Body Exterior Body kits, grills, HID kits, etc.
Spddracer/CuztomPartZ Aluminum Engine Undershrouds are READY!
Old Oct 2, 2009 | 08:44 PM
ZSpeedPerformance's Avatar
ZSpeedPerformance
Vendor - Former Vendor
Default ZSpeedPerformance 350Z G35 Aluminum Engine Undershrouds
ZSpeed Performance Aluminum Under Shrouds
Ready to Ship with Matte Black PC Finish Or
Non-PC aluminum
Click here to purchase securely on our website
All of these Zspeed Performance aluminum shields have been road and track tested, Fit perfect and are properly designed. These are laser cut and professionally produced to perfection!
These under shrouds were developed by Zspeed Performance to protect your critical engine parts under the car and also because the cheesy plastic OEM shield deteriorates over time and usually ends up on the highway behind you somewhere.
Without the shield in place the air that comes in through your fascia should be directed into you radiator and instead will just take the path of least resistance and exit under the car instead of cooling off your radiator. Just like the upper radiator air guides keep air going through the radiator, The bottom is even more important to have in place as it is much easier for air to escape there.
The under shrouds will fit all 2003-2009 350Z's with stock front fascias and should fit any fascia that the OEM under shroud still bolts to. These have only been test fitted on stock bumpers.
These will also fit 03-07 G35 coupe/ 2002-2006 Sedans (RWD Only)
Will not fit G35X All wheel drive sedans.
The ZSpeed under shroud will help give the lower front fascia much more rigidity also, As you probably know, running without the shield in place at high speeds can do serious damage to the front fascia as it will droop down and can rip apart.
The BEST feature of all thou is that you can actually change your oil AND filter without removing the entire shroud. I have integrated a oil change access door into the shroud so all you have to do is remove 2 bolts and you have ample room to get to the oil filter and drain plug even with the GTSpec V-1 front tie bar in place. Have not test fit with the V2 tiebar but it doesn't look like it will work with it.
Weight on the entire piece is 4.5lbs, The plastic OEM shield for reference weighs in at a bit over 3lbs.
Very lightweight and much more protection!
Powder Coated, Matte Black
These are available in non-powedercoated aluminum at a lower cost
All Stainless hardware is an option for the ultimate BLING!
Mounted on 08 Nismo with OEM Front diffuser, If you don't have the OEM diffuser we make an extension for it to work without spending $500+ on the OEM piece. ZSpeed Nismo V3 Extension
Fitment
2003-2008 350Z
2003-2007 G35 Coupe
2003-2006 G35 Rear drive sedans.
This will clear the APS aluminum oil pan on the G or Z and also fits with the JWT oil pan spacer and stock pan.
If you have the APS oil pan that goes under the oil filter you may not be able to get to the filter without removing the shield.
Works with Vortech supercharger kit, Some slight pipe adjustments may be needed.
Known to fit with the Nismo V2, Charge Speed and a few others, If your stock shield can still be attached to your aftermarket front bumper this will also.
Also fits the Nismo Z's so long as you have the OEM front splitter still in place.
Click Here to purchase securely on our website!
Old Oct 2, 2009 | 09:30 PM
TreeFiddyZee's Avatar
TreeFiddyZee
Do WHAAAAT!?
You had me at hello. In for pics of the PC piece.
Old Oct 2, 2009 | 10:12 PM
350ZPK's Avatar
350ZPK
Nice piece bro
Old Oct 2, 2009 | 10:33 PM
415mm's Avatar
415mm
Professional
i'm going to have to get me one of these.
Old Oct 3, 2009 | 02:16 AM
jdmrwd's Avatar
jdmrwd
Will this clear bigger oil pan?
Old Oct 3, 2009 | 02:25 AM
DC350ZTrack's Avatar
DC350ZTrack
Just ordered mine - can't wait to have it!!!
Old Oct 3, 2009 | 05:28 AM
ZSpeedPerformance
So long as it is not lower than the crossmember itself it should fit. These can be "adjusted" to give you a bit moree clearance under the oil pan. Just bolted on there is a little over 1" of clearance between the stock pan and the shield. I adjusted it to gain almost another 1" of clearance.
Old Oct 3, 2009 | 09:02 AM
JET MECH's Avatar
JET MECH
just ordered mine........better than paying $600.00 bucks for the arc unit.
Old Oct 3, 2009 | 10:20 AM
red_magic2000's Avatar
red_magic2000
Same here just ordered mine, and though I'm not cheap, I just can't justify paying 600 dollars for the ARC piece. Great product for the Z community. ARC is just going to have to stop producing theirs cause this one will sure take all the business. Ever though about making one of those radiator cooling panels also?
Old Oct 4, 2009 | 09:16 PM
Twenty4's Avatar
Twenty4
just ordered mine! THANKS!
Old Oct 5, 2009 | 06:18 AM
sweets2k's Avatar
sweets2k
Ordered mine! THANK YOU!
Old Oct 5, 2009 | 01:11 PM
QNman's Avatar
QNman
Do I need a hardware kit? Will the plastic pan h/w suffice? Or is yours better? Just curious... I already bought a h/w kit too.
Old Oct 5, 2009 | 01:24 PM
Tko's Avatar
Tko
Looks great!
Old Oct 5, 2009 | 02:10 PM
ZSpeedPerformance
You can use the OE hardware if it is in good shape and all there.
I can refund the hardware kit if you like.
Old Oct 5, 2009 | 06:22 PM
ZSpeedPerformance
Default PC Black Test run!
Just got back from picking up the PC black test runs, I had 2 pieces powder coated to make sure it was the correct color and finish I wanted before having them all done. The rest of the batch will be going to PC's tomorrow or Wednesday.
This particular texture looks a lot like Teflon.
They look even better in person!
Old Oct 5, 2009 | 06:26 PM
Jay'Z's Avatar
Jay'Z
Thats sick!!
Old Oct 5, 2009 | 07:15 PM
mD2MHK's Avatar
mD2MHK
wow dat IS hot
Old Oct 5, 2009 | 07:50 PM
widerisbetter's Avatar
widerisbetter
Just ordered!!! Is it here yet???
Old Oct 5, 2009 | 07:59 PM
TreeFiddyZee
Do WHAAAAT!?
OK. PC it is. These look awesome. Maybe you could sell a gazillion to Nissan so they'd quit using the crappy panel.
Old Oct 6, 2009 | 05:36 AM
QNman's Avatar
QNman
OK... if you don't mind, I'll take you up on it. My Z is only 6 months old, and all the h/w is still there and in perfect shape.
Thanks, dude.
