Lower Plenum Porting Question?
I have my upper and lower plenum off of the car to finish polishing them. I was thinking about the SSV plenum and how it looked with the tubes running directly into the lowest plenum piece. Why can't the lower plenum be shaved out? Instead of porting each of the the runners, take the SSV approch and get rid of them all together. Maybe I don't know enough about what I'm talking about but it seems the SSV gets really good gains and all it appears to do is cut out all of the channels our plenum has inside of it. All our plenum is an air chamber with channels made out of cheap cast aluminum, tell me what I'm missing? Whats are the channels for? Why are different sizes? What would happen if they were ground out?
Originally Posted by ZU L8R
you mean like this? audiblemayhem did it and is gonna try and dyno it pretty soon.
JunierPhillips (Today)
Shorter runner lengths = more high end HP but it also could move your peak HP to a higher RPM, maybe even above redline.
Longer runner lengths = help with low RPM torque but higher end HP could suffer.
Its all about finding a happy medium. Im curious still, to see how audibls's cut away plenum works out for him on the dyno.
Later
Aceman
Later
Aceman
Later
Aceman
Later
Aceman
It's funny you say this....that's seems to be exactly what my butt dyno tells me. I cut the runners even with the middle one, straight across on both sides, and ported out the inside a little bit. I also cut the tops off of the outer 4 runners. I filed most of it out to smooth it down. HACKSAW and files and a dremel....5 hours later I had the car back up and running.
![Smilie](https://my350z.com/forum/images/smilies/smile.gif)
So you live right above Baltimore? You been to the dyno yet?
Later
Aceman
No, I haven't been on a Dyno yet but, I will be looking into scheduling it shortly. Pics will be up on Monday, like I said, expect to see some ruff cuts. I had a dremel, some files, a flap wheel and a couple of hours, these will not be photos of a 2 week project. I have to do more but the car is my daily driver. I think people are overthinking the lower plenum, but that's just my opinion, it's not as delicate as people think. Tomorrow I drive it Ocean City, about a 3.5 hour drive, so I'll be able to see it through all different driving conditions. So far the difference I feel is at about 4000 RPMs, it pulls much stronger. I meet up with another member on here, Momo 305Z and let him rev it a few times, he said he could see where it jumps at 4000+ rpm's. I cut the side runners straight across and cut the tops off of the 4 outside runners. I am still goining to port it out more. I keep you posted on Dyno results as soon as I get it scheduled.
If you want to know volume of runner differences you can duct tape the port hole at the gasket flange and the pcv holes inside the runner. then you stand it on edge in the sink and pour water into the runner mouth 'til full.
I found the volume to be equal thou the length seemed different. The cross section of the runner seem the same at both ends. With all that said I want to cut about 5/8" or so off all the runners for just a little higher rpm/frequency.
I want half way between the factory two styles of lower plenums with a smooth polish on the runners.
I drove it for about 8 hours total today mostly highway driving, the power seems to has increased in the 4K rpm range. Doing 70 + most of the day, I ended up getting about 21.7 mpg if anyone cares but,there were some unneeded accelerations though out the day. My idle has increased to 1K rpms and sits solid, no lope/up and down reving at idle. When I press in the clutch it's dropping to 950 rpms and then coming back up to 1000 and stays. Pics will be up tomorrow of the cuts I made, I plan on porting out the runners in the near future. I have a Sun Hyper Force on the way and then the car will be Dyno'ed. Sorry guys, this will be the first time on a Dyno so there are no previous # to compare it to. The best comparision I will be able to give is now vs. after porting.
My350z
ok guys.... screw it, it is going in tomorrow. i can tell you right now murphy if you dont have any ecu that you could have tuned that to then you lost a lot of power. i tried this about a year ago and i am just now getting around to get it in my car. i lost a lot with it in my G sedan without tuning it. i have a utec now and will put it in tomorrow. i have an acelerometer that i can see how many forward Gs i am pulling and at what rpms.
i just hope my peak hp doesnt move too high....
results tomorrow... i will be on a dyno on thurs. if i think it pulls harder then i will dyno it on. if i dont think it pulls harder than the stock on will go back on for the dyno...
Here are the photos of the cuts I did.....as you can see, I'm not working out of a machine shop, this is straight up hillbilly modifing.The first pic is before any cuts or filing was done.
With this project, it's all based on guess work right now. I welcome any feedback from anyone that is doing something like this or that can offer any usefull knowledge. As you can see, I still need to port out the runners, and I plan on smoothing things down more. The pics show the work I did in about 5 hours, more time will be spent but the car is a daily driver.
In the pics, you can see the pieces that were cut out to get an idea on how much material was removed but there was twice as much in shaving on the floor from filing and sanding everything down.If nothing else, I added air volume!
Why, after all the work done with some of these intakes, does it seem like nobody removes the letters that are cast into the intake right in front of the runners?
Something else that I find interesting is that the runners on these intakes are right next to each other, with regards to the air horns. It seems that a runner could be taking air from the one next to it, and then visa-versa when the other runner begins to draw in air.
Do you have any pictures of the intake hat (upper plenum).
