part out?
Old 02-17-2018, 06:16 PM
joshua350z6841
joshua350z6841's Avatar
Default part out?
thinking about parting out thew 350z here is a list of parts figured ask 75% of listed price. what do u guys think. all items have less then 2000 miles. motor and transmission have 30k. what do u guys think.
Hotchkis front an rear sway bars 390
a stock brembo kit 1500
kw clubsport 3200
jim wolf full clutch kit 775
nt03 18x10.5 1400
z1 plenum spacer 200
z1 race intake 288
braided brake and clutch lines 120
long tube headers 600
megan racing motor mounts 310
Torque Solution TS-TM-350 Billet Aluminum Transmission Mount 350Z Z33 100
bigger power steering cooler 200
nismo y pipe 420
cjm stage 2 fuel return kit e85 1125
SPL Solid Differential Mounting Bushings 160
SPL Pro Solid Subframe Bushings 221
SPL PRO V3 Front Upper Arms 760
SPL FKS Front Lower Arm Bushings (Inner) 130
SPL FKS Front Lower Arm Bushings (Shock Mount) 130
SPL FKS Front Compression Rod Bushings 175
SPL TITANIUM Rear Camber Links 300
SPL TITANIUM Rear Mid Links 800
SPL TITANIUM Rear Traction Links 330
SPL FKS Rear Knuckle Monoball Bushings 540
spl wrench 50
SPL Eccentric Lockout Kit 75
pls water an oil temp 240
350Z AFP Clutch Pedal Systems New Rev 3.3 Complete Replacement Assemblies 250
Greddy Radiator cap 50
Koyo 350z racing radiator (thick core 428
Nismo 350z/G35 Thermostat) 75
Pathfinder Cooling Kit 200
Setrab Oil Cooler 34 Row (13" x 1 1/4" x 10 1/4") 700
MTech Shifter Spring 50
act disk 125
NRG Front Strut Bar 100
haltech map 350
ultra racing Rear Lower Bar 210
GTSPEC 4 Point Mid Chassis Reinforcement Brace 345
ID 1000cc Injectors 720
Aeromotive 340 (11142) 172
z1 shifter 50
GReddy Air Diversion Panel 160
Tomei 440014 Expreme Ti Full Titanium Single Exit Exhaust System Nissan 1000
Whiteline KLC110 350Z Front Sway Bar End Link 135
Whiteline KLC141 350Z Rear Sway Bar End Link 135
ARP 100-7716 Wheel Studs 12x1.25 3in 14mm 144
H&R Trak+ 20mm Wheel Spacer rear 115
H&R Trak+ 10mm Wheel Spacer Kit front 112
PI 350Z/G35 VQ35DE And REVUP Oil Catch Can Kit 371
z1 one hole turbo oil pan 100
doluck front bumper 1250
doluck front bumper paint 500
alpine radio plus case an wires 150
radio antenna 15
remove oil warmer an have ports weled up 100
carbon fiber hood 800
aero catch pins 80
Haltech HT055016Haltech HT055016 Platinum PRO Plug-In Platinum PRO Plug-In 2595
HT-011000 Flex Fuel Composition Sensor 192
aem 12 trim switch 100
Haltech Wideband Display Gauge 120
HT-059986 WBC2 - Dual Channel CAN Wideband Controller Kit 474
Corbeau FX1 Racing Seat driver an pas an brackets an rails 1040
driver double rail 25
swife 1050 lbs front springs 200
Driven Steering Wheels DSW02 Flat Dish Steering Wheel 12.9'' 1.95 pounds 160
nrg quick connect an bell short hub 170
kognition 68 in wing 1800
new fuel pump 6/2016 300
roll bar 2000
chassis mount wing 320
custom oil cooler mount 480
carbotech xp20 front 321.25
Old 02-18-2018, 05:58 AM
Bak3rme
Bak3rme's Avatar
PM CF hood. pics also plz
Old 02-18-2018, 06:23 AM
You need to post in correct section with user verification....
Old 02-18-2018, 08:38 AM
CK_32
CK_32's Avatar
I think you should post this in the proper section.....
Also come down on some pricing. Some of that stuff you can buy for the same price at a store during regular sales brand new.
Old 02-18-2018, 09:59 AM
joshua350z6841
not for sale at this time. looking for input if what % rate off msrp i should expect. looking to get an idea if i want to part out or just try to sell out right.
Old 02-18-2018, 03:03 PM
dboyzalter
6 inch cawk is my fave!
dboyzalter's Avatar
Anything over 50% consider yourself lucky, asking 75% you might sell a few things but will likely be holding onto your stuff for a while.
joshua350z6841 (02-18-2018)
Old 02-18-2018, 03:07 PM
dboyzalter
dboyzalter's Avatar
Also most of your prices are retail + prices... One example
https://www.z1motorsports.com/coolin...it-p-3011.html
Another example would be the sway bars that are $333 new from tire rack...
Factory brembo brakes you would be lucky to get anything north of $500
Old 02-18-2018, 04:01 PM
I have to laugh at people who think used parts can sale for like new prices. I always listed stuff at about half what i paid for it
Old 02-18-2018, 05:58 PM
joshua350z6841
thanks for the input. most of the prices were msrp when i bought them. i am sure price has changed over the years an i will have to adjust. i am a dollar to high on the path cooler mod, and the brembo brakes are rebuilt with z1 two piece rotors.
Classy
Texas Marketplace
04-26-2012 08:51 AM
atlantavip
01-19-2007 06:52 PM
Quick Reply: part out?
