Gauge Cluster Switches
Old 02-18-2019, 02:04 PM
neilca
neilca's Avatar
Default Gauge Cluster Switches
I have a 2008 grand touring 350z. I want to install some fog lights but struggling with where to put the switch. I was looking at using the switch on the lower right side of the gauge cluster. It doesn't seem to have a function. The upper one on the right side changes the display in the left center gauge on the dash. Does the lower switch have a function? Any other suggestions on locating a switch to turn off the lights?
Old 02-19-2019, 03:33 AM
karlt
karlt's Avatar
Owner's Manual.
Old 02-19-2019, 05:40 AM
neilca
neilca's Avatar
Any suggestions on alternative locations?
Old 02-20-2019, 04:10 AM
Freise
Freise's Avatar
https://www.aironboard.com/online/pu...een-amber.html
If it were me I'd replace the blank for the switch, it'd look as close to stock as you could get
ajpasa (02-26-2019)
Old 02-22-2019, 03:39 PM
neilca
neilca's Avatar
I like it, not sure that switch will work. Thanks.
Old 02-22-2019, 04:39 PM
Freise
Freise's Avatar
The switch I linked is more or less an exact fit to that location, not sure if that is was you meant by "not sure that switch will work," or if you just had something different in mind.
Either way, here is another thread with more info:
https://my350z.com/forum/exterior-an...eat-slots.html
Old 02-22-2019, 05:01 PM
neilca
neilca's Avatar
I think it means I lack imagination. At first glance I didn't think it would fit as advertised but I looked again and I think this is a great find. However, you have now unleashed my imagination and I found this!
: D
ajpasa (02-26-2019)
Old 02-24-2019, 04:01 AM
Cux350z
hatersgonnahate
Cux350z's Avatar
those switches should also fit on the driver side lower dash (where the TCS/VDC and gas door buttons are)
SIX
06-14-2004 02:14 PM
dobbuster
01-16-2003 11:23 PM
Chebosto
09-04-2002 03:40 AM
Quick Reply: Gauge Cluster Switches
