Caster Adjustment !? HELP NEEDED
Old 03-01-2017, 09:55 PM
ahmad zeee
ahmad zeee's Avatar
Default Caster Adjustment !? HELP NEEDED
hey guys i seriously need to figure out what exactly i need to adjust the caster on my 350z. i have a 2003 Z and the front right caster is +5 , left -5 can't remember exactly what it was. what do i need to bring my caster back in spec ?? as you can see in the pictures my right wheel is closer to the bumper whereas left is pushed back. any help is appreciated
Old 03-02-2017, 03:15 AM
-5 deg?? Yeah, there's something seriously broken if that's the case. I'd tell you to bring it to an alignment shop but you must have already been there to know the exact caster angles, no?
How does the car drive? (If it does with those whacked out numbers.) Based on the numbers, your car should be making left turns on its own.
If it's tracking straight and everything else about alignment is correct, I'd suspect your fenders are misaligned causing optical inaccuracy.
Old 03-02-2017, 03:28 AM
has it ever been wrecked?
Old 03-02-2017, 04:44 AM
ahmad zeee
ahmad zeee's Avatar
i don't know if it was wrecked by the previous owner but i think not. ill go ahead and mention that once i was sleepy as f and landed over an island going 20mph but that was about 2 years ago. idk if it happened after that but i noticed it about 5-6 months ago.
Old 03-02-2017, 04:46 AM
ahmad zeee
ahmad zeee's Avatar
The car used drives fine but pulls little to the left. all the alignment shops i go to can't tell me what i need exactly to fix what's messed up
Old 03-02-2017, 05:55 AM
HCO_surfer
HCO_surfer's Avatar
Why would you put other people's lives in danger and drive while you're tired? Serves you right.
Old 03-02-2017, 06:58 AM
OK, few more questions then...
What's your suspension set-up?
Do you have adjustble FUCA?
What do all the other alignment numbers tell you? Camber, toe, etc.
Have you or the alignment techs checked all of the front componentry?
I would point fingers at one or both of the LCAs being bent but without hands-on, only speculating.
Old 03-02-2017, 07:00 AM
iideadeyeii
iideadeyeii's Avatar
Very helpful
Old 03-02-2017, 07:14 AM
could the lower inners being blown out cause this... maybe one being blown and the arm forward and vice versa on the other side?
Old 03-02-2017, 09:00 AM
I'm going to say, parts are bent and things need to be replaced. Time to start measuring
The following 3 users liked this post by terrasmak:
iideadeyeii (03-02-2017), Mayow83 (06-16-2020), zwei_the_c (02-23-2019)
Old 03-03-2017, 04:22 AM
ahmad zeee
ahmad zeee's Avatar
thanks guys. my first post here and already getting a lot of advice n stuff. will keep you guys updated on what i find out. gonna take the front end apart soon
Old 04-05-2017, 09:34 AM
jcruz0143
jcruz0143's Avatar
Hi, God bless you all, it could be the front lower control arm bushing going bad.
Old 04-05-2017, 05:17 PM
CK_32
CK_32's Avatar
Yea if you ran over a island that is just as bad as being in a crash...
Accept instead of your body taking the force your wheels tires and suspension literally take ALL of the forces.
I'd take it in for a professional look at the suspension and see what 100% needs to be replaced. Something def needs to be replaced cause it sounds like you busted some things when you crashed into the island.
Old 04-05-2017, 05:18 PM
CK_32
CK_32's Avatar
Originally Posted by iideadeyeii
Very helpful
Well you were about just as helpful with that comment..
Lol
Old 02-20-2019, 05:46 PM
10-E-C-350Z
10-E-C-350Z's Avatar
Thanks for the update ********!
Old 02-23-2019, 12:43 AM
zwei_the_c
zwei_the_c's Avatar
I doubt the OP still owns the Z still to bother giving us an update about his bent suspension components/blown bushings.
