales@czp
Sep 23, 2019 03:30 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
