Need help with bolt size
Old 08-14-2018, 05:17 PM
bcoffin23
bcoffin23's Avatar
Default Need help with bolt size
Can anyone give me the specs to the rear lower shock bolt? I need to find a drill bit in the same size, and cannot find the specs. Thanks!
https://conceptzperformance.com/niss...0a_p_12300.php
Old 08-15-2018, 07:58 AM
SpartaEvolution
SpartaEvolution's Avatar
The bolt is an M12 x 1.25 x 70mm (plus the tapered bit, so a custom 75mm I guess?).
What are you trying to do?
Old 08-15-2018, 09:28 AM
I’ll bet that it seized in the bushing from wha5 he is asking.
Old 08-15-2018, 09:33 AM
SpartaEvolution
In that case,
hammer + punch =
Old 08-21-2018, 05:45 AM
bcoffin23
bcoffin23's Avatar
Redrilled the lower shock forks to get the rear lower. I am fully stripped out in the rear, and on my coilover setup, my rake is too much even when fully bottomed out in the rear.
And no, I cannot run a softer spring in the rear
Old 08-21-2018, 07:29 AM
SpartaEvolution
Ahh, that makes sense. Bummer! I've used heli-coils to repair threads before, but never on anything that large..
Edit: I misunderstood the intent of the re-drilling. Are you also planning to weld a nut onto the fork in the new spot? If not.. there's a reason Nissan didn't want the both the bolt and nut to rotate relative to the shock body. Sounds like it'd be a lot safer (though more expensive) to order a new spring with the same rate and a shorter free length.
Good luck OP.
Old 08-21-2018, 12:22 PM
Helper spring, that is how it is properly done
Old 08-21-2018, 04:43 PM
bcoffin23
bcoffin23's Avatar
Good luck OP.
These are true coilovers from Buddy Club. The fork never came with a nut welded onto it.
Old 08-23-2018, 05:42 AM
dboyzalter
6 inch cawk is my fave!
dboyzalter's Avatar
Bet this didn't end well.
Old 08-23-2018, 05:52 AM
bcoffin23
bcoffin23's Avatar
Whys that?
I just wanted to get the rear lower to reduce my rake. We corner balanced the car this week and got the cross weights 50/50, rear is still a bit lighter but not to much. Rerouting battery to the rear and will be running to some aero to help get some weight over the rear.
Old 08-23-2018, 08:15 AM
SpartaEvolution
Huh, I figured all aftermarket shocks did, but now that I'm looking into it it's ~half and half (assuming the pics I'm finding are actual G/Z products vs representative).
Bilstein does, Nismo does, BC does, RS-R does, Koni does not, Ohlins does not, Apexi does not, KW does not.
Old 08-23-2018, 09:35 AM
dboyzalter
dboyzalter's Avatar
I guess your rear shock is much different than mine, I don't have any room for anything like that.
Old 08-23-2018, 09:37 AM
bcoffin23
bcoffin23's Avatar
I'm running true coilover. I drilled the lower fork hole 1-inch higher on the fork. Fit right in.
GT-ER
08-12-2010 05:05 PM
JasonZ-YA
07-02-2009 12:10 PM
Bwicked
04-18-2009 08:49 AM
wren57
05-04-2006 04:29 AM
Quick Reply: Need help with bolt size
