My car shut off highway exit.
Old 03-21-2018, 06:02 PM
albaugh81
albaugh81's Avatar
Default My car shut off highway exit.
Had something scary happen to me this Monday while I was getting off a highway exit. My car shut off and I was coasting at 65 mph, stepped on my brakes and couldn't really stop then as I came closer to the car in front of me I pulled the ebrake and steered the car off to the side of the road coming very close of hitting the car in front of me. !HOLY ****! I looked like a idiot & I bet the person in front of me thought I was speeding or wasn't paying any attention. After a few seconds I started the car up and put the ebrake down and was on my way home. No CEL or ABS light. When I got home first thing I did was get the laptop with my UpRev software & check for any hidden codes. Found only one code for the ABS & it was U1000. No hidden codes for the engine at all. Looking up the U1000 code on the internet and it could be a list of things. So the blame can't be on the ABS alone, the problem is hidden somewhere else on the car. I'll be checking for loose grounds in the engine bay and in the dash when I get some warm weather. If anyone has any insight on this pleez feel free to let me know what I should do or look for. Thanks
Old 03-22-2018, 09:34 AM
HOMiEZ
HOMiEZ's Avatar
This really sounds odd. Even with all electronics down our brakes should still work. anyone with more mechanical savvy can chime in here?
Old 03-22-2018, 03:50 PM
zakmartin
zakmartin's Avatar
No power, no power brakes. It's a bear to brake when the engine cuts out and the brake booster isn't getting vacuum. I bet you lost your power steering too. For what it's worth Albaugh, you did everything right by not panicking and pulling off to the curb.
Did you lose all electrical when the engine cut out or was it just the engine?
HOMiEZ (03-23-2018)
Old 03-23-2018, 11:31 PM
CK_32
CK_32's Avatar
Yup. No power no brakes on the Z.
Only brake you will have is the mechanical e brake. Z’s like almost all modern cars have brake boosters which need power.
Boneout JZA80
Southern California
15
05-30-2007 07:57 PM
Dream350Z
10-14-2005 11:17 AM
DIE DIE DIE
12-22-2004 02:40 PM
nitrousoxidex
11-18-2004 06:20 PM
Quick Reply: My car shut off highway exit.
