Engine Swaps For all your engine swap experiences, ideas, questions, & more..
Can’t get engine to start (or hand crank)
Old 01-21-2019, 12:27 PM
Gveeder
Gveeder's Avatar
Default Can’t get engine to start (or hand crank)
Just replaced engine with a junk yard one. Hooked everything back and up added fluids . It still won’t start. When turning the key I would just get a loud click. Checked battery and believe it was the starter. I then replaced starter, which then started on fire.
Noticed that I can no longer turn by hand or braker bar. I could at the junk yard, but can’t any longer. Removed spark plugs to see if it was a compression issue with no success.
Any my thoughts on what to do next?
Old 01-21-2019, 01:18 PM
Ls swap
Old 01-21-2019, 01:25 PM
or buy a block from IPP and build it yourself
Old 01-28-2019, 04:04 AM
jksstar
jksstar's Avatar
Check flywheel /flex plate to see if its hung up on something. You may have to drop the trans but I'd bet something not right
Fooshe
04-17-2007 03:43 PM
DM350Z
01-31-2004 09:12 AM
Quick Reply: Can’t get engine to start (or hand crank)
